Monday, Apr 13, 2009 at 07:19
Mainey surely you can't be serious.
To say the above you assume that absolutely all applications are the same criterea.
For example. Large instalations are not concerned with shading, mounting issues, or possibly sun angles.
Solar Challange is only concerned with efiency per sq meter and who the sponser is. ( eg BP probably wouldn't use Sharp panels).
RV applications are a mixture of size, weight, price, shade capability, angle tolerance and other requirements.
Things are not that simple and broad statements are generaly not good advice.
I would have thought that if you had an ex race car's solar panels it would be single crystal based which can be more efficient than Multi Crystaline, and if you do what large installations do, you would have to have a MPPT regulator.
627329
