12V to 12V Battery Charger, will it work?
Submitted: Sunday, Nov 08, 2009 at 09:11
ThreadID: 73606 Views:17258 Replies:10 FollowUps:14
I have a dual battery system fitted to my car with a standard tractor battery as the aux battery. I have recently bought a 200AH Agm battery which I currently charge with a projecta 7 stage 16AH smart charger while at a powered site.
I am considering setting the new agm battery up in the car or camper trailer and have seen the DC20, PROJECTA 3 Stage Automatic 12V to 12V 20Amp Battery Charger in the auto shop. I have checked out the website video but am still unclear on a few points. 1. Do I draw power for the DC20, PROJECTA 3 Stage Automatic 12V to 12V 20Amp Battery Charger from the existing main battery or aux battery, 2 What is to stop the supply battery being flattened by feeding to the agm, 3 Do these chargers only operate when the vehicle is running ie alternator outputting charge?
I am not convinced that the expense of setting this up is validated, and that the agm battery would ever be fully charged due to the hours of driving time required. Would I be better simply to replace the existing aux battery with the agm knowing that the alternator will not supply sufficient voltage to fully charge the agm and then top up when at a powered site with the mains 7 stage charger? Estimated draw from the agm battery could be 50AH per day.
Opinions appreciated
regards Kc
Reply By: RV Powerstream P/L - Sunday, Nov 08, 2009 at 09:25
KC and Co
The problem I see is if you divide 20 into 200 and you use the AGM to get the capacity how far do you have to drive to recharge it.
Is the unit ignition activated so that it only works when ignition on and stops when ignition off or does it have a wide acceptance voltage of say 8-15V where it can flatten your battery.
The main benefit of DC/DC charging from an alternator is to use all the available spare amps the alternator can produce to charge the aux battery as high as possible in the shortest run time.
Currently there is only one manufacturer that can achieve the above and that is Sterling Power Products of the UK whether it is by Alternator Smart Regulator, Alternator to Battery Charger or Battery to Battery Charger they are all DC/DC chargers.
If your alternator can produce 50A spare capacity why would you choke this capacity by installing a 20A charger.
The small capacity DC/DC chargers are only better than a correctly cabled cable only system when the resistance of the battery limits the alternator to below the capacity of the charging unit.
Ian
AnswerID: 390444
Follow Up By: kcandco - Sunday, Nov 08, 2009 at 18:22
Thanks Ian please see my last post
regards Kc
FollowupID: 658287
Reply By: ABR - SIDEWINDER - Sunday, Nov 08, 2009 at 09:52
Hi Kc
From what I can see on the only pdf file I can find is there is no ignition control. Dc20-pj
This would mean you would still need to fit a dual battery isolator and cable capable of carrying 30A continuously over the distance.
These DC2DC chrgers are becoming very popular and is fast becoming one of our best sellers in our 30A unit. (with ignition control).
The problem we are seeing is that many manufacturers are controlling output voltage of the alternator down to as low as 13.5V and this will never allow a battery to fully charge, it will slowly sulphate and loose capacity.
In your particular case you should test your alternator and if it produces 13.8V or more when hot then there is no need for a DC2DC charger as the 200ah AGM will accept closer to 50A and you would increase recharge time by putting a DC2DC charger in the circuit.
The DC2DC charger is a good way to finish off the charge once the batteries are almost fully charged. IE: 80% or more when the alternator is delivering less than the output of the DC2DC charger.
I recommend to all my customers that they fully charge their batteries on a mains charger when they get home from any trips or holidays.
Derek from ABR
AnswerID: 390448
Follow Up By: drivesafe - Sunday, Nov 08, 2009 at 14:14
Alternator voltages on new vehicles drop to as low as 13.2v and even at this voltage you can still fully charge ANY automotive battery.
Furthermore, batteries only suffer from sulfation when there is no chemical reaction taking place and this will only occur if they are left in a No Load / No Charge state for a period of time of up to 24 hours or more.
While there is any load or charge applied to a battery, there will be a chemical reaction and this will prevent sulfation from occurring.
FollowupID: 658261
Follow Up By: kcandco - Sunday, Nov 08, 2009 at 18:23
Thanks Derek and Drivesafe please see my last post
regards Kc
FollowupID: 658288
Reply By: RV Powerstream P/L - Sunday, Nov 08, 2009 at 10:45
The post by Derek says it all except with one exception even if the alternator is down to 13.5V the Sterling units will still do what they are designed to do smart charger the auxilliary battery correctly in the shortest time up to
14.1V 14.4V or 14.8V selectable to suit the batteries and with temperature control of the batteries being charged.
Ian
AnswerID: 390451
Reply By: Peter McG (Member, Melbourne) - Sunday, Nov 08, 2009 at 11:08
I use a Ranox 12v charger and it is terrific.
If you use 50AH a day then you will only need 2+ hours of driving
to fully charge. Check them out: wwwmranox.com.au
AnswerID: 390455
Follow Up By: drivesafe - Sunday, Nov 08, 2009 at 14:18
Being as these devices are a stage charger, it will take you far more than 2 hours to bring two 100 A/H batteries from an SoC of 75% to fully charged and if you read their site, they state this.
FollowupID: 658263
Reply By: Member - Phil G (SA) - Sunday, Nov 08, 2009 at 11:23
Kc,
I'm not in the business, and agree with Ian and Derek that you would be limiting current to your AGM and initially slowing the recharge.
What vehicle you have (and what voltage the alternator puts out are very important - they need to match your batteries.
For example, if you had a V8 100series, then the voltage might be a bit low - the heat under the bonnet will drop the alternator voltage and the cool AGM in the back doesn't get enough volts and hence not enough current to recharge. In this case an inline charger that upsizes the voltage to 14.4V would be useful.
Alternatively, if you owned a series3 Disco, the voltage might be too high and damage the battery.
I run a similar 3-battery setup to you - twin cranking batteries under the bonnet and 100Ah AGM in the canopy. My vehicle puts out 14.3 - 13.8 volts (depending on temperature), and I use the large 4Ga cable (both pos and earth) to the AGM, so it can easily manage the high current. I roughly measure current by measuring the voltage drop between batteries 1 and 3. And after playing around with a clampmeter, I find that with my wiring, a 0.01V difference equals 1 amp going into the battery. Its a simple way of knowing whats going on.
AnswerID: 390456
Follow Up By: kcandco - Sunday, Nov 08, 2009 at 18:29
Hi Phil Thanks and please read my last post. Your advise would be appreciated.
regards Kc
FollowupID: 658289
Reply By: drivesafe - Sunday, Nov 08, 2009 at 14:13
Hi kcandco, you pretty well hit the nail on the head. If you know your not going to be driving for more than a few hours at a time but look like using a fair bit of power while camped, then your alternator is easily going to replace more of the used battery capacity in the short time available.
These devices will fully charge batteries, but they need the time to do so. The very same thing can be stated about an alternator except that an alternator has one huge advantage over these devices. When you start your drive for the day, the lower the battery state of charge, the higher the current supplied by the alternator.
No matter how you charge your batteries, most people never drive long enough to allow any set to fully charge their batteries and with these devices, they just charge at a set current until the battery is about 85% SoC and then the charging mode charges and usually lower the charge current.
With an alternator, at the very time you need the most charge, when your batteries are at there lowest, an alternator will deliver the highest possible charge current, so you will replace the greatest amount of used capacity in the shortest time and all you need is decent sized cable.
BTW, for these devices to work at full efficiency, you still need decent size cable.
The only device I know of that can come close to what an alternator can do, is the Sterling gear, but at a price.
AnswerID: 390464
Reply By: RV Powerstream P/L - Sunday, Nov 08, 2009 at 15:41
What drivesafe has said is also correct with one exception the Sterling equipment gives the charge to the battery at the recommended charge voltage which is the fastest way to charge a battery so the come close part is with the Sterling leading and the alternator playing catch up as the Sterling has equipment to cater for up to a 300A amp alternator.
Efficiency does come at a price and it depends on you if you are happy to drop to 50%soc and recover to 75% or 80% state of charge and work in that range do not waste your money on other than a correct sized direct cable setup and this is dependednt on how far you travel.
If you want to increase your useable capacity and lenghten the life of your battery use a system that gives you the maximum power in the shortest time with the help of the spare alternator capacity.
Ian
AnswerID: 390476
Reply By: kcandco - Sunday, Nov 08, 2009 at 18:20
Thank you everyone. your answers have really helped. I am overwhelmed with your response. I am pretty sure I now intend to go with charging via the alternator only and do a top up at home or caravan park as available. I measured voltage at the main battery as 14.3v and at the auxiliary battery at 14.2v which is about 1 metre from the main. This was with the engine at normal operating temp after a few minutes drive. Due to the size of the agm battery (65 kilos 55cm x 25cm x 25cm) I have to mount it away from the engine bay and will end up with about 3 metres x 2 = 6metres of cable to do the round trip from the main to agm battery and return. The cable i have at present is DSE W 2302 (630/.12mm) which I believe is approximately 13 square mm in cross section. At the distance of 6m (2 x 3) at 50amp I calculate a voltage drop of .4 volts. I think this is a bit on the high side. Again I would welcome your opinion.
regards Kc
AnswerID: 390489
Follow Up By: drivesafe - Sunday, Nov 08, 2009 at 19:37
Hi kcandco, be careful when calculating voltage drop.
To do it properly, you need to workout the highest current load when the battery is at it’s lowest and then this will give you a worst case scenario but as the battery charges, the current load will reduce and the voltage drop will reduce accordingly.
So after a few hours driving, you will probably find that your batteries are well on their way to being charged and the voltage drop will be minimal.
let us know how you go.
FollowupID: 658297
Follow Up By: Member - Phil G (SA) - Sunday, Nov 08, 2009 at 19:52
Kc,
Your alternator's regulated voltage is fine. You'll find that the voltage drops a bit as the underbonnet temps increase.
Voltage drop is proportional to how much current is actually flowing through the cable. So if your batteries are full,there is very little drop, if your AGM is down, then it will draw a heap of current from your alternator and the voltage drop may be a lot. I expect that you've measured voltage drop with fully charged batteries which doesn't tell you a lot.
The cable you have is approx 9Ga or 7.1mm sq (according to DSE website). It is not adequate for a 200AH AGM that is 3 metres away. I originally used 8Ga cable for my 100Ah AGM in the canopy (4metres) and found that when the AGM is discharged and draws a heap of current from the alternator, the voltage drop was about 0.8V. So the small cable restricts the current going to the AGM. I upgraded the wiring to 4Ga and the AGM recharges much quicker. With high currents, you need a good earth which goes back to the motor. Simplest way is to run a thick earth cable back to the cranking battery neg terminal. With all that battery power, you also need to be sure you won't get a short circuit with that thick cable. Plenty of conduit and well anchored cable is the way to go. I also like to use fusible links at each battery pos terminal, but most don't do this.
FollowupID: 658303
Follow Up By: RV Powerstream P/L - Sunday, Nov 08, 2009 at 20:40
KC
The following may be helpful.
3m of 4GGe cable @20A gives 0.102V Drop
30A 0.152V Drop
40A 0.204V Drop
50A 0.255V Drop
60A 0.306V Drop
0.1 Volt Drop is recommended for maximum efficiency of a charging circuit.
Ian
FollowupID: 658318
Follow Up By: Member - Phil G (SA) - Monday, Nov 09, 2009 at 12:57
Thanks for the numbers Ian. A fusible link at each end will bump it up a little too. So if Kc has 14.3V at the cranking battery, he might have 13.9V at the AGM if it were sucking 60amps, so I guess thats still a healthy figure.
FollowupID: 658367
Follow Up By: kcandco - Monday, Nov 09, 2009 at 20:30
Hi Guys
OK I've decided after your valuable assistance to go for 4 guage cable. My alternator is rated at 90 amps and am working on a suggested 50Amp as a possible charge rate to the agm. I have a VDO ampmeter rated to 60 amp so am considering wiring that into the circuit in a good spot so I can read the charging rate on the move with nearly no increase in the cable length. I figure this will also give me an indication of the soc. I already have a 100A fuse at one end of the wiring so will place another at the + of the agm just in case of a short. Once I get this running I will do some tests and post the results.
regards Kc
FollowupID: 658422
Follow Up By: Member - Phil G (SA) - Tuesday, Nov 10, 2009 at 16:39
Kc,
I like to keep things simple, then there's less that can go wrong. I'll assume your VDO ammeter is one of the 60-0-60 ones that are fitted in-line and do not require a shunt. I wouldn't use it because it can be a source of failure and may add resistance to a high current circuit. A digital voltmeter set up via an on/off/on switch to measure voltage at each battery, will give you better information, and as I mentioned before, the difference between the two voltages will be proportional to how much current is flowing through the cable (just like a shunt ammeter).
A decent fuse should work fine but be aware of the potential problems - fuse holders can develop corrosion, which may lead to resistance and heat. Also, depending on the type of isolator, if cranking current can be drawn from the AGM, you may blow the fuse on startup. Fusible links are my preference.
FollowupID: 658585
Follow Up By: kcandco - Wednesday, Nov 11, 2009 at 16:11
Thanks Phil
fusible link it is, and ampmeter now looking dodgy. It would actually be easier to wire in the voltmeter as you described so that would make my life easier and be a job for another weekend. Hoping to make a start this weekend. Would it matter what size wire I run to voltmeters? I am thinking no.
regards Kc
FollowupID: 658705
Reply By: Member - Mike DID - Sunday, Nov 08, 2009 at 20:39
"I am considering setting the new agm battery up in the car or camper trailer and have seen the DC20, PROJECTA 3 Stage Automatic 12V to 12V 20Amp Battery Charger in the auto shop."
Why ? What benefit were you hoping for compared with Alternator-only charging ?
AnswerID: 390520
Follow Up By: kcandco - Monday, Nov 09, 2009 at 19:50
Hi Mike
My gut feeling was that alternator was the way to go but didn't want to make a commitment without some advice first. that is the beauty of this forum. The aim was to get as close to a full charge in the least amount of time with least expense. I'm easy to please eh.
regards Kc
FollowupID: 658415
Follow Up By: drivesafe - Tuesday, Nov 10, 2009 at 08:19
Hi again Kc, even if you had decided to fit some form of step up device, you would still need decent size cable to get it to work properly.
So by fitting a proper cable set up first, you can then make up your mind if you need any additional assistance and as most people do not use anything more than a adiquate sized cable set up, I think you will find this will also meet your needs and save you a bundle.
Time will tell.
FollowupID: 658507
Reply By: Member - Matt M (ACT) - Monday, Nov 09, 2009 at 16:03
KC,
Just cast your research net a little wider before coming to your conclusions is all I suggest.
Matt.
AnswerID: 390613
