adjusting a 100 ser hand brake ?
Submitted: Friday, Oct 23, 2009 at 21:13
Member - Johny boy (NSW)
Hi all,
I seem to find it difficult to adjust the Handbrake on my 98 mod 100 ser diesel
I thought I had it right but now the handle comes right up and wont hold on a
hill ,has anyone else experienced this ??
Reply By: Member - Andrew L (QLD) - Friday, Oct 23, 2009 at 22:05
How were you adjusting the handbrake..?
I think there was a thread covering this a while ago.
Lcool website may have some info.
388449
Reply By: GerryP - Friday, Oct 23, 2009 at 22:39
Hi John,
They are a real PITA. However, make sure you adjust at each rear wheel to make sure the shoe travel is correct (minimal). There are adjustments at the handbrake and also under the vehicle which normally do not need adjusting - all these do is adjust the cable length.
As mentioned above, do a search as there was a previous thread with lots of hints and detail (I tried to find it - hope you have more luck than I did!!).
Gerry
388457
Reply By: Member - Phil G (SA) - Friday, Oct 23, 2009 at 23:03
LCOOL Link
388462
Reply By: Voxson - Friday, Oct 23, 2009 at 23:06
Easy really...
Take rear wheels off and look straight at the bottom of disc area and you will see a rubber bung... "bottom remember"...
Remove that bung and look in with a torch and you will see a little thumb-wheel with teeth on the outside..
Put a small screwdriver in there and wind it from the bottom-up until it stops turning,,, it wont take much,,, maybe four or five little cranks..
Then once it has stopped turning in the up direction,,, turn it in the down direction 2.5 - 3 little cranks.. and it will be awesome..
388463
Reply By: The Lobster - Saturday, Oct 24, 2009 at 01:16
You do realise that landcruiser hand brakes are only a cosmetic feature. They have no actual practical use. Even if you do manage to tighten it up, it will loosen within a few weeks. Just so you know.
There are mods you can do to improve the hand brake (ie make it last longer than a few weeks, maybe a few months). It's posted somewhere on LCOOL, but from memory it involves fabricating a new a part. So I personally couldn't be bothered.
matt
388466
Reply By: disco driver - Saturday, Oct 24, 2009 at 02:02
Seeing that it's still Friday here in WA perhaps the following will solve the now notorious Tojo handbrake problem.
Take a block of timber about 12" (300mm) x 4" (100mm) x 4" (100mm). Drill a 1/2" (12mm) hole through one of the 4" (100mm) ends. Insert a 7' (2metre) lenght of cord and tie it on.
To use it, open drivers door, lean out and with practice you can swing the block to land the said piece of timber either in front of or behind the front of rear wheel, as required, on that side.
Allow the vehicle to roll up to the block, thus preventing the vehicle from moving. Leave the vehicle in gear as an added security. Tie the other end of the cord to the steering wheel so you don't drive off and leave it behind.
To drive off, start the motor, place in either 1st or reverse as necessary and creep the vehicle away from the handbrake block. Pull on the cord to retrieve the hand brake before driving away.
This method does away with the necessity of crawling under an oil dripping motor vehicle to adjust a totally ineffective handbrake..
The block can also be used as a jackpad to place under the jack when extracting said vehicle from bogging experiences.
LOL
Disco.
388470
Follow Up By: Member - Johny boy (NSW) - Saturday, Oct 24, 2009 at 07:20
My God Disco,
I could hardly pick myself up from the floor due to my fit of laughter and I'm sure that all that typing was worth the effort ...as you can see from all the supporting responses,mate do you still work as a comedian or are you retired due to everyone taking you for a joke !!
NAHH just kidding mate I had a chuckle and don't worry the 4x2 might be an option??
Cheers.
656107
Reply By: Ozhumvee - Saturday, Oct 24, 2009 at 07:27
Not really funny, I know of two 100 series locally that have rolled away after being parked at the top of the drive while the driver checked the mailbox, both written off!
Never
park a Tojo without applying the handbrake and putting it in gear with the engine off!!
388475
Reply By: Member - Nick (TAS) - Saturday, Oct 24, 2009 at 13:08
Ok, I must have a good one(not that there is a bad Cruiser) but I have owned ours 4yrs, adjusted the hand brake once and it works great.Always has.
Even after our last trip, 13500kms of mostly dirt and corrigated roads, its still good.
388503
Follow Up By: Member - Phil G (SA) - Saturday, Oct 24, 2009 at 13:25
I agree with you Nick. Never had a handbrake not work and I'm now on my 4th Toyota that has the drum in disc rear handbrake. But I do my own servicing. I'm sure service people are either too lazy to take the rear wheels off and do a drum adjustment, or they don't know Landcruiser
well enough to realise that you only let them off by 3-4 notches.
656134
Follow Up By: Fatso - Saturday, Oct 24, 2009 at 18:07
Sandy
water crossings have caused a lot of problems with cruiser wagon handbrakes in the past. Most 80 series cruisers used to run out of handbrake before they got to
Bamaga. Seems sand used to get in & it wears down the pads in the drum.
Not too sure if it has changed for the later models.
I heard that one of the coppers on the Peninsular would get cruiser owners returning to test their handbrake if they got smart to him. This would nearly always end with a defected notice. If he liked you he wouldn't check your handbrake.
656169
Follow Up By: Member - Phil G (SA) - Saturday, Oct 24, 2009 at 18:38
Gday Fatso,
You'd still have to be using the handbrake a lot to cause it to wear. Maybe the linings were swelling and binding??? That used to happen on the rear drum brakes on 60series and Hiluxes. My daughter has a later series 80series and the handbrake is identical to
mine and the 105 series.
I wonder about Qld police sometimes :-)))
656172
