Fuel Filter Toyota TDV8 changing of.
Submitted: Friday, Jun 05, 2009 at 17:37
ThreadID: 69539 Views:4374 Replies:4 FollowUps:4
Can anyone help, Ican't figure it out. Is it a cartridge or a spin on. If anyone can help thanks in advance.
Reply By: Gone Bush (WA) - Friday, Jun 05, 2009 at 18:02
Trev, there is a whole Thread on this on LCOOL.
If you click on this link:
http://www.lcool.org/forum/viewtopic.php?t=6072
you will go to the thread but you need to join first to read it. Well worth it, no cost.
AnswerID: 368577
Follow Up By: Gone Bush (WA) - Friday, Jun 05, 2009 at 19:24
Sorry Trev,
that link was about the OIL filter.
My mistake, cheers
FollowupID: 636149
Reply By: Member - Redbakk (WA) - Friday, Jun 05, 2009 at 18:16
Trev...do you luv your Troopy?
AnswerID: 368578
Reply By: Ino - Friday, Jun 05, 2009 at 19:33
Trevor - I have the manual here for the 1VD engine. I can PDF the section in question for you, if you let me know where to send it.
I'm reluctant to make it public - given the copyright and all. PM me and we'll work something out.
Ino!~
AnswerID: 368594
Follow Up By: Ino - Friday, Jun 05, 2009 at 19:47
arrghh! Member only facility! good-o!
Here it goes:
FUEL FILTER > REPLACEMENT
HINT:
When replacing the filter, use TOYOTA genuine parts or equivalent parts.
1. DRAIN FUEL FROM FUEL FILTER
Connect a hose to the drain cock. Place the other side of the same hose into a container.
Loosen the drain cock to drain fuel.
Tighten the drain cock.
2. REMOVE FUEL FILTER ELEMENT
Using a 5 mm hexagon socket wrench, remove the 3 bolts and disconnect the fuel filter cap.
Disconnect the clogging switch connector.
Disconnect the water level warning sensor connector.
Remove the fuel filter case and element assembly.
Remove the O-ring and retainer.
Using a screwdriver, remove the fuel filter element from the case.
NOTICE:
Do not damage the fuel filter element and case.
HINT:
Tape the screwdriver tip before use.
3. INSTALL FUEL FILTER ELEMENT
Install the fuel filter element to the case.
NOTICE:
Make sure that there is no foreign matter on the areas of the case shown in the illustration.
Install the retainer.
Install a new O-ring.
NOTICE:
Make sure the rounded side of the O-ring faces upward as shown in the illustration.
Install the fuel filter case and element assembly to the bracket.
Set the fuel filter cap.
NOTICE:
Make sure that there is no foreign matter on the areas of the cap shown in the illustration.
Do not turn the cap as the O-ring will be damaged.
Using a 5 mm hexagon socket wrench, install the fuel filter cap with the 3 bolts.
Torque:
4.5 N*m{ 46 kgf*cm , 40 in.*lbf }
Further tighten the first bolt tightened above so that its torque value is slightly more than the torque specification.
Connect the water level warning sensor connector.
Connect the clogging switch connector.
4. RESET FUEL SYSTEM WARNING LIGHT
Turn the ignition switch ON.
After turning the ignition switch ON, connect the clogging switch connector within 3 to 60 seconds.
Check that the combination meter's fuel system warning light turns off.
5. BLEED AIR FROM FUEL SYSTEM
Using the hand pump, bleed air from the fuel system until pumping becomes difficult.
6. INSPECT FOR FUEL LEAK
Start the engine. Check that leaking sounds, sucking sounds or other unusual sounds cannot be heard.
Ino!~
FollowupID: 636152
Follow Up By: Serendipity of Mandurah (WA) - Friday, Jun 05, 2009 at 20:11
Hi Ino
I have been looking to get a workshop manual for the vdj V8 but have not found who is selling it. I have not tried Toyota yet as I think they might be a tad expensive.
Where did you get yours and how much.
David
FollowupID: 636154
Follow Up By: Ino - Friday, Jun 05, 2009 at 20:53
Serendipity - any Toyota authorized parts store should be able to get it for you. It is a pain of a thing to get them to find the part number - because it doesn't show up at a quick glance (and that's all you usually get).
Get them to get you PN: SC0580E - it is a CDROM - in a green case - much like the old Toyota repair manuals. They should charge you around $168 - but that is money well spent - you actually get the repair manuals for all the Troopies - back to 1990.
When you put the CDROM in for the first time - you have to enter a serial number - which is on the inside of the sleeve of the case.
Also - the manuals for the 2007 and onwards series, you will find them under the "supplement" menus (i.e. New Car Features Supplement, Repair Manual Supplement, Electrical wiring diagram supplement, and so on and so forth).
Ino!~
FollowupID: 636162
Reply By: Member - Trevor the driller - Friday, Jun 05, 2009 at 19:46
Thanks to ever one, I,m computer illeritate and find it hard to reply. Any way thanks to every one.
AnswerID: 368598
