Slide on camper jack stands
Submitted: Monday, May 11, 2009 at 13:49
ThreadID: 68722 Views:15551 Replies:3 FollowUps:2
We are currently designing a slide on camper for our tray back Hilux. At present we are looking for adjustable jack stands to enable us to set up the camper and drive the car away. Any ideas on suppliers?
Reply By: GoneTroppo Member (FNQ) - Monday, May 11, 2009 at 14:33
Try Manutec here
Site Link
AnswerID: 364303
Follow Up By: Member - Tony & Julie (FNQ) - Monday, May 11, 2009 at 16:52
Thats where I got mine from and they gave me a very good delivery price to FNQ as well. They work a treat and they are a very good price compared to others. They are H/D and I think about 50kg for all 4, so adds to your carry weight. I welded my bracket to the top of the winder so I can lift quite high if needed. Have a look at my profile and you will see how they are set up. I will give you close ups if you wish. I made a box in the camper to store them, we only take them when we are going to camp in one place for a while.
A couple of tips. Drill 1/2" holes in the bases so you can put a large tent peg through the base. Then weld lugs on the legs so you can put cross brace chains on (with a turnbuckle). This way when you remove the camper you can tighten the braces and there is no rocking and rolling :-). Cheers Tony
FollowupID: 632003
Follow Up By: Ali L - Monday, May 11, 2009 at 17:23
Thanks Tony and Julie
It's certainly the best range of jacks I've found to date. Thanks for the extra tips - it is appreciated
FollowupID: 632016
Reply By: Dunedigger - Monday, May 11, 2009 at 19:00
I have a set of Manutec on our Trayon Camper. Good units
Dunedigger
AnswerID: 364349
Reply By: _gmd_pps - Tuesday, May 12, 2009 at 00:54
I have these on my slide-on
http://www.pplmotorhomes.com/parts/rv-jacks/atwood-power-jacks.htm
with wireless remote .. work a treat with all 4 at the same time.
slide-on is 1300 kg dry
good luck
gmd
AnswerID: 364417
