Big generator.
Submitted: Monday, Oct 19, 2009 at 20:34
ThreadID: 73150 Views:4214 Replies:9 FollowUps:2
Any recommendations for a generator setup to power a holiday house [off the grid].
Needs to be able to run most household appliances and a drill etc. automatic system....
No mains available. Not worth setting up a solar system just yet.
Reply By: Fred G NSW - Monday, Oct 19, 2009 at 20:44
Image Could Not Be Found
these should do the job...:-0))
Barkley Homestead
AnswerID: 387788
Reply By: Member - MUZBRY(Vic) - Monday, Oct 19, 2009 at 20:46
Gday
Talk to Cummins or GM . They have them in stock.
Murray
AnswerID: 387790
Reply By: Motherhen - Monday, Oct 19, 2009 at 20:54
How much do you want to run? Our Honda 2 does the job at home when there is a power failure.
AnswerID: 387794
Reply By: Road Warrior - Monday, Oct 19, 2009 at 21:03
So are we talking about a fridge, microwave, TV etc at well??
AnswerID: 387797
Reply By: Robin Miller - Monday, Oct 19, 2009 at 21:28
5KVA is really required Royce.
Also relatively cheap in petrol.
Diesels are good but getting expensive and like with cars not many are cost effective.
What I have found worthwhile is demand start types.
Robin Miller
AnswerID: 387802
Follow Up By: Member - Fred B (NT) - Monday, Oct 19, 2009 at 22:05
As an ex- sparky... I say ditto on the 5kva on demand type.
regards
Fred B
VKS 737: Mobile/Selcall 1334
FollowupID: 655389
Reply By: Member - Ed. C. (QLD) - Monday, Oct 19, 2009 at 21:39
For 10 yrs or so (from mid '70s - mid '80s), SWMBO & I lived in a farm house with electrickery supplied by a 3 KVA Dunlite alternator powered by a single-pot Lister diesel..
This was more than adequate to run separate 'fridge & freezer, + all of the usual kitchen appliances, incl. jug & frypan (though not necessarily all at the same time;-))
We actually made a point of using the jug (often;-) & frypan on a regular basis, in order to 'load 'er up'...
I'd be wary of getting more power than is necessary, on the basis that these things really need to be under pretty constant load to avoid bore glazing...
Our Honda EU20i comfortably runs everything we need to run here during the occasional black-out (though it doesn't like it if 2 'fridges try to start at the same time;-)
Regards...
Confucius say.....
AnswerID: 387804
Reply By: Member - Wamuranman - Monday, Oct 19, 2009 at 22:28
A 6 Kva is even better and will run pretty much the whole household.
Ours is Allight made in WA - they are well built, fully enclosed (can leave out in weather if necessary), have a lifting hook on top. Powered by 18Hp Honda -
very economical to run and has a large tank.
You see a lot of this brand sometimes around roadworks where they run all night for flood lights around new works (hence the name).
Here is a pic:
AnswerID: 387816
Follow Up By: Member - Wamuranman - Monday, Oct 19, 2009 at 22:31
I forgot to say it has two 30amp outlets - so you can work out how many things you can run at anyone time. Also has hour metre (helps to remember when service time is due, fuel gauge, safety switch etc).
FollowupID: 655396
Reply By: brushmarx - Tuesday, Oct 20, 2009 at 12:35
Iron Planet Auctions have a 8000 watt generator up for 5th November. Pick up Victoria. Dandenong?)
http://www.ironplanet.com.au/jsp/s/item/234903?h=2,NewSearch
No affilition etc, but I have seen some cheap prices on many items.
And it looks like its on wheels for mobility.
AnswerID: 387877
Reply By: paulnsw - Wednesday, Oct 21, 2009 at 06:13
First and foremost check the fuel consumption figures and then do some mental arithmetic and see how many $$$ these cost to run over 24 hours and 7 days. You will soon realise you may change your ideas fast how you are going to power the house and what size generator you end up with. If you put in a 12v fridge and cook with gas a suitable size solar system with government rebates could be attractive and use a 2kva for drill and other power tools.
AnswerID: 387992
