Engine Saver installation 02 GU 4.2 TD
Submitted: Tuesday, Jun 16, 2009 at 12:34
ThreadID: 69867 Views:2436 Replies:3 FollowUps:0
Afternoon all,
I have recently purchased the above two in one unit.
I have successfully connected the low water sensor however, would like to know where others have connected their temp sensor.
Any suggestions or photo's would be greatly appreciated.
Chris.
Reply By: Member - Rodney B- Tuesday, Jun 16, 2009 at 13:47
Chris
Recently fitted it to my 80 series LC and tried the temp sensor in 3 different places until I was happy with it. Suggest you keep it away from the exhaust system as the radiated heat registers on the sensor. I found a spot below my inlet manifold at the rear of the head which gives a better indication of the head temperature. Not familiar with the Nissan head but I am sure you will find a tapped hole somewhere on the head.
I found the unit is brilliant and does what they say (which is a turn up for a change).
AnswerID: 370309
Reply By: Member - Graham H (QLD) - Tuesday, Jun 16, 2009 at 23:09
Mine is on a tapped hole at the front of the head on a 100ser.
Was too hard to get it at the back of the head.
Engine runs at 78-82deg whilst towing nearly 3 tonne
There was some pics posted by Richard Kovac about a week ago that shows it on a Cruiser also.
AnswerID: 370434
Reply By: putrol - Wednesday, Jun 17, 2009 at 15:12
i put one in my gu but i bought the inline version & just an 1" out of the top radiator hose & slip it in very neat & easy to fit
AnswerID: 370513
