Friday, May 01, 2009 at 15:14
Big Al
the short answer from me is yes...I will try and answer it as best we can
purchased new Feb 2004 . Never had an issue with water at all until late last year completley out of the blue the following happened.
Put it away in the shed after 4 weeks away in the
Kimberley..no rain at all on it that trip and no water xings that could do anything.
Pulled it out of the shed in Nov and when we opened it up I stood there dumbfounded..the floor was completely buckled up internally with the lino raised in a center ridge about 100mm high and
rock solid!.
Took it up to Pioneer factory and they stated that it had only "happened to a rare few" but had never seen one as bad as ours. The actual floor staff were very helpful and open with me. They took the end plugs out of the aluminium runners on the top of the camper (when closed up) and water ran out of about half of them! (so to do that they must have suspected they had water?..I never thought of looking they are "sealed" so they must have known something obviously)
How in the hell it ever got in there we will never know. They suggested that the water can only come into those runners when landing on the top (when closed) and then seeping in between the runners and the floor and then down into the screw holes that are used to fix the runners to the timber floor) Hope that makes sense. Unfortunately a lot of that defies gravity! as the water had to flow vertically upwards to be in the runners
They peered very closely all over the camper and I noted that they took particular notice down around the bottom left and right of the tail
gate area (as though they might have experienced leaks from there before)
I spent hours searching all over the thing and hours racking my brain and simply cannot fathom how the water can get in to those runners there in that quantity......(and when) because with it closed up the water had to go down into the floor area not vertically into the runners!
As I said we pulled it out of the shed after some 4 months to find the buckled timber and lino...so did water somehow get into the runners (over an unknown period of time and how????) and then gravity allowed it to seep out through the screw holes when in the closed position in the shed? why then and why not before...it is a complete mystery and has beaten and frustrated the hell out of me.
The end result was that I had to have a new floor fitted (at approx $1k) as the current owner of the business (who is not as nice and helpful as his staff) said it was out of warranty and before he owned the business...therefore not his problem.....fair enough comment...but not even doing it at cost in good faith was dissapointing...he still made money out of my misfortune and is still using the same floor design
So we now have a new floor..same design still in use.......mystery never solved..and my fingers crossed.......I love the camper it has served us
well over some very serious off road trips and performed flawlessly..
Dont know if that water issue is the same as yours...but if you do know where your leak is coming from Id love to know...it may be from where
mine started and therefore may do again?
362623
Follow Up By: PandJ - Saturday, May 02, 2009 at 09:43
This seams strange to me
Just wondering if when you arrived
home after your trip you hosed it down or washed the top where the runners are?
Could this be a problem?
Cheers P&J
630426
Follow Up By: Member - bungarra (WA) - Saturday, May 02, 2009 at 09:55
Agree it is strange.....we did not hose it and even if we did...water should still not ingress
if you read my post again note that the factory went looking into those runners!...why would they without already some knowledge?..they were sealed and who would even think of looking there without a previous occurrence / knowledge
yes very strange indeed
630428
Follow Up By: PandJ - Saturday, May 02, 2009 at 10:02
Yeah! very strange for sure. I thought it may have been condensation at first.
I will look at our in a minute.
Note your opinion of the new owner, I found him very helpfull and honest.
630429
Follow Up By: Member - bungarra (WA) - Saturday, May 02, 2009 at 10:09
your initials have jogged my memory..
did you by any chance spend New Years Eve in Coolup? with S & J?
..if you didint no worries that question wont make sense...
630430
Follow Up By: PandJ - Saturday, May 02, 2009 at 10:18
No not us.
630433
Follow Up By: Big Al SA - Saturday, May 02, 2009 at 14:52
My Argyle E is willing up with water, under the bed, whilst it is closed up, No its not from filling the
water tank. My under body lockers also fill with rain water.
630463
