One for the Engineers & Inventors
Submitted: Wednesday, Apr 08, 2009 at 15:03
Member - John M (NSW)
Hello All
I am about to commence on this years project, a tandem off road pop top camper trailer.
I have purchased many of the components for this project including a tandem 2.5 tonne Simplicity
Suspension.
The main body is 4.2 metres long which includes a rear section that folds down and incorporates a shower/
toilet and entry to inside.
I have researched many options from hydraulic cylinders, 12v electric telescopic actuators, gear driven worm drives and every option comes close to approximately $4,000.00 for components.
Although the camper is expected to cost about $35K for components and materials, I cannot convince myself that it should cost $4K to lift the roof.
The roof complete with insulation, lining, retractable Air Conditioner and a 80kg tinnie will be approximately 225 kgs so I am using a figure of 350kgs as the total weight.
I do not want to use the Jayco / Coramal wire and winch system as they are susceptable to failure and will not handle this weight.
If anyone has any suggestions on a reletively simple and cost effective method to raise the roof 900 mm's I would appreciate your advice and input.
Yes I have considered
parking under a tree and using a chain block, fitting a HIAB crane to the drawer bar and getting the "Men from Mars" to follow me around with a crane. All of these ideas were scrapped when I pulled the last strand of hair from my head.
Your help would be appreciated.
Regards and Happy
Easter to All.
John | Life isn't about how to survive the storm, but how to dance in the rain! Lifetime Member My Profile Send Message |
Reply By: Louie the fly (SA) - Wednesday, Apr 08, 2009 at 20:11
John, what about these ideas?
A rack and pinion. You can buy rack by the metre, and then build a winder mechanism - that could work simply.
or
You could make your own linear actuators by using some threaded bar. 25mm high tensile threaded shafts with a brass nut which is held captive in a housing, and spins around via a worm gear drive. Like a Hywema truck hoist.
or
You could use some pulleys and a 12 volt boat winch. Put slides on each corner, like fridge slides.
The linear actuators may work but to lift 900mm you're looking at a hefty priced unit, and you need 4. And I'm not sure if they can support the weight. We use them in a horizontal position generally, or vertical in light duty applications. Have you ever seen those jacks they use to put transportable houses on & off low loaders? An air cylinder with a 900mm stroke will also set you back a bit. Any way you go, an automated system will be costly IMO.
Good luck with it.
Louie
358857
Follow Up By: Louie the fly (SA) - Wednesday, Apr 08, 2009 at 20:17
I just read Gonetroppo's post again and it gave me an idea. A scissor action lifter that winds up & down by way of 2 synchronized drives that wind around a quadrant. It would work along the lines of a car window winder mechanism and would have considerable load lifting capacity if designed correctly. Drives would need to have a reasonable amount of torque and be compact. I know someone that could design it (hint hint).
Louie
626867
Follow Up By: Member - John M (NSW) - Thursday, Apr 09, 2009 at 07:35
Hi Louie
Your option 2 along with the scissor lift is the most simple and fool proof method that I have come up with and I can build it both with a motorised lift and have mechanical backup. No hydraulic oil to leak, no electrics to fail except the drive motor and no cables to break and it will always stay syncronised.
I also like the idea of a quadrant except the it may be very larhe and housing it could be a problem. Any ideas are welcomed.
I really like the linear actuators and can get them with the stroke and lift capacity that I need from Motion Control Industries, what worries me is the electronics and electrics for the syncronisation. More to go wrong and fail and in the middle of the bush if I can't raise the roof or lower it may not be a good look with the bride.
Thanks for your good advice.
626900
Follow Up By: ross - Thursday, Apr 09, 2009 at 09:59
How about something like an exhaust jack placed under the centre of the roof to get it to height so you can push some pins in to hold the load there.
If the jack was placed on something like a sturdy tool box 4-500mm off the ground then the distance would be halved.
The box could be used for storage and placed outside once the roof was up
Having the roof keenly balanced would be important
626928
