Which is best: stiff or flexible chassis
Submitted: Monday, Jul 27, 2009 at 17:02
Bandicoot
There seem to be 2 schools of thought regarding chassis stiffness for good off-road 4WDs. One school says stiff rigid chassis is best; the other says a more flexible chassis is best.
Is there any "consensus" out there?
Bandicoot
Reply By: RobAck - Monday, Jul 27, 2009 at 17:48
No there will not be consensus. Particularly given that "stiffness" is an open book. There will be a group who say that a set of chassis rails and beam axles is the only way to go. Then there is the group who will say a monocoque, vis Pajero and others, IFS all round and great traction control systesm offers the same amount of capability. So they are the two opposite poles or camps I suspect
It also depends on what you mean by stiffness. If you are chasing maximum off-road traction then beam axles on coil springs gives you that and there are plenty of vehicles in that
camp. LR Defender, Nissan Patrol etc all with chassis rails. But a
well driven anything with either a monocoque or rear beam axle and IFS with our without a chassis rail will go a very long way off road as
From a purely engineering sense a high level of rigidity in a vehicle is not good. Overall any 4WD must have a degree of body flex or it will fall apart. This is accomplished by rubber engine mounts and chassis mounts etc
RobA
376440
Reply By: Member - Shane D (QLD) - Monday, Jul 27, 2009 at 17:53
Stiff.
IMHO Its OK to have a flexible chassis, as long as everything around it flex's with it, take a ute for example, will the body flex like the chassis will?,what happens if the chassis "out flex's" the body?
The company I work for had quite a few problems with this on garbage trucks and was never fully resolved, new trucks are now spec with double chassis to make stiff so it doesn't crack body's, causing them to leak.
This may not fully relate to 4WD wagons, but I personally rather let the
suspension bend, not the chassis.
Shane
376441
Reply By: jdwynn (Adelaide) - Monday, Jul 27, 2009 at 18:12
Can you define rigid? Unimogs are designed to flex but I wonder if you’re talking more about monocoque Paj’s and the like.
Having been balanced on diagonally opposite wheels on many occasions, and done much snatch strapping over the years, and wanting to avoid cracked windscreens or a distorted chassis, a rigid chassis for me any day (assuming a ladder chassis Patrol qualifies as rigid by your definition).
376443
Reply By: Peter_n_Margaret - Monday, Jul 27, 2009 at 18:31
Depends on the rest of he vehicle and the
suspension design.
The Unimog has flex chassis PLUS long travel
suspension and is the best, but building a body on one is fraught with difficulties and constraints.
The Canter has a flex chassis and poor
suspension travel.
The OKA has a very ridgid chassis and good
suspension travel and off road performance between the other 2. It is the easiest to put a body on by far compared with the other 2.
Horses for courses......
(no bias) Peter
OKA196 Motorhome
376446
Reply By: Robin Miller - Monday, Jul 27, 2009 at 18:49
Flexible for me Bandicoot.
AS represented by the 80 series and GQ patrol chassis of the nineties.
The cruiser had hard steel , and I was shown the cracks that developed on a
mine unit around 1992 just before it was shipped back to japan.
Eye opening , and helped me go for the more flexible Patrol then.
376452
Reply By: Member - Timbo - Monday, Jul 27, 2009 at 20:16
I thought the chassis under my Jackaroo was too flexible as the bullbar shook around all over the place (relative to the car body) on rough roads, and it was too much for the IPF lights (despite the salesman telling me they'd be okay!). I've heard that chassis flex also makes fitting a bullbar difficult on the 120 Prados as
well (you need to ensure adequate clearance so the bullbar doesn't hit the bodywork). The upside of a more flexible chassis is that it isolates the cabin from a lot of the road noise (the Jackaroo transmitted very little road noise into the cabin) and makes for a more comfortable ride - let's face it, that's what most buyers of 4WDs want these days whether they're towing a caravan or dropping the kids at soccer.
Personally, I think I'd like to have a stiffer chassis on my next car, but I'm not really sure how to find out what is stiff enough, and what isn't?!
376471
Reply By: Flywest - Monday, Jul 27, 2009 at 22:10
Avoid the complete monocoque
shell construction 4wd's then - no stiffness at all without the little blue pill! ;o)
376505
Follow Up By: turbopete - Tuesday, Jul 28, 2009 at 09:59
the early cherokee,s etc were so flexible their doors opened under some circumstances
643937
Reply By: Member - ross m (WA) - Tuesday, Jul 28, 2009 at 20:23
Ive never seen a rigid chassis on any 4wd. Sure ,some may have more rigidity than others,but they all flex.
Even some of the monocoques like the Pajero can flex a fair bit.
376600
