Air Compressor Check Valve
Submitted: Friday, Oct 02, 2009 at 20:49
ThreadID: 72712 Views:6640 Replies:4 FollowUps:4
Hi All
I have just fitted an air tank under the tray of my ute ,approximately 8 litres
capacity. The tank came of a small truck and is fitted with the usual relief valve.
My only reason for fitting this is to deliver a decent amount of air for reseating tyres. I have tested the tank for this purpose an it worked well.
Yeah I know that I can use the butane cyclinder and a match but burns can be painfull and where we travel a burn could be painfull for a long time.
Customers on our tours would also take a dim view of us setting a small explosion in thier $ 350 odd tyre.
My question to all of you learnard folk is do I need to fit a Check valve to the inlet on the tank or will the one in the compressor do the job. Currently I am using an ARB compressor which fills the tank in under 4 mins.
Thank you in advance for your well informed comments
Cheers Teza
Reply By: Member - Rob Mac (QLD) - Friday, Oct 02, 2009 at 21:33
Hello Tezza, my Boss system came with a check valve, and I have read somewhere that they are needed, cannot remember exactly why.
As a side interest, what make/brand is your slide on? I want to sell my canopy and awning and get a slide on box.
Rob Mac
AnswerID: 385521
Follow Up By: Member - Tezza Qld - Saturday, Oct 03, 2009 at 08:44
Hi Rob Mac
Thanks for your reply with the check valve, got it all sorted now.
In relation to the slideon I had it built in Maleny on QLD north coast. I saw it at a show on the sunny coast and unlike most other suppliers was more than happy to make any mods I wanted. Being made of ally built on a 25mm ally box
frames and being comprised of 5 seperate compartments means it is very light,240kg dry, your gear does't get thrown everywhere and to date I have had no issues with the structure or quality of the build. Canvas work was done by North Coast campers in conjunction with construction.
Mine has travelled just about everywhere, Cape, Canning,Simpson, Tassie you name it, no problems.
The man to contact is Darrell White in Maleny Ph 54 999250
He now markets them under Tray Tek Campers
I will try to upload photos to my profile but am really not computer savey but will have a go
Cheers Teza
FollowupID: 653163
Reply By: Richard Kovac - Friday, Oct 02, 2009 at 21:58
Teza
Yes fit the check valve as this will hold the pressurized air in the tank and will not allow it to drain back through the compressor, also the compressor will not have to start under full load if it drains between comp and tank.
Marks will do my spell checking.
Image Could Not Be Found
TXP International
Thanks GB
Richard
AnswerID: 385524
Follow Up By: Member - Tezza Qld - Saturday, Oct 03, 2009 at 08:12
Thanks Richard
Great drawing Will keep a copy in my files. I forgot about the compressor starting under load.
Cheers Teza
FollowupID: 653160
Reply By: Geoff (Newcastle, NSW) - Friday, Oct 02, 2009 at 21:59
Hi Teza,
In my opinion the fact that you've installed one between the compressor and the receiver is of more importance than its physical location.
They are fitted so that the compressor isn't starting against a full head of pressure on its exhaust valves. I believe you've well satisfied that requirement.
Geoff
Geoff,
Landcruiser HDJ78,
AnswerID: 385525
Follow Up By: Member - Tezza Qld - Saturday, Oct 03, 2009 at 08:20
Hi Geoff
Thanks for your reply I couldn't remember exactly why they were needed.
After seeing the drawing Richard posted for in his reply I wlii do all the plumbing as described.
Cheers Teza
FollowupID: 653161
Reply By: Michael ( Moss Vale NSW) - Saturday, Oct 03, 2009 at 09:37
Big Red Comprerssors have an internal check valve, my works well. I asume the ARB would also have one. Michael
AnswerID: 385548
Follow Up By: Member - Tezza Qld - Saturday, Oct 03, 2009 at 10:09
Thanks Michael With the ARB having a small tank to feed air lockers I would think it has an internal check valve as well Just to be on the safe side I installed a check valve near the tank as per Richards drawing. This also means that if my compressor stops working the tank can be filled directly through the outlet.
Cheers Teza
FollowupID: 653168
