Headlight left on warning device
Submitted: Wednesday, Apr 01, 2009 at 11:19
Vince NSW
Hi all, just go back from a trip to the Snowys and we are sitting at
home with fog & rain in the Blue Mountains. Went to the hardware store this morning and when I came out the headlights were still on. This has happened to me quite a few times over the last few weeks. I can see a flat battery coming. Sooo !
Can you buy an after market device to warn you that the lights are still on. Tried Jaycar but the only have a kit that you have to build yourself.
Any other idea's ?
Vince
Reply By: Geoff (Newcastle, NSW) - Wednesday, Apr 01, 2009 at 13:54
Hi Vince,
Another alternative is the Redarc "Key On-Lights On" module,
Redarc KOLO
10 seconds after you turn the ignition on the lights come on.
As soon as you turn the key off out go the lights.
Great safety idea, I know it's actually the reverse of your question but it may solve another thought!
Companies such as Budget etc. use them in the 4WD's they hire to mines!
Geoff
| Geoff,
Landcruiser HDJ78,
357427
Reply By: StormyKnight - Wednesday, Apr 01, 2009 at 20:16
Yep I did this mod on my HQ before I upgraded to a real 4WD...with the auto turn off..(Toyota)
You just need a 12V buzzer, hook the red positive wire to the a 12V wire that is on when the lights are on, hook the Black Negative wire to your door switch. When you open the door the black wire will be connected to earth thus making the circuit. With your lights on the buzzer will sound. To stop the buzzer, but with the lights on, just shut your door. Worked for me & saved a few starting issues over the years I had that car.
357528
Follow Up By: Member - Graham H (QLD) - Thursday, Apr 02, 2009 at 18:34
Put a relay in the headlight circuit and activate it by the ign circuit.
Should do the trick
Yes my 100 and my older Corona's had autoshut off lights.
625813
