Prado GXL rims on 07 Hilux
Submitted: Thursday, May 28, 2009 at 10:25
ThreadID: 69260 Views:10402 Replies:5 FollowUps:4
Will Prado GXL rims fit on a 2007 Hilux?
Back later, thankyou
Reply By: Anthony (Vic) - Thursday, May 28, 2009 at 12:04
The rim offset for a Prado may vary over the last two models ?
I was told at the tyre shop that the GXL alloy rim offset for the 2003 model 120 series is 38mm positive offset.
I don't know the offset on a hilux. It may depend upon model & year, but I thought that hilux may have a netual or negative offset?
AnswerID: 367141
Follow Up By: leachy_9 - Thursday, May 28, 2009 at 13:27
120 Prado rims have a P30 offset.
Leachy
FollowupID: 634853
Follow Up By: Anthony (Vic) - Thursday, May 28, 2009 at 13:47
I bought some after market steel rims for the 120 series and they have a 30mm positive offset. At that time, the tyre shop mentioned that original GXL alloys for the 120 had a 38mm positive offset - they may have got it wrong ?
FollowupID: 634856
Follow Up By: Member - Phil G (SA) - Thursday, May 28, 2009 at 13:54
Its probably correct. Most aftermarket rims sit out a bit more than the factory toyota rims.
FollowupID: 634858
Follow Up By: leachy_9 - Thursday, May 28, 2009 at 14:13
Factory rims are P30.
Leachy
FollowupID: 634859
Reply By: Member - SR509 (WA) - Thursday, May 28, 2009 at 12:45
I have the new Prado rims though the Speedy version which is exactly the same) on my 2009 Hilux. They are made for the Prado as the Toyota Prado Rims from Toyota are about $1,000 each. Look good, fit well.
AnswerID: 367145
Reply By: Jimbo (WA) - Thursday, May 28, 2009 at 15:52
Prado 90 Series GXL rims definately fit!
AnswerID: 367174
Reply By: Buggerlux - Thursday, May 28, 2009 at 23:21
Thankyou so much for your help.
Ill look at the Speedy rims and keep an eye out for any wrecking Prado GXL rims..
AnswerID: 367276
Reply By: Buggerlux - Thursday, May 28, 2009 at 23:23
$1000 dollars each! Gee their parts division must do well :)
AnswerID: 367278
