Glind Heat Exchanger in a 78 Series RV Troopy,
Submitted: Sunday, Nov 29, 2009 at 19:34
Geoff (Newcastle, NSW)
Hi Team,
I have procured a Glind shower kit.
Does anyone have suggestions on the neatest - easiest place to mount the heat exchanger and pump in the above troopy?
I've pondered and looked this afternoon. It's a busy engine bay with the factory TD and a dual battery tray!
Geoff
| Geoff,
Landcruiser HDJ78,
Reply By: Haza - Sunday, Nov 29, 2009 at 21:24
I have a Helton kit which I have removed from my previous vechicle.
I was also looking at where to fit my exchanger and pump today.
I might mount the exchanger on the bracket the holds the radiator overflow reserve, and the pump beside the batteries front left same as preious response, I've still got to fit the 12V Redarc was thinking the firewall and other odds and ends to fit under the hood, fuse box etc
Mine is a N/A 78Series.
393168
Reply By: Wayne (NSW) - Sunday, Nov 29, 2009 at 22:17
Geoff,
Heat exchanger on
mine is located next to radiator and behind headlight on passenger side. It is also mounted vertical.
The pump is not fitted under the bonnet but is a remote unit that is on the end of 30mt of hose.
Because of the time that the shower has to be running it is better to take the pump to the water rather that the water to the pump.
Wayne
393173
Follow Up By: Geoff (Newcastle, NSW) - Sunday, Nov 29, 2009 at 22:28
Hi Wayne,
Thanks for the
information, much appreciated.
Yep, great advice on taking the pump to the water, thanks again.
Geoff
| Geoff,
Landcruiser HDJ78,
661243
