Hi All,
Had an old 9 kg gas cylinder in good condition laying around. What I needed was a portable air
tank to run the stapler and brad gun while doing odd jobs in the Goldstream Camper. I didn’t want to run long air hoses from my compressor, especially for a job that would take ten minutes.
I did a bit of research beforehand, and these puppies have a Test Pressure of 3 Mpa, or ~435 PSI to us folk. Mmmm, more than enough to make a compressed air
tank out of I thought, considering I’ll be only using it at 100 – 130 PSI. Moreover, a 9 kg cylinder has the volume of about 22 litres – about half the capacity of the
tank found on an “auto parts store” compressor.
I still wasn’t convinced, so I went to a website that listed pressures for LPG gas under pressure – just to be sure.
Well, I found out that LPG in a full 9 kg bottle at 30° C is ~145 PSI. And that’s easily achievable in a bottle left in the sun or similar. So there should be no dramas using compressed air.
So, all is good, and here’s my solution;
The trickiest bit was converting the gas POL fitting on the bottle, to BSP fittings that air compressors use. It turned out quite simple. I had an old POL hose, so I cut the end off it, and that gave me the connection that fitted into the gas cylinder valve.
I then tapped the inner portion of the POL fitting (the bit with the O ring on the end) with a ¼” BSP die (to about 10mm long), to accept a “T” piece as seen in the photo. I then screwed the “T” piece onto the POL fitting (with thread tape) and screwed it to the cylinder.
Image Could Not Be Found
Go to major hardware store and purchase some air fittings. How you set it up is your choice, but I did it like this;
On the top of the “T”, I added an open/shut valve and a male air fitting. This is where I charge the cylinder from the air compressor, via a hose.
Next, I added a threaded barb to the end of the “T” piece, and attached a short piece air hose (blue in colour in the photos), that in turn went to the Regulator/
Water Trap (Note: you don’t really need a Regulator, as the cylinder is only ever pressurised to what the compressor is set at – but I like gauges!).
On the output end of the Regulator, I fitted a standard Nitto female coupling ready to accept an air hose and the tool of my choice.
Apart from a coat of paint and a note saying “Compressed Air Only”, jobs done! I charge the cylinder to 130 Psi (this is Max limit recommended by the makers of the Regulator/
Water Trap), using the air compressor and then disconnect. The Regulator is set to 90 PSI (as recommended by the makers of the tools), and away I go!
Cheers, Matt
