Canning Stock Route Feedback
travelling the canning nth, to sth. in september, in twin cabs, 03 rodeo & 04 triton both 3lt ict diesels, anybody got any history travelling in these vehicles, pete, jen, dave & deb.
Reply By: Member - Richard L (WA) - Wednesday, May 06, 2009 at 19:13
Iv'e done it in an 02 Navara DC........no problems.
There are a couple of things you have to be a bit more careful with however.
1. Ground clearance is not as good as a cruiser or patrol so you need to choose you track more carefully in certain areas.
2.You will also need to reduce tyre pressures a bit more alsofor the dunes........I let mine down until I can virtually idle up a dune......this of course means you have to travel a bit slower on the flat but travelling slower with low tyre pressures on the corragated sections makes for a much better ride and less chance of blowing a shocky
Hope you have a ball........we did
Richard
AnswerID: 363539
Follow Up By: POB - Wednesday, May 06, 2009 at 22:59
thanks Richard L, what tyre pressure did you run at?
FollowupID: 631239
Follow Up By: Member - Richard L (WA) - Thursday, May 07, 2009 at 11:58
Depends on what weight you are carrying but the pressures indicated by Bucky would be a good indication .........a bit of trial and error never goes astray.... let them down till the dunes are easy and the corragations comfortable
FollowupID: 631340
Reply By: POB - Wednesday, May 06, 2009 at 22:56
thanks richard we plan to
AnswerID: 363602
Reply By: Member - Bucky, the "Mexican"- Thursday, May 07, 2009 at 05:13
POB
We too are doing the CSR in July, and will be doen to somewhere betweem 15-18 psi.
And on the corrugations, ect to get there approx 22-25psi..
Have done the Simpson, and Big Red a few times now, and 15 seems to work best, 18 if you have a fair load.
It's all about footprint, of your tyres
Bucky
AnswerID: 363615
