MAF on 3ltr Nissan
Submitted: Friday, Apr 10, 2009 at 17:03
pippy62
Can you tell us where to find this Maf on a 2000 patrol and what it looks like. Thanks
Reply By: Member - Stuart P (WA) - Friday, Apr 10, 2009 at 17:16
its a sensor in the air duct from the air cleaner to engine
359103
Follow Up By: Bonz (Vic) - Thoughtfully- Friday, Apr 10, 2009 at 20:13
so how is it disabled so it wont cause a problem?
627125
Reply By: Member - Ian H (NSW) - Friday, Apr 10, 2009 at 20:17
I believe if you disable it the car won't go at all. Then you won't have a problem!! No problems!
359129
Reply By: Louie the fly (SA) - Friday, Apr 10, 2009 at 20:25
In the Chevy LS1 Gen 3, and I presume the Gen 4 6.0L, you can get what they call a MAFless tune. They reprogram the ECU and you actually remove the MAF sensor. Not sure if there are people doing this for other cars.
Louie
359132
Reply By: Member - Stuart P (WA) - Friday, Apr 10, 2009 at 23:22
the maf sensor gives the correct air flow to the motor for the most efficient fuel combustion. the problem is that it also controls the turbo operation ,via a vaccum actautor, take the sensor out and use a good carby type cleaner to take scale off the hot wire sensor . regular descaling should help.
359157
Reply By: pippy62 - Wednesday, Apr 15, 2009 at 09:11
We don't want to disable it or permanantly remove it.....just get to it and clean it...
359647
Reply By: KiwiAngler - Wednesday, Apr 15, 2009 at 22:29
This website may assist you
MAF sensor location
359755
