Magellan eXplorist XL
Submitted: Tuesday, Mar 24, 2009 at 18:19
ThreadID: 67156 Views:3076 Replies:5 FollowUps:3
Can one of these units be run of a 12volt socket instead of the 4 AAA battery.
Reply By: Member - esarby (NSW) - Tuesday, Mar 24, 2009 at 18:35
I have used my XL on a trip around Oz and only had to replace the AAAs once. As far as I can figure the four AAA = six volt. There is an input plug on the unit mains lead. You would have to cut the power input by half. Probably with a six volt charger. AAAs are the cheapest way to go, in my mind.
AnswerID: 355916
Reply By: Member - Warfer (VIC) - Tuesday, Mar 24, 2009 at 18:36
Hiya carlj
You mean 4x AA Batts....It should of come with a ciggy plug is that what you mean by socket ???
I use Energizer rechargable 2500mah batts..
AnswerID: 355917
Follow Up By: carlj - Tuesday, Mar 24, 2009 at 18:46
It came with a high speed USB cable and the Ciggy plug has input DC 12v-24 output DC5v+-5% Max 500ma. The trouble is I got it second hand not a lot info.
FollowupID: 623932
Reply By: Member - colin J (VIC) - Tuesday, Mar 24, 2009 at 18:50
Hi carlj,
When my unit is installed in it's cradle in the car in runs the whole time off the cig lighter cable. The only time the batteries come into there own is when you use it as a hand held or if the car is not on accessories etc.
Regards from Big Col
AnswerID: 355920
Reply By: Member - Michael O (NSW) - Tuesday, Mar 24, 2009 at 21:45
I found a "cigarette lighter" plug with a USB on the back of it.
Runs the Xplorist all the time on 12V.
If we're on the blacktop and don't need the GPS, we can then run the iPod off it too!!
AnswerID: 355966
Reply By: Foxhound (WA) - Tuesday, Mar 24, 2009 at 22:15
I have the same GPS as you. You can just plug in the cig plug on the USB cable to your cig lighter socket and it will overide the batteries.
AnswerID: 355974
Follow Up By: Member - Russnic [NZ] - Wednesday, Mar 25, 2009 at 10:05
I run mine on the cig lighter socket almost all the time, only use the AAA bat when away from a vehicle, I found the AAA's don't last for very long at all.
FollowupID: 624045
Follow Up By: Member - Russnic [NZ] - Wednesday, Mar 25, 2009 at 13:53
For more info Search Magellan eXplorist XL
you will find links to manuals and instructions that you can down load. That will give much more information than the basic instructions that come in the box.
I use it often, too work out area ground speed etc for cultivation, check speed, navigation in towns and those bigger places that I try to avoid!.
With the appropriate software even names the creeks you cross out there. Unfortunately it doesn't keep pace with road changes ie new Motorways etc, it will in time I guess!.
I have the cards for Aus, and NZ almost cost as much as the hardware, well worth it.
FollowupID: 624103
