Monday, May 04, 2009 at 19:33
Hi there. We bought 'old' a few years ago, and there's a range of vans including $5000 ones that I wouldn't back away from, as long as you are happy to buy a 'dated' design, like the Millard, Frankiln, Viscount etc. of the early 80's.
I was not aware at all of things like brakes, ATM, towball weight, towbar rating when I started shopping. Also, even if your van has Tare and ATM shown on a plate or whatever (ours is painted on the van side), there's every reason to believe the actual weight has nothing to do with the stated weights.
If the van you buy has electric brakes, you will need to add the cost of a brake controller plus installation to your purchase costs. Also, if your towbar has a light duty rating, that may need to be replaced.
You may need to buy weight distribution stuff, especially with a front wheel drive (it would be a bit inconvenient if the front wheels weren't in contact with the road!).
Tyres are an issue too - ours looked fine, with plenty of tread, but they turned out to be stuffed (they were 6 years old, and the first we knew was a blow out on our first proper trip).
You'll probably find that 14ft is about your size - anything heavier than 1500kg ATM and 100kg on the ball will probably exceed your Camry's limits, though I am not saying I know what the actual figures are for the Camry.
My research said to
check for chassis strength (cracks, rust etc.) and signs of serious water damage to the structure (usually plywood, chipboard underneath the skin). Leaky windows can be fixed, but it means a lot of work and a few dollars as
So yes, $5 grand may get you a van, but it may also get you a heap of trouble. Same applies to a dearer van though - you still have to be wary.
Hope these comments help
Chris (SA)
363220
Follow Up By: cranswick - Monday, May 04, 2009 at 19:51
Thanks for youe reply, l haven't had a tow bar installed on my car yet, l think the weight limit for a toyota camry is 1,200 kilos, l did'nt know about electric brakes, do the old ones form the 1980's have them? am l better off getting a van with or without electric brakes?
630847
Follow Up By: Tenpounder - Monday, May 04, 2009 at 22:16
I hope someone else can tell you when electric brakes took over. As far as I know, the old over-ride brakes if fitted were OK, but yo can't retrofit override brakes to an van. Our is an '89 van and has electric brakes which I think are heaps better. But you are only talking short hauls aren't you, so my hint was that an override system would be easier and cheaper, even if not quite as good.
Chris (SA)
630884
