How to stop netbook going into sleep mode when in moving map mode and not using
Submitted: Saturday, Jun 06, 2009 at 18:22
Member - G N (VIC)
Hi all
Just gave the netbook + moving maps a go and works great except it goes into sleep mode when no keys are used for 10 minutes or so.
Does anyone know how to change the setting so it will just stay "ON" until turned off manualy?
also is there anyway to turn the netbook on from the remote touch screen? (this is on a post a few back also)
GN
Reply By: DesF - Saturday, Jun 06, 2009 at 18:39
Hi, This is how you do it with XP
home & XP Pro, not sure of Vista , I have done it but cant remember the exact names, most are the same but may be called something else,
Start / Contol Panel / Display / Screensaver / Power / then set " Turn off Monitor" to " Never" , Then "Apply" / Ok / Ok.
Cheers Des.
368736
Follow Up By: Member - G N (VIC) - Saturday, Jun 06, 2009 at 18:52
Buety
Thanks Des F, will give it a go tommorrow
reagrds GN
636255
Reply By: farouk - Saturday, Jun 06, 2009 at 19:09
Hi GN, Just one more move, make sure you have NEVER in the bottom window ie System Hibernate
Colin
368741
Follow Up By: DesF - Saturday, Jun 06, 2009 at 19:28
No worries , yes I forgot to mention Never in the " Hibernate box.
Cheers Des.
636261
Reply By: Member - Graham H (QLD) - Saturday, Jun 06, 2009 at 20:05
do it like this
Control Panel/Power options
Set it as laptop and set ALL the L/H column to NEVER and you wont have any probs.
As long as you have it plugged in of course
368749
Follow Up By: Ozboc - Sunday, Jun 07, 2009 at 11:14
I have done this setting with my laptop also --- never had a prob since and used it in this mode for 1 year now
best to have the laptop on a charger also when in the car as it will use more power than if it was allowed to hibernate
Boc
636310
Reply By: Member - G N (VIC) - Saturday, Jun 06, 2009 at 21:13
Thanks you all for help, i will try the ideas tomorrow.
Many thanks GN
368752
Follow Up By: Member - Graham H (QLD) - Saturday, Jun 06, 2009 at 21:32
Try
mine first you wont need the others
I never turn it off and its always on in the morning after just sitting all night.
636278
Reply By: Wisey - Saturday, Jun 06, 2009 at 23:44
I had a good laugh at myself last week. I was watching a cycle training program, all set up, computer,
check,...... fan,
check, .........facing the right direction,
check, spinning on my training bike in the garage. This is great. Ok, 2 min fast and easy 1 min and so on .......................following the prompts....................................2 mins fast.................... phew isn't this 2 min up yet.........looking at the screen (blank mind you).........................wondering?.............time?................can't keep this pace up much longer...............
aahhhhhhhh, power saver....................... derrrrrrr................. off the bike and flick the mouse.................
nuf said,
saved by the missus for the rest of program, Honey can you come here for a sec? Just flick the mouse a bit. " Where to?" Ahhh... just anywhere
368767
Reply By: Member - Greg T (ACT) - Sunday, Jun 07, 2009 at 19:11
i use my netbook for moving maps etc, and find it also handy if you select it never to sleep, even when you close the lid.
368851
