lifespan of clutch
Submitted: Wednesday, Sep 16, 2009 at 13:45
Gossy
What would be the average lifespan of a clutch for my vehicle?; GQ 2.8td.
Reason I ask is I have 248,000kms on the clock and most of the last 70,000kms has been hard km's (2nd hand so not sure for the km's before that). Some chewing up the Simpson dunes, climbing the flinders etc etc whilst most of those km's is carrying heavy weights to get to
places.
Doing the Canning next year so quite willing to spend $1200 on a new heavy duty clutch but only if I have to.
BTW, there is nothing wrong with the clutch now but just looking at this for prevenative maintenance. If most clutches go between 250-300 then it's out of there! If they last 1,000,000kms then no problem.
thanks,
Reply By: Michael ( Moss Vale NSW) - Wednesday, Sep 16, 2009 at 14:18
I have the same problem, my GU 4.2 has 280,000ks and still ok and original, but when???
My old 1999 GU 4.2 had the clutch changed recently at 380,000ks and towed a horse float constantly!!! Some clutches only last , as you said 70,000ks and never had a hard time.. Michael
383368
Reply By: Member - Troll 81 (QLD) - Wednesday, Sep 16, 2009 at 14:51
My factory GU clutch lasted till 160k then a heavy duty went in cost was around $1300
The factory clutch in the Subaru Outback just went on 115k and that's $3600......ouch
Both cars was purchased second hand so don't really know what sort of life it's had before then but I am expecting the GU clutch to be good for another 100k or so
A mates GU factory clutch went at 170k so seems to be around that range
383370
Follow Up By: Gossy - Wednesday, Sep 16, 2009 at 15:08
$3600. Ouch.
Around the $1300 I have been quoted for "Xtreme" heavy duty clutch also.
160K and 170K is fairly consistent and considering that I have 248K it's probably worth serious consideration to replace.
I noticed on the net there is an abandoned new looking Pajero on the
Canning Stock Route because of a burnt out clutch. Don't want to be that person Aug next year!!
Next challenge is to convince the wife that a clutch is more important than flowers!
651009
Follow Up By: Member - Troll 81 (QLD) - Wednesday, Sep 16, 2009 at 15:13
Yea they have a dual mass flywheel that's made out of gold
651010
Follow Up By: Member - Anthony G (ACT) - Thursday, Sep 17, 2009 at 08:21
Gossy, if its the Pajero stuck between two dunes, its not a new one. An attempt was made to recover it, with a draw bar made up and taken in.
But in the end the cost of recovery was worth more than the Pajero, so the owner left a note, if anyone wanted the remaining fuel help themselves.
651098
Follow Up By: Gossy - Thursday, Sep 17, 2009 at 08:55
poor buggar. Could happen to any one of us :(
651105
Reply By: Member - joc45 (WA) - Wednesday, Sep 16, 2009 at 15:05
My GQ (Mav) TD4.2 went for 250k before I sold it, still ok. My GU clutch only lasted 200k.
383371
Reply By: Member - Duncs - Wednesday, Sep 16, 2009 at 15:08
I had a rear main seal in my GQ fail at 248,000kms this filled the clutch with oil and forced me to replace it.
The plate had maybe 5,000km left on it. My vehicle, like yours, had been purchased second hand and had worked hard off road in my hands and at the hand of the previous owner. Before I left
Sydney for that trip I checked everything, but how do you check the clutch? I relied on that great Australianism "shell be right"
well she wasn't.
I was lucky. Rain had forced us to modify our travel plans and I was leaving
Broken Hill when the clutch started to slip. If it had not been for the rain I would have been in
Innamincka when the trouble hit.
Compare the cost of replacing the clutch say 500km south of
Halls Creek to replacing it at home. I know what I would do. And while the spanner man has his head in that part of the world get him to check the rear main oil seal too.
Duncs
383373
Follow Up By: Gossy - Wednesday, Sep 16, 2009 at 15:15
Yep good advice. It's easy to keep spending on our beloved cars but realistically we need to be careful on what we spend on. Sometimes it means fixing what is already broken and sometimes it's spending money on something for piece of mind (harder to justify!!).
651011
Follow Up By: Bryan (WA) - Wednesday, Sep 16, 2009 at 15:47
Hi Duncs,
thanks for mentioning the rear main oil seal as my GQ4.2EFI is at 270,000Km, and Ive just noticed an oil weep starting to come form the bottom of the clutch housing drain plug.
While I dont have any clutch shudder unless Im doing alot of stop/start towing the camper, it looks like I have some money that I need to throw at my trusty old Patrol.
regards
Bryan
651018
Reply By: DIO - Wednesday, Sep 16, 2009 at 18:19
I guess that you really need to weigh up the cost now or the inconvenience of it failing on the Canning plus the ADDED expense there, (recovery etc. (ouch).
383387
Reply By: obee1212 - Wednesday, Sep 16, 2009 at 19:18
I reckon it's a piece of string and how the clutch has been or not been abused. Four wheel drives are basic ly (most of them) commercial spec and built to take a hiding. Most of us hardly make them work at except for the odd occasion.
Reminds me of the bloke I knew who drove an automatic with one foot on the brake and other on the accelerator and wondered why he spent so much on brake pads.
Owen
383401
Reply By: Member - Phil G (SA) - Wednesday, Sep 16, 2009 at 20:04
"Peace of Mind" will cost you money.
There is no way of knowing what's left on a 248,000k clutch without removing it. The Canning is a long trip which can be hard on the clutch, so replacing it sounds like a good option.
We came across a Pajero on the Canning in 2007 with 230,000k on the clock - it was abandoned because the clutch failed and the owner decided to cut the losses
383416
Reply By: Gossy - Thursday, Sep 17, 2009 at 08:56
thanks to all. The more I read the more convinced I am that I will replace the clutch before the trip.
Thanks, all
383481
