Using Honda gennie
Submitted: Sunday, Apr 12, 2009 at 14:39
ThreadID: 67781 Views:2813 Replies:3 FollowUps:11
If I want to watch the footy whilst camping bush, now I have a new Honda gennie, do I watch TV like I always have, via the inverter and re-charge the batteries as necessary. This allows us to keep the water pump on the 12v setting if in use during the match
or
do we run the gennie whilst watching the match, (TV running directly off240v) and switch the pump to 240v and then back again to 12v at the end of the footy?
This is just an example and will give me the answer to several conundrums. The van has on-board batteries
Reply By: Maîneÿ [wa] - Sunday, Apr 12, 2009 at 14:47
Steve,
Use it to recharge the battery system as you watch TV via the inverter.
Less hassles :-)
Mainey . . .
AnswerID: 359309
Reply By: Member - Barnray (NSW) - Sunday, Apr 12, 2009 at 16:06
If the gennie is inverter type run the TV off the gennie and charge batteries at the same time. The more you can run off the gennie while you are charging the batteries the quicker they will charge. B
AnswerID: 359315
Follow Up By: Member - Fred G NSW - Sunday, Apr 12, 2009 at 16:23
That's what I do, just so long as there are no other campers nearby to disturb...or invite them over to watch it with you, their shout :-)
otherwise go with Mainey's suggestion. Did you get the 10 or the 20?
Fred.
FollowupID: 627276
Follow Up By: Steve - Sunday, Apr 12, 2009 at 22:49
I got the 20, which is probably overkill for now - but in the future, I'm sure we can use a bit more when the sun/solar isn't doing it's stuff.
i suppose the thing that I couldn't quite get my head around was, do I have to switch the 12v pump over to 12v or 240v to operate whilst the staff are doing their thing and the men are watching the game. If I have the TV running off the 240, can the water pump still run on it's usual (bush setting) 12v? and if so, to achieve that, do I just connect the gennie to the batts via 12v whilst having the 240 lead running into the van and TV?
FollowupID: 627318
Follow Up By: furph - Monday, Apr 13, 2009 at 08:05
Steve.
First up, you mention the 20 being a bit of overkill.
If your continuous load is such that it merely "idles" on eco throttle setting it wont be long before you notice considerable oil consumption (glazed bore)
This happened to the one a mate bought, he bought "top of the range" everything, Kimberly Kamper, Honda 2.0i etc. etc.
He would have been much better off with the 10, which is what I bought. His 240v. load is almost negligable.
With a what sounds similar to your set up, my Honda 10 powers the van 240v. system which also charges the on board battery. It also runs a 20a, 3stage charger for the 2 aux. batteries in the truck (plus the starter battery if needed).
This generates a (240v.) load of about 400-500 watts on the gen. (900 max. cont.) which means it is still on eco throttle but you can hear the load on it.
The exhaust noise is still ok (the gen. is mounted in the back of the truck with a canopy over) Fuel use about 0.6l./hr., oil consumption neg. Would now have around 900hrs. running.
furph
FollowupID: 627333
Follow Up By: Steve - Monday, Apr 13, 2009 at 09:04
Thanks furph. I'll bear that in mind. I can make it work harder if necessary - plenty of things like microwave, electric stove and even a fan heater to switch onto it. Didn't take up the air con option but all is in place if needed.
The thing that I would like to know is, if we are in a caravan park and plugged into 240v, this not only allows us to use whatever appliances we want, but also charges the van batteries via the controller at the same time. So having the Honda plugged into the van's 240v system via the main power inlet, would do the same without having to physically connect it's 12v to the batteries as well??????? whilst I'm watching TV in the bush.
....and for those who wonder why we want to watch TV in the bush.....we don't. Unless it's to find specific info or watch something specific via Foxtel.
FollowupID: 627340
Follow Up By: Member - Fred G NSW - Monday, Apr 13, 2009 at 09:20
That would be correct Steve. The Honda simply replaces the park 240 v supply into your van, whilst also feeding your batteries via the system you have in place. Your just limited as to how many/what 240 v appliances you can run at the same time, whilst running off the Honda. That's my understanding of what you are asking.
Fred.
FollowupID: 627341
Follow Up By: Member - Fred G NSW - Monday, Apr 13, 2009 at 09:23
Thanks for the tip re the eco setting on low loads furph. I'll store that tip in the memory bank.
Fred.
FollowupID: 627342
Follow Up By: Steve - Monday, Apr 13, 2009 at 09:56
thanks Fred - that clears it up. I'll just have to be aware of the water pump use and switch it to 240 when we are connected to the gennie and back again when we've finished charging.
I suppose I wouldn't use the 12v facility apart from charging the car batts if necessary. I get a bit confused and excited with these new gadgets
FollowupID: 627347
Follow Up By: furph - Monday, Apr 13, 2009 at 10:58
Forgot to mention it, but the mate with the 20 now carries a smallish microwave to impose a decent load on the unit every day or so.
Spoke to him this morning, it is still using oil but he thinks it is running much better.
furph
FollowupID: 627355
Follow Up By: Steve - Monday, Apr 13, 2009 at 11:50
I'm glad you mentioned that - because we tended to shy away from using the microwave. Not that we've actually used the Honda in earnest yet - but we'll make sure the MW gets a workout as well.
Steve
FollowupID: 627358
Reply By: landseka - Monday, Apr 13, 2009 at 11:29
Hi Steve,
just going off on a tangent here, you didn't mention what type tv you are using.
I am assuming it is an lcd flatscreen as most people seem to use, if so, are you aware that they actually run on 12v?
If the power cord has a "brick" between the power plug and the tv then this is the case, it has 240v entering the brick & 12v coming out.
You can either make a separate lead to run direct from 12v supply to the tv, or do as I have, cut the supplied lead on the tv side of the brick & connect this portion to a 12v supply plug.
I have utilised a connection to this lead so I can revert to 240v supply when using the tv at home.
Now you can watch tv without starting up the gennie.
My satellite reciever (Strong) works the same way so I can use it also from 12v supply.
Hope this helps
Neil.
AnswerID: 359361
Follow Up By: Steve - Monday, Apr 13, 2009 at 11:48
I had previously (before the Honda purchase) set the LCD TV up to run thru the inverter/battery and just topped the battery topped up via solar usually, or my old GMC gennie. We still have that option but if I'm glued to the box for two hours it'll take a bit out of the batts so we might use the opportunity to top them up as well as prevent them running down and run the Honda. Depends on circumstances. We are heading off to the High Country tomorrow for the first time and knowing mountain climates as I do (in a previous life) there'll be plenty of cloud, if not rain about - that's what finally prompted us to go for the Honda. We might become nomads in a few years time too so I'm sure it'll justify our lashing out on the new Gen.
FollowupID: 627357
Follow Up By: oldtrack123 - Monday, Apr 13, 2009 at 16:18
HI
Just a word of caution.
Yes many 240v lcds do operate via a wall wart /brick which puts out 12v dc.
The problem is that the supply voltage has fairly tight controls which means you would be unlikely to have in excess of 250v supply .At 250 v the wall unit would be putting out about 13.6 vdc % the unit [tv ]would/should be designed to cope with that.
[approx 13% over voltage]
' However ,Your van /vechicle battery if being charged ,& depending on charger type/source , state of charge etc could reach 15v.
25% OVERVOLTAGE the tv /unit may not be able to cope.!! Units supplied with a 12v adaptor by the manufacturer ARE / should be , designed to cope with this voltage range.
Your choice but be aware.
FollowupID: 627381
