Tuesday, Mar 24, 2009 at 22:20
A fine Exploroz greeting to you, KS.
I second the suggestion that you install a second battery (deep cycle) and a 12V/240V fridge in your vehicle. A set up such as this gives you way more flexibility for keeping food and drink cool when you are away from your van. Nowadays you can even purchase a car fridge with an inbuilt deep-cycle battery. Either option will allow you to easily overcome the problem you face with powering the 240V fridge in your van as you travel.
If you don't want to install a fridge in your vehicle, perhaps go with the suggestion that you replace the 240V fridge in your van with a 3-way or 12/240V fridge. Selling off the 240V fridge is unlikely to be a problem ! Any reputable caravan sales/repair business could help you with modifications required.
Your van probably already has a gas installation for the stove. Connecting the gas supply to a 3-way fridge should be easily done by an authorised gas installer. Most caravan sales/repair shops have such a person on staff.
If you install a deep-cycle battery in your van to power your fridge, an auto electrician can install it and connect it to your vehicle so that it gets a top up as you travel. Maybe you already have a battery in your van for the 12V lights !
There are plenty of
places where you can use a generator, however national parks are not among them. Nor are those close by other travellers ! You need to make sure that you have the correct outlet on the generator - usually 15amp - to be able to use your caravan lead. Simply plug the 15amp lead into the external 240V socket of your van just as you do when you are in a caravan park.
If you go for a generator, be sure to get one that will power several items at the same time. A lot of vanners buy the 2000W model as it will run several appliances at once, but definitely not the toaster, microwave and hairdryer at the same time. I know from ownership and experience that the Honda and Yamaha generators are much quieter than the really cheap units and they run (rev) according to the load on them.
By using a medium to high capacity multiphase battery charger, you can use your generator to quickly charge up a deep-cycle battery. However, if you are frequently on the move, topping up the second battery will not be a problem. In a correctly set up installation, the vehicle alternator will do it for you once it has topped up your vehicle's starter battery.
A solar panel can be connected to the deep-cycle battery - via a regulator - to top it up if you stay in a secure place for a while. The speed of charge will depend on the size/capacity of the panel/s and how much you are prepared to spend. An 80W solar kit seems to be popular. I bought a 120W unit for $1350 as it gives me the option of expanding my use/dependence on batteries. As
well, it gives a greater charge over a shorter period .... when the sun's shining !
Further suggestions:
1) Do a search of the
Forum Archive. Plenty of folk have responded to a plea such as yours in the past and you'll find many responses worth reading. Scroll through the threads and look for those with highlighted words.
2) Read up via the Articles tab (above); you should find valuable information.
3) Ambush a traveller with a set up such as yours.
4) Attend a camping/caravan expo.
5) Use Google and search for the information you require. I found the following this way: Ray's Caravan, Campervan & Motorhomes web site at http://
home.iprimus.com.au/rfh/index.htm. Scroll to the bottom of his
home page and click on Continue to access the plethora of experience-based information.
Happy travels,
Netnut
355977
