Upgrade override brakes to electric on camper
Submitted: Monday, Nov 16, 2009 at 20:08
portlester
Hi guys
I'm in the market for a second hand trak shak. One of the ones I'm looking at has only got override brakes. I would prefer electric brakes.
I know they can be upgraded to electric brakes, but can anyone give me a rough idea of price - if too expensive it may not be feasible & would be better to wait and find another camper.
Secondly, if we were to purchase a camper with override brakes it would possibly be some time before we hand enough money in the biscuit tin to upgrade to electric. How do override handle 4wd territory such as the High Country (ie low range, sometimes steep, sometimes slippery, ...).
Ian
Reply By: GerryP - Monday, Nov 16, 2009 at 21:29
Hi Ian,
I have a Challenge camper trailer that originally had override brakes. However, I was fortunate that I knew someone with a "spare" electric brake axle set from a caravan, which I swapped for some stuff I no longer needed. All I had to do was adjust the track (cut, shut and reinforce the axle) and buy matching u-bolts. The job itself wasn't too difficult.
A couple of advantages of electric brakes I have found are that you don't have to worry about flipping the latch in place when reversing, which can be a pain if you need to reverse back down a sand
hill after getting stuck. The other advantage is steep forward descents where you are able to feather the trailer brakes while crawling down in first low using engine braking. This helps to keep the trailer in line - used this a couple of times on the OTT earlier this year on our way to
the tip and certainly made a difference.
Sorry I can't give you an idea on costs, but I'm sure someone here can.
Gerry
391450
Reply By: Member - Wamuranman - Monday, Nov 16, 2009 at 21:47
Check out this link:
Electric Brake Sets - Trailer Warehouse
Cost depends on the stud pattern
At the trailer warehouse the price for a 10" set of hubs range from $550 upwards.
Fitting costs extra of course.
391451
Reply By: Member - Duncs - Monday, Nov 16, 2009 at 22:00
Ian,
I don't know what you will be towing the camper with and that will have some bearing on the answer to the second part of your question.
I have been towing a Trak Shak for 13 years and it still has the override brakes, drums.
In all honesty they hardly work these days. There are a number of reasons and I have spoken to many trailer manufacturers and repairers about the problem but it has not caused any problems. The Patrol is heavy enough and has good enough brakes to pull it all up pretty
well. The Trak Shak only weighs in at about 660kg empty it is not hard to stop.
Even when the brakes were working
well they presented few problems. I certainly never had an issue backing down sand hills or any other
hill for that matter. The only time when the override brakes needed the latch in was backing into the
parking spot at home. To get into
the spot I had to back up a kerb where there was no driveway ramp and the brakes would lock on at the step.
I have had my TS in the Vic HC a number of times. It is a delight to tow off road, it follows like a faithful pup and I have literally never backed away from a
hill, up or down, because the TS was hooked on the back.
Hope this helps
Duncs
391452
Reply By: nsngood - Monday, Nov 16, 2009 at 22:05
we have a trailer repair bloke locally south of
perth and from previous discussion i believe you will pay approx $1000 per axle for this conversion. Not including the controller in the vehicle
391453
Follow Up By: jothefw - Tuesday, Nov 17, 2009 at 10:22
Just had a controller fitted - $188 to supply. Think it's called a Redarc? Not certain ..
659373
Reply By: Woodman 1 - Tuesday, Nov 17, 2009 at 04:42
Had our complete
campsite converted by pro axle at narellan for about $800 back in 2008. Worth every cent as we were never completely happy with the original over-ride system .
391470
Reply By: Member - Lia H (SA) - Tuesday, Nov 17, 2009 at 21:46
Hi, we got a quote today, for about $1300. But the man made it clear we could do it ourselves cheaply and easily.
Have found many DIY kits today, just sorting out which ones would be good and which one not, or if there's any difference!
391551
Reply By: Member - Howard T (QLD) - Wednesday, Nov 18, 2009 at 12:37
Hi Ian
I am in Cent Qld and have just got a quote of $250 per wheel to do my Trackabout.
Howard.
391613
Reply By: portlester - Thursday, Nov 19, 2009 at 17:19
Thanks guys for the info
Looks like we could head down the path of override brakes and then upgrade to electric at a later date, but need to take this into accout wrt how much we originally pay.
391790
