Pajero Engine Vibration at 2200 RPM
Submitted: Tuesday, Sep 22, 2009 at 20:41
Blackass55
Hi team.
I understand that a few Pajero owners (like me) have had a problem with a harmonic engine vibration at around 2200 rpm.
well after spending a few thousand dollars and no suscess we have at last found the problem.
If anyone is still having this problem just make contact, it will cost you ten minutes of your time and a 14mm ring spanner.
Blackass55
Reply By: Member - Kiwi Kia - Tuesday, Sep 22, 2009 at 20:52
Can you give us a clue ? It may happen to me in the future :-))
KK
384255
Follow Up By: Blackass55 - Tuesday, Sep 22, 2009 at 21:00
the fellow team member is correct and tell all of our fellow Pajero owners the problem is the dampening weight that is bolted to the bracket at the rear of the automatic gear box.
Mitsubishi have just released a hotline alert to the dealers advising them of the problem.
Just remove the metal block from the bracket (not the bracket) the bracket is needed to protect the gearbox.
I was wrapted, it worked.
Happy hunting.
Blackass55
651985
Follow Up By: marq - Wednesday, Sep 23, 2009 at 07:23
Model?
Gen 4-1?
652023
Follow Up By: Blackass55 - Wednesday, Sep 23, 2009 at 20:06
Marq,
I believe / dealers are thinking that this problem is in the NM series on until
the block was removed by the manufactor in the 2007 mod.
I have been told that it only exists in the automatics, but who knows.
I will be looking what my options are with all the monet that I have spent with the dealer trying to locate the problem.
All the best Blackass55
652138
Reply By: happytravelers - Tuesday, Sep 22, 2009 at 20:53
The problem is the vibration dampening weight bolted to the rear of the transfer case. Pajeros built post May 07 do not have the weight fitted. Removing it fixes the problem, it's held on by two 14mm nuts.
384256
Follow Up By: Member - Kiwi Kia - Wednesday, Sep 23, 2009 at 06:51
Thanks mate.
KK
652021
Reply By: Member - Toyocrusa (NSW) - Wednesday, Sep 23, 2009 at 06:52
Hi. Don't think I would be too happy spending a "few thousand" dollars on a problem only to find it is some sort of manufacturer's design fault. Hope you have some sort of retribution. Bob.
384272
Reply By: Member - Oldplodder (QLD) - Wednesday, Sep 23, 2009 at 07:36
Are you talking of NB, NE, NF, NG, NH, NJ, NK, NM. NP. NS or NT?
I have a vibration/resonace at 2450 rpm, which is annoyingly at 95 km/hr in 5th.
Not at 2200 rpm.
Can't see weight you are talking about?
I have a 1996 NJ (early 96, not the later 96 NK) 2.8 turbo diesel manual pajero.
It didn't occur in my 2.6l petrol NB, 1986.
384277
Follow Up By: Member - Kiwi Kia - Wednesday, Sep 23, 2009 at 07:43
Mine is a 1999 2.8 TDi Auto. Ex Japan (winter version) Can anyone tell me what model that would be in Australia ? We don't use the model system in NZ.
I have a very slight vibration that I have not looked into yet, thought it may be drive shaft related due to having cranked up the
suspension a little.
KK
652029
Follow Up By: Member - Kiwi Kia - Wednesday, Sep 23, 2009 at 08:02
Ooops... make that a 1993 2.8TDi auto.
(got my vehicles mixed up, my Troopy is 1999)
KK
652030
Follow Up By: Member - Kiwi Kia - Wednesday, Sep 23, 2009 at 08:04
KK
652031
Follow Up By: Member - Leanne W (NSW) - Wednesday, Sep 23, 2009 at 08:07
Hi KK,
Try looking on the Pajero Club website - www.pajeroclub.com.au. The
forum may also be able to shed some light on your problem.
Leanne
652032
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Sep 23, 2009 at 08:07
99 I think would be NL, if it is the generation II shape like
mine.
Gen 1 was 1984 to 1989, gen II 1990 to 1999, gen III (NM, NP), the weird one with the big guards :o), to late 2006 (?) , when the NS came in. Current model is the NT, from late last year.
My vibration/resonace occurs at the same revs in each gear, so is engine related.
652033
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Sep 23, 2009 at 08:11
Trying to keep up with you. :o)
93 most probably is NH, first of the gen II, or it might be early NJ being 2.8.
The 2.8 diesel didn't arrive in OZ until 94, and manuals only.
652035
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Sep 23, 2009 at 08:14
Forgot to add, gen I - NA to NG, gen II - NH to NL, from memory, open to correction.
652037
Follow Up By: Member - Kiwi Kia - Wednesday, Sep 23, 2009 at 10:04
Thanks guys,
Thanks for the pointer to the Pajero web site Leanne.
Oldplodder, Looks like
mine could be a NH. Will you have your Pajero at
St George ? I am comming over on Sat so see you there if the viz is more then a few metres :-))
KK
652061
