How do you remove caravan windows
Submitted: Sunday, Apr 26, 2009 at 15:07
ThreadID: 68238 Views:3966 Replies:2 FollowUps:1
G'day
Have a leak in one of my caravan windows, it's a slide window and was wondering if anyone knows how to remove these and what to do about resealing them.
Jim
Reply By: Member -Dodger - Sunday, Apr 26, 2009 at 17:42
They are quite difficult to remove as one must undo all the retaining screws then slowly remove the window.
This window removal is difficult as the sealant around also holds the window in.
After removal you must clean all the old sealant from window surrounds and the offending window then purchase the correct caulking compound then apply and re-seat the window in the surrounds.
I did 2 in our old van and it was a difficult and messy job.
I swore that next time I would leave it to those that do van repairs.
Cheers Dodg.
AnswerID: 361690
Follow Up By: Tenpounder - Monday, Apr 27, 2009 at 16:48
Hi there. Yes, I agree with Dodg, it's a cow of a job. But, as a retired bloke, I had the time, and did my windows one at a time; ended up doing the door frame and the corner beads as well.
Only thing to add is that I bought new self-adhesive foam strip from Clark Rubber (don't know if they operate outside SA), and I used a windscreen sealing compound that stays soft (ie does not cure like silicon). So I (a) stuck the foam strip to the window frame, then (b) buttered the foam strip with the sealer, then (c) refitted the frame, fixing quickly with new stainless screws, and finally (d) cleaned up VERY QUICKLY with turps to get rid of the HUGE amount of smeared sealer!!!!! (lots of clean rags handy!).
Hope this helps.
Incidentally, prise out the frames gently: you can easily crack a window, which adds considerably to the cost (yes, the window I broke was, naturally, the biggest and most expensive to replace).
Chris (SA)
FollowupID: 629640
Reply By: lecruiser - Monday, Apr 27, 2009 at 15:16
Thanks for the info.
Jim
AnswerID: 361865
