TECHNI ICE
Submitted: Monday, Dec 07, 2009 at 20:29
ThreadID: 74248 Views:15126 Replies:11 FollowUps:5
Has any body used Techni Ice, the reusable dry ice in plastic satchel sheets. Does it last alot longer than crushed or block ice under normal esky use and if so how many sheets do you need for a 40 lt marine type esky.
Murray
Another Mexican
Reply By: TerraFirma - Monday, Dec 07, 2009 at 21:07
I thinks it's main advantage is the re-useable aspect, not sure it lasts longer than block ice. I use it a fair bit and it works fine. It has been handy when we are away as we can keep re-freezing it and transferring it to our smaller portable eskis.
AnswerID: 394116
Reply By: Member - The Bushwhackers -NSW - Monday, Dec 07, 2009 at 21:14
Hi Murray,
We use Techni Ice sheets in our 'commercial' type esky (thick wall insulation). It would be about 40 ltr, same as yours.
We find it lasts longer than crushed ice, and is much more convenient to use... no wet packages etc.
Basically we use as many sheets as we can fit around the food and drinks, minimum 4 sheets, 6 is better.Lasts the best part of a week, with care taken not to overuse the lid of the esky.
When you first get them, you really must follow the instructions regarding immersing them in water, to swell the compartments. My wife worked long and hard at this, but with good results.
A friend of ours didn't like them, I suspect the initial 'swelling' process may not have been done to the letter......
Don't know how this bit works, but the longer you leave them in the freezer at home, before packing them in the esky, the longer they last.
Recommend? Sure. Bought ours off ebay, probably had them more than a year now.
Hope this helps, Dave
AnswerID: 394118
Follow Up By: Member - Murray R (VIC) - Monday, Dec 07, 2009 at 21:30
Dave
how long do they need to be in the freezer to freeze, just over night or longer. I am away at xmas and have access to a freezer and think that they might be the way to go for cold drinks and use the 12 volt fridge for the food .
Murray
Another Mexican
FollowupID: 662346
Follow Up By: Member - The Bushwhackers -NSW - Monday, Dec 07, 2009 at 23:35
Hi Murray
We leave ours in the freezer all the time (when not in use). I would suggest a week before you go, to start, then you can re-freeze them as required while you are away, with access to a freezer. Overnight would do in that case, as they are not fully defrosted.
Cheers, Dave
FollowupID: 662373
Reply By: Robin Miller - Monday, Dec 07, 2009 at 21:15
It does hold more "cold energy" than Ice Murray but we prefer not to use it because its lower initial temperature can actually harm some food in a mixed fridge.
We prefer just to freeze water in strong bottles.
The only time we use ours now is as a quick blanket to throw over drinks.
Robin Miller
AnswerID: 394119
Follow Up By: Member - Murray R (VIC) - Monday, Dec 07, 2009 at 21:38
Robin
when you say that they can harm some foods do you mean that they can burn the foods like fruits and some vegies. Could'nt you place a sheet of styrene between the ice packs and food to stop this.
Murray
Another Mexican
FollowupID: 662348
Follow Up By: Robin Miller - Tuesday, Dec 08, 2009 at 07:46
Hi Murray
Yep that works but bubble plastic works better because its not stiff and doesn't break if heavy food above bounces around.
The frozen water bottles though make for ice cold water for drinking or mixing 50/50 with chardonay which we like to do !
Robin Miller
FollowupID: 662393
Reply By: Member - Kroozer (WA) - Tuesday, Dec 08, 2009 at 00:30
I think there rubbish myself. I can get 3 days out of 2 bags of crushed ice and one block in my 70 techni ice esky. And thats with adding hot drinks and 35+degree heat. When i used the supplied recommended number of sheets with one block of ice and same amount of tucker and drinks they had all melted by midday the next day and it was only the block ice keeping things cold. Might work down south in the cool but up here it stands no chance compared to good old ice. They even go slimy after a while. Alot cheaper then buying ice all the time, but nowhere near as reliable or effective.
AnswerID: 394153
Reply By: Member - MUZBRY(Vic) - Tuesday, Dec 08, 2009 at 07:39
Good morning Murray
Little Wes has your drawings and is doing his best. He will be here at my factory on Saturday having a good look.
AnswerID: 394164
Follow Up By: Member - Murray R (VIC) - Tuesday, Dec 08, 2009 at 18:20
Murray
Hope they help with the g/box problem, now only have to fix engine prob.
murray
Another Mexican
FollowupID: 662476
Reply By: Outbacktourer - Tuesday, Dec 08, 2009 at 18:52
Happy Techni Ice user here..
OT
AnswerID: 394248
Reply By: ss--ss - Tuesday, Dec 08, 2009 at 20:02
I have about 10 sheets of tech ice & have used them for a few years..They are ok but they don't seem to last that long.. Someone once told me to fill icecream containers or 2 litre orange juice bottles with water & freeze.. Put these at the bottom of the escky & they keep stuff cool for days. Better than the tech ice sheets.
AnswerID: 394262
Reply By: putrol - Tuesday, Dec 08, 2009 at 21:00
one word to describe my six sheets [which im glad i didnt pay for] CRAP!
AnswerID: 394282
Reply By: Leroy - Tuesday, Dec 08, 2009 at 22:10
I've used them and you can't go past block ice and then some crushed ice around your stubbies :) Lasts a few days compared to the 'slime sheets' :O
Leroy
AnswerID: 394296
Reply By: Austravel - Friday, Dec 11, 2009 at 17:50
Depends on the use. Block ice is of course much better but you can't compare the energy. Try making a block the same size of the techni ice and then compare. Yes they are slimy which I don't like. Easier to put in the engel freezer and over night they are frozen. Though won't last as long as if placed in a 240V freezer for a few days of course, again energy. Block ice is way better if you have the space and means to freeze. If not then a few techni ice are good value especially if free with one of their freezers.
AnswerID: 394647
Reply By: Member - Norm C (QLD) - Friday, Dec 11, 2009 at 20:16
I use them a heap, but not in the conventional way.
We are 'on the road' full time, now with a van (previously CT).
In addition to the 2 door fridge freezer in the van, we have two 40 litre Engels in the back of the ute - generally both on freeze (one with caught fish, the other for our meat). I keep a Techno Ice sheet on top of each freezer to separate the frozen stuff from the new unfrozen as it is added. Works very well.
Other big use is in the big esky we take in the boat when we go fishing (mostly in far North / NT). I put 5 or 6 sheets in the esky for each trip with our cold water and lunch. As we keep fish, I put the fish on the bottom and lay the sheets on top. Works great. Fish are cooled and kept very well without being in water. Also just toss live crabs in and put sheets on top - they are very quiet and easy to tie when we get home, but have damaged the sheets at times.
For keeping drinks (particularly beer) cold, you can't go past crushed ice. For general use, block ice is great, but it takes up a lot of space and produces water.
The advantage of Technie Ice is that it takes up little room, is flexible and stays dry.
Back when we used an esky for food, I used to fill a couple of 2 Litre milk bottles with water and freeze them. I'd put them at the bottom of the esky and pack stuff around / on them. I'd then lay Technie Ice sheets across the top, sometimes 2 thick. This worked very well and lasted at last 4 or 5 days - often more. But not great for adding hot beer to cool - for that you need a fridge or crushed ice.
If you buy them, do it via EBay. Techni Ice sells there (under a different name). Way cheaper and posted free. You can generally get them so cheap that it is worth giving them a go.
Hope this helps.
Norm C
AnswerID: 394666
