Supercheap 800W Inverter Generator $359 or Old Honda??
Submitted: Friday, Dec 11, 2009 at 12:54
ThreadID: 74331 Views:8740 Replies:8 FollowUps:6
Hi All
I noticed Supercheap have a 4 stroke 800W Inverter Generator on sale for $359... It's been reduced by 55%
I was wondering what people thought of these and whether they would prefer to buy of these new, or get an 2nd hand Honda generator - like a EX650
For $359 it's dirt cheap (and probably noisy), but would it last longer than a 2nd hand Honda for the average person who uses it once/twice a year?
Reply By: Tenpounder (SA) - Friday, Dec 11, 2009 at 13:05
Two comments: first, a decent 800W inverter, if it's a real sine wave inverter, would probably cost you more than $359, just for the inverter, so how good is the quality of this offer?
Second, a 650w Honda is a relatively small unit (like about 500w continuous) so you should ask if that is big enough for your needs. Is the Honda EX650 an inverter? how good is the voltage control? is it a pure sine wave?
How long it will last is only part of the story: what is the electrical quality of the output? You have not mentioned voltage stabilty, frequency stability, and these things really matter.
There's a good article on this site about these questions. About the only simple thing I can say is that aren't ant simple answers!!
I bought a Yammy Inverter.
Does this help?
AnswerID: 394611
Reply By: Member - ross m (WA) - Friday, Dec 11, 2009 at 13:41
I would take the old Honda ,Yamaha or any Japanese brand over the supercheap special.
How long it will last depends on how many hours it has done.
AnswerID: 394614
Reply By: Member - Stephen L (Clare SA) - Friday, Dec 11, 2009 at 14:04
Hi Ozwasp
I had a post on here a few weeks ago of what a non inverter generator can do to a portable fridge when hook up to a cheap generator. The voltage spike was unreal when tested. The advice from our technician at work is these type of generators are only safe to use for lighting. If it is not an inverter type generator, under no circumstance connect a computer, tv, or portable fridge to that generator. The damage it could cause to modern electronic components will cost you many hundreds of dollars for repairs, or even replacement. Engel produce their cheapest inverter type generator for under $1000. It would be cheap insurance to spend the extra dollars for an inverter type generator and give you peace of mind when running more than just lights.
Smile like a Crocodile
AnswerID: 394622
Follow Up By: Member - Allan B (QLD) - Friday, Dec 11, 2009 at 14:25
"these type of generators are only safe to use for lighting"
And only incandescent lighting at that!
I wouldn't use them on LED, CFL or other fluorescent lights or anything that had even the simplest electronic components!
FollowupID: 662961
Follow Up By: Member - Stephen L (Clare SA) - Friday, Dec 11, 2009 at 14:31
Hi Allan
You are spot on. I was trying to infer that they should not be used on any appliance that has electronic components.
Thanks for that.
FollowupID: 662962
Follow Up By: Wilk0 - Friday, Dec 11, 2009 at 15:25
Hi Steve,
I believe that the engel isnt an inverter model. I'm sure someone will let me know if I'm wrong.
Cheers Wilko
FollowupID: 662968
Follow Up By: Member - Stephen L (Clare SA) - Friday, Dec 11, 2009 at 19:44
Hi Wilko
We have not tested one at work, but have been told by our rep that they are 100% inverter generators. It even mentions this in their latest brochure. If they were not what they have printed, they would be out of business quick smart. What I do know is that they are a re badged Honda, with a few features missing.
FollowupID: 663004
Reply By: Roughasguts - Friday, Dec 11, 2009 at 14:52
These are invertor generators!!! I would have one but there only 800 watt, a bit light on Output for me.
AnswerID: 394628
Reply By: Member - Carl- Friday, Dec 11, 2009 at 15:17
Everyone has raised good points so far.
I know from expereince that a noisy generator, ranks just below a noisy group of teenagers for destroying a great camping expereince.
I have had a 2200cx Honda at 66 DB but moved to a EU2.0 Honda at 54 Db. This is only 12 Db and that does not sound much but is a great number at 10.30 pm in a camp spot.
Noise level might be a consideration if you are planningto camp near other campers. You have the right idea however in asking everyone.
AnswerID: 394631
Reply By: Outbacktourer - Friday, Dec 11, 2009 at 16:33
This is a 4 stroke 800W Inverter (safe for electronics) generator that looks like a Honda e10 for $359 with supercheap warranty backup. Unless you want to run air con or heating it will do all you want for camping purposes.
I fail to see how this cannot be a bargain and have just rung up to put one on lay by to replace my 5 year old $98 750W GMC that is far from dead, but noisy and harsh on the appliances.
OT
AnswerID: 394638
Follow Up By: Member - Allan B (QLD) - Friday, Dec 11, 2009 at 17:01
OT, if it's an 800w Inverter.......it's a bargain!
Just saw a special at my local hardware.......600W max ....$199.
Don't think I'll bother thanks!
FollowupID: 662981
Follow Up By: Outbacktourer - Friday, Dec 11, 2009 at 18:04
Definitely 4 Stroke 800W inverter p 18 of the cattle dog
FollowupID: 662987
Reply By: Mrbrush - Friday, Dec 11, 2009 at 18:50
I Bought one and it ran fine , except when I would run a 3 stage charger it would constantly rev high and low. Which was annoying. Just a little to noisy for camping . So I sold it. Otherwise if it was`nt too noisy I would have been happy to keep it.
AnswerID: 394654
Reply By: john&thejayco - Friday, Dec 11, 2009 at 19:06
g'day Ozwasp,
i picked up one of these little inverters last time they had them on special and so far can't complain to much. having seen the honda inverters in action on the job they don't really compare but they also don't compare on price.the supercheap job i have run's a bit louder than the Honda and does not run as smoothly, i think the mixture needs adjusting a bit also.but it runs our fridge and lights in our jaydove camper on short trips with out a problem.so far so good,only time will tell, and usually things don't break down until the day after the warranty runs out.don't forget they recommend using a surge protector with it also. hope this helps.
AnswerID: 394658
