What are your best tips?
Submitted: Friday, Jun 26, 2009 at 13:32
ThreadID: 70168 Views:7412 Replies:23 FollowUps:17
As you are no doubt aware, we have a section on the Home Page (bottom right) that lists, at random one "Tip" or "Fact" from our Tips & Facts database. This content, whilst interesting as is, could be expanded to include new/additional tips and facts and I thought you guys and gals would love the opportunity to be a part of that.
Rather than create a content management system for you to upload it automatically into the database, just submit your succinct "tip" or "fact" via this post and we can extract and put it into the database to share with others.
Just a bit of fun but this can be useful to other newbies - so now go on and share your best tip related to 4wding, camping, carvanning, bushwalking, travelling, packing, bush cooking, fishing, boating, outback photography, tyres, fridges, weather, navigation, recovery, communications, travelling with kids, etc, whatever!!
Thanks in advance,
MM
Reply By: Richard Kovac - Friday, Jun 26, 2009 at 16:01
Water saving when washing up, small bottle with hand pump water and detergent, spray dish's and wipe dry
AnswerID: 371961
Reply By: Member - Duncan W (WA) - Friday, Jun 26, 2009 at 17:32
Wrap eggs in cling wrap and put back in box. If the egg breaks it stays intact enough to use the egg.
Dunc
AnswerID: 371983
Follow Up By: Member - Duncan W (WA) - Friday, Jun 26, 2009 at 17:36
Old detergent bottle put some squirts of lotion in it. Fill with water. Good for hands and also dishes.
Have also had a 600ml shower using the bottle. Water goes exactly where it's supposed to go.
Dunc
FollowupID: 639252
Follow Up By: Member - Duncan W (WA) - Friday, Jun 26, 2009 at 17:37
That should read put some squirts of hand washing lotion in it.
Dunc
FollowupID: 639253
Follow Up By: Member - Timbo - Monday, Jun 29, 2009 at 12:42
Duncan, I'm interested in this one (not trying to have a go at you) but do you find you have to rinse off after 'showering' with the soapy water?
FollowupID: 639552
Reply By: Sir Kev & Darkie - Friday, Jun 26, 2009 at 17:50
My tip is to get a copy of the Camps Australia Wide book as it will save you heaps in the long run
Cheers Kev
Russell Coight:
AnswerID: 371991
Reply By: Member - Mick O (VIC) - Friday, Jun 26, 2009 at 17:59
4x4 safety tip. If travelling over corrugated roads and you have a powder extinguisher, trhe constant vibration will cause the contents to settle and pack down. Every couple of days, remove the fire extinguisher, invert it and knock it gently against your tyre to get the contents loose again. This ensures it'll work when you need it.
Mick.
AnswerID: 371994
Follow Up By: Member - Mike DID - Saturday, Jun 27, 2009 at 08:12
Always mount powder-type fire extinguishers horizontally to stop the powder compacting. Horizontal mounting allows the powder to move with vehicle movement.
FollowupID: 639315
Reply By: Member - JohnR (Vic) - Friday, Jun 26, 2009 at 18:41
Paper towels are great for minimising washing up water and fluids. A bit of water in the frying pan immediately after use and boil it will hugely reduce the cleaning effort there too.
AnswerID: 371996
Follow Up By: Welldone WA - Saturday, Jun 27, 2009 at 02:54
El Cheapo paper plates sat inside your normal plates greatly reduces washing up and also provides paper to start the fire with.
FollowupID: 639305
Reply By: equinox - Friday, Jun 26, 2009 at 19:15
When the constellation of Orion, or "the Saucepan" is high in the sky, his sword, or the saucepans handle points south.
AnswerID: 372001
Follow Up By: Jedo_03 - Friday, Jun 26, 2009 at 20:23
Good one Equinox..
Also...
The Southern Cross is in the south sky...
The right and left arms point (left) to a bright star abt one-and-a-half spans away.
This is Polaris...
Sits almost directly over south pole..
While all the other stars (inc Orion) are wizzing over our heads to sink in the west old Polaris just sits there and describes a tiny arc... So you always know due south (provided it's not cloudy of course...)
Jedo
FollowupID: 639275
Follow Up By: Welldone WA - Saturday, Jun 27, 2009 at 02:36
Jedo, nearly right but no cigar,
Firstly: "Polaris" is the pole star over the North pole [sometimes called the "Dog Star"]and can't be seen by us antipodeans in the southern hemisphere . We'd need X-ray glasses, face north and stare at the ground to see it from here;).
Secondly:The one you think is Polaris is in fact one of the "Centauris" [Alpha or Beta]
Thirdly:there is a pole star in the south [whose name escapes me] but it is so faint that it can barely be seen with the naked eye on a clear moonless night in the most remote part of the out-back. It is there, but you don't need it!
Fourthly: [This is the bit you nearly got right] To find south you'll need to do a tiny bit of geometry and "join the dots":-
To start, draw an imaginary line through the stars that make the "long" axis on the southern cross extending from the base [if it was on the flag, it would head to the ground] about 2 and a half times the distance of the stars of the long axis.
Next draw a line between the 2 brightest stars [Alpha & Beta Centauri] in the sky just near the Southern Cross, at the centre of this line draw another line at right angles [90degrees] to it heading in the direction of the first line from the Southern Cross.
Where these two lines intersect is where our very faint pole star resides and if you drop a line straight down form this point to the ground ; that will be true due south.
Failing that, use a GPS or heaven forbid, a compass! ;))
Now,where did I put my telescope?
Welldone
FollowupID: 639304
Follow Up By: Member - Vivien C (VIC) - Saturday, Jun 27, 2009 at 08:00
Welldone,
Ever since I went to Arkaroola and did the Astronomy Tour there I do exactly what you've described every night when I'm travelling outback....
Viv
FollowupID: 639312
Reply By: Bongo (Darwin NT) - Friday, Jun 26, 2009 at 21:12
Burn some turkey bush on your camp fire; the smoke repels mosquitoes.
AnswerID: 372017
Reply By: Welldone WA - Saturday, Jun 27, 2009 at 03:03
Make sure the shovel you use as an emergancy frying pan to fry your bacon and eggs on is NOT the same one that you dig the bleep ter with.
AnswerID: 372038
Follow Up By: Welldone WA - Saturday, Jun 27, 2009 at 03:10
bleep ter is a word that starts with SH and rhymes with "fitter"
FollowupID: 639306
Reply By: Member - Mfewster(SA) - Saturday, Jun 27, 2009 at 08:28
Never tell the wife
AnswerID: 372045
Reply By: Member - barry F (NSW) - Saturday, Jun 27, 2009 at 08:50
Re usable cable ties are great for keeping hoses etc. neat & tidy and are a handy item to carry in your tool box. You can usually find them in the gardening section of places like Bunnings.
AnswerID: 372046
Follow Up By: Troppo Tom (Virginia, N.T.) - Thursday, Jul 09, 2009 at 21:49
Visited Bunnings and have purchased a variety of reusable cable ties. Previously I have used many one time cable ties.
Thanks Barry you are a champ!
FollowupID: 641014
Reply By: Member - Mfewster(SA) - Saturday, Jun 27, 2009 at 10:32
A Clamp-it tool. I have seen them used in the bush to fix snapped roof racks, axe handles; even leaf springs. With one, you don't need to carry a collection of water/fuel/air hose clamps either. They are a little trickier to use than the online demo shows, but once you get the knack, fine. I always have one and a roll of wire in the toolbox when travelling. Small and light. Pretty cheap, but effective.
This sounds like I work for them, but I have no connection.
Check
http://www.practool.com/clamp-it-tool1.html
AnswerID: 372064
Follow Up By: Richard Kovac - Saturday, Jun 27, 2009 at 17:40
Mfewster
Yes great tool, I have one and is well used.
Prac Tools
FollowupID: 639370
Follow Up By: Member - Mfewster(SA) - Saturday, Jun 27, 2009 at 17:48
That's the little beauty Richard. Actually there are two sizes. I've got the small one. I think fixing broken leaf springs might have needed the big one. A pair of good wire snips so you can cut the wire close to the Clampit is also pretty essential with it.
FollowupID: 639374
Reply By: Member -Dodger - Saturday, Jun 27, 2009 at 13:57
When camped out and you are unable to sleep due to the heat.
Get a cheap spray bottle from a $2 shop fill with water and lightly spray your bed and your face plus any bare flesh just before retiring. This will help one feel cool whilst nodding off.
Many a time the wife and I have had a water fight with these .......it's fun.
Also a spray over the face when traveling will give a real cool when the air con vent is turned on you.
Cheers Dodg.
AnswerID: 372082
Reply By: Louie the fly (SA) - Saturday, Jun 27, 2009 at 14:58
Pack your car according to the terrain you're driving in. It's no good having the snatch strap and shackles packed away in the crate that's hardest to get to. Especially when the tide is coming in.
Carry spare tent pegs - you'll need them someday.
Louie
AnswerID: 372085
Reply By: Member - Alex B - Saturday, Jun 27, 2009 at 17:19
Fire Starters: Pieces of waxed cartons form your local fruit shop make great fire starters - even when wet. A lettuce box cut up into 10cm squares goes a long way.
Cheers.
Alex B
Enjoy everyday, make your own luck & help a few along the way.
AnswerID: 372102
Follow Up By: Member - barry F (NSW) - Saturday, Jun 27, 2009 at 17:49
I like that one, as there as no need to carry chemicals. I read somewhere a few days ago that used tea bags with a bit of metho on them is another good fire starter, but metho has limited usages & is pretty volatile. Cheers
FollowupID: 639375
Follow Up By: kimberleybloke - Thursday, Jul 09, 2009 at 21:51
used teabags soaked in diesel and kept in a jar/tin are very good firelighters.
FollowupID: 641015
Follow Up By: MobiCondo - Thursday, Jul 09, 2009 at 22:39
Oh you "fire bug & pyromaniac" :-) you are just like me and have the same really good clue the tea bags & diesel are superb!
Cheers - Mobi
FollowupID: 641035
Reply By: Member - Netnut (VIC) - Sunday, Jun 28, 2009 at 20:27
Spectacles Cleaning Kit
If travelling through or camping in a dusty environment, keep the soft cloth used to clean your spectacles in a resealable plastic bag. Wash spectacles well before cleaning to avoid scratching the lens.
AnswerID: 372246
Reply By: ExplorOz - David & Michelle - Monday, Jun 29, 2009 at 11:08
Great stuff everyone, keep it coming :-)
MM
AnswerID: 372293
Reply By: Welldone WA - Monday, Jun 29, 2009 at 16:19
If you have to use a chainsaw in the bush [for cutting fire wood or clearing fallen timber off tracks etc.] put your very portable, light and compact fine mesh mosquito/fly head net on, instead of using a bulky face shield that takes up lots of room, has no other use and fogs up on cold days. The net lets you breath easier, doesn't fog up, stops 99.8% of fine dust and 100% of flying chips, has more than one use and can be kept in your pocket . If you want 100% protection, put you sunglasses on first.
Foam Ear plugs also take up much less room than earmuffs and you can get a good nights sleep if other inconsiderate campers are snoring or partying on hard into the wee small hours. Karma is the chainsaw at dawn:))
AnswerID: 372328
Reply By: ExplorOz Team - Kerry W (QLD) - Thursday, Jul 09, 2009 at 21:25
If you are travelling with "not so young" kids who are always wanting to go off and explore, and want some peace of mind that they are safe, invest in a couple of cheap UHF handhelds specifically for them.
That way they can be playing out of sight while you cook, relax or do something else, they can call you if they need to.
You can check in with them when you want to.
Just a tip though - dont bother trying to catch a nap while they have a UHF in their hands, they can remotely sense that you have closed your eyes and they will call you 3 times every 5 minutes. Guaranteed!
Kerry W
Kerry W (Qld)
-Helen Keller
AnswerID: 373850
Reply By: Bretto (QLD) - Friday, Jul 10, 2009 at 08:34
Old camera film containers (the small cylindrical ones) are a great way to keep your laundry/shower money organised. They are the perfect size to store one dollar coins in. So if you fill one of them with one dollar coins and throw it in your glovebox before your trip, you'll never have to scrounge around looking for the right change.
AnswerID: 373892
Reply By: Von Helga - Friday, Jul 10, 2009 at 08:36
A slightly different idea for the spray bottles.
Before each trip I have one (600ml) that I put 2-3 capfuls of Dettol in and fill with water. I use it often during the day, generally as my hands get dirty, wiping down the benches, after toilet stops, handy to apply a little Dettol for those annoying nicks and cuts we get in ther bush, and the pressure of the spray flushes the wounds well.
Trevor
AnswerID: 373894
Reply By: Bezza - Tuesday, Jul 14, 2009 at 13:22
Keep hot water in the slow cooker (thermos) for morning hot drinks or for baths when travelling late.
We make hot water on the camp fire at night, put it into the thermos (slow cooker) to stay hot for the morning. It stays hot enough for hot drinks or requires minimal heating on the gas for the morning cuppatea. Saves a lot of gas and time.
AnswerID: 374489
Follow Up By: Member - Neville & Sally C (VI - Wednesday, Jul 15, 2009 at 13:28
Wet ones, both moisturising and disinfecting. Paper towels and newspaper. You can use newspaper to stand on to dry yourself in the shower and use it to put over dirty picnic tables, Then burn it, as well as the obvious firelighting, you can also put it over your windscreen at night if there is going to be a frost, you won't
have an icy window. There is also a new hand lotion out for washing & disinfecting hands no water required.. it smells great & leaves you hands feeling n
ice. Bye for now.
Take care SallyC.
FollowupID: 641853
Reply By: Tim HJ61 (WA) - Saturday, Jul 18, 2009 at 11:40
Shadecloth is great for covering the ground around camping kitchens to keep the are a bit cleaner and reduce sand getting into everything. It is also excellent under tents and at tent doorways and dirt falls through rather than sitting on the surface of a tarp. It rolls up to a bulky but light pack that doesn't matter if it gets wet whilst travelling.
AnswerID: 375036
Reply By: Tim HJ61 (WA) - Saturday, Jul 18, 2009 at 11:51
Choose map books with spiral binding
AnswerID: 375038
Follow Up By: Rolly - Saturday, Jul 18, 2009 at 12:55
Ah! Yes, indeed.
Especially if you're travelling alone.
FollowupID: 642326
