Half Height Cargo Barrier Dimensions
Submitted: Wednesday, Apr 01, 2009 at 06:16
Gunna Do
I have just built a storage unit for in the rear of my GU Patrol and am trying to work out if a half height cargo barrier will fit over my creation.
Would anyone be able to give me the distance a half height barrier comes down from the roof/hood, or alternately the distance one of these barriers is from the floor in the rear of the Patrol.
Any assistance would be greatly appreciated.
Reply By: Member - John T (Tamworth NSW) - Wednesday, Apr 01, 2009 at 07:31
G'day Gunna Do,
Just walked out and measured the distance from the floor of my GU (DX model so no carpet) to the top edge of the Black Widow draws - 36cms. The barrier sits just (1/2 cm at a guess) above that.
This is witha set of draws that fit behind the rear seats.
Hope this helps
| John T (Lifetime Member)
VKS-737 Mobile 2619
Selcall 2619
"Argue for your limitations and sure enough they're yours" - Richard Bach in "Illusions" Lifetime Member My Profile My Blog My Position Send Message |
357362
Follow Up By: Gunna Do - Wednesday, Apr 01, 2009 at 18:11
Thanks for the measurements
John T, they will be a great help.
625605
Reply By: Leroy - Wednesday, Apr 01, 2009 at 21:14
To give you an idea of what I did (and size), I have an Engle 40l with 2 drawers beside it. I bought a Milford cargo barrier from an AU Falcon. I cut like the bottom 350mm off it and used that for my barrier. Turn it upside down and you will see...
I then bought some square tube and welded that allong the bottom. I cut tags etc off the old barrier and welded them on and cut the arms to length that mount up near the grab handles. If I get time I will take a
pic.
You can
pic the falcon barriers off ebay for $20!
Leroy
357550
Follow Up By: Gunna Do - Thursday, Apr 02, 2009 at 10:55
Thanks Leroy,
I hadn't thought of doing something like that, but it is a good idea, and then it would be the perfectly height for the unit I have built. I would appreciate seeing a couple of pics if time permits.
625738
