What to use for a fridge cover?
Submitted: Tuesday, Oct 27, 2009 at 22:14
Road Warrior
Hi all, I'm making a insulated cover for my
camp fridge (3-way) and I have scored some wall insulation material from a mate which will be ideal to use as the 'sandwiched' layer. How I envisage this is that the actual insulation will be sandwiched between a piece of canvas or something each side.
Question is - should I use canvas or something else?? I don't know what those Engel transit bags are made from, but I will be making something along those lines to cover the sides and top of the fridge. Should improve the efficiency of the little 3-way a bit.
Reply By: dbish - Tuesday, Oct 27, 2009 at 22:26
Hi Road Warrior I made an insulated cover for my Waeco, outer layer white vynel canvas inner layer I used an old sleeping bag for the insulating material, just sewed the two together worked for me.
389047
Reply By: greybeard - Tuesday, Oct 27, 2009 at 23:03
at various times i've used polystrene foam, blanket and a pillow on top :)
whatever you use, just make sure you keep the air vents clear ( and allow some room around the air vents from adjacent 'stuff' ). and keep the direct sun off any part of the fridge.
if you use a pillow, after it's been running for a couple of hours, stick your hand between the pillow and the top of the fridge. it's very noticable how much insulation the pillow provides and how cool it is.
certainly proves the insulation properties lacking in most fridges.
389057
Reply By: Maîneÿ . . .- Tuesday, Oct 27, 2009 at 23:20
I made a 1/2 cover for the front and one side of my fridge from the front and back of a large coolite box.
I covered the coolite with canvas from an old tent, you can't use some contact adhesives to attach the coolite to the canvas, that is why it only has one side now, it eats up (dissolves) the coolite grrr.
I then made a lid cover the same way that sits over two edges of the lid so it stays in place when driving and because my fridge has two different height top surfaces it was made to cover them both, now the surface is level so can be used for many things.
It's there to protect the frontal area from things that get thrown up against the fridge from time to time.
Maîneÿ . . .
389059
Reply By: Trevor R (QLD) - Wednesday, Oct 28, 2009 at 09:17
What about making the outer layer from sunsheild reflector material? Don't know how easy this would be to sew with but it does the same job you will be asking the fridge cover to do, so should be appropriate.
Cheers, Trevor.
389081
Reply By: Fatso - Wednesday, Oct 28, 2009 at 09:58
I have a trailblazer.,My son has it out in the sun in the back of his ute somewhere at the moment. I is probably covered in dust.
That works fine.
389087
Follow Up By: Maîneÿ . . .- Wednesday, Oct 28, 2009 at 16:39
does it still look like it's brand new ??
Maîneÿ . . .
656833
Follow Up By: Fatso - Thursday, Oct 29, 2009 at 14:13
No
656970
Follow Up By: Fatso - Thursday, Oct 29, 2009 at 14:31
14 years old.
Been knocked around in utes, wagons, trailers & the back deck of our boat.
Been used to sit on,
cook on, carry stuff on, cut bait on & fillet fish on.
Been washed down with salt
water.
Been chafed by swags,
camp ovens & all sorts of
camping gear. Definitely no decals on this baby.
Even has rings worn in the bottom of it from when a mate flogged it to
Cape York & back in the back of his ute. (won't lend it outside the family after that)
It does not have a temperature gauge or any other fancy dials.
It has never failed to keep food & drinks cold.
It has never had assistance from a protective cover.
It has never had a repair.
It is not pretty.
656975
Reply By: qubert - Wednesday, Oct 28, 2009 at 10:10
go to clark rubber or upholster and gey some of that silver insulation material,(silver coverd foam) comes in 10 15 or 20mm thickness, cut out your shape and rut together with velcro so you can dissmantle it easy
389088
Follow Up By: qubert - Wednesday, Oct 28, 2009 at 10:11
dont cover the vents of the condenser or the fridge wont work!!!
656807
Reply By: Member - Phil G (SA) - Wednesday, Oct 28, 2009 at 12:05
I have insulated two engels with the high density foam floor mats (pack of 4 600x600mm). Costs about $20 from Bunnings, or you can get them at some
camping shops. I used contact adhesive to glue them to the sides and underneath of the fridge. They look pretty good.
The other thing I used to do in the old days with the 3-way fridge was to cover the fridge with a wet towel in the heat of the day.
389096
Follow Up By: Member - Phil G (SA) - Wednesday, Oct 28, 2009 at 20:44
Here's two photos:
Image Could Not Be Found
656859
Follow Up By: Member - MUZBRY(Vic) - Thursday, Oct 29, 2009 at 05:28
Gday Phil
That looks good.
I'll have to go and look in my stock shelves and make one for myself.
I might glue the foam to the inside of some 3mm leather and sew it all together.mmmm now you have got me thinking.
Murray
656908
Reply By: Road Warrior - Wednesday, Oct 28, 2009 at 12:13
Thanks people. Looks like a trip to Clark Rubber may be in order.
389097
Reply By: workhorse - Wednesday, Oct 28, 2009 at 19:05
Used one of those dense foam yoga mats cut into pieces, protects the casing as
389142
Follow Up By: qubert - Thursday, Oct 29, 2009 at 09:59
and its easy on the mind and soul too
656926
Reply By: trainslux - Thursday, Oct 29, 2009 at 14:58
When I used an older brown chescold 3 way.
I wrapped it in the 25mm white packing foam, just used hot glue to encase it sides, base, and top was removable using stick on velcro tabs around the top.
As the foam is pretty prone to impact damage, and having bits of it come off, I wrapped it in clear packing tape, so it was very durable, and easily fixed if needed.
This transformed the 3 way, as previously I could feel the sides get very cold on the outside when it was on 240v, showing the lack of insulation.
Trains
389259
