Charging battery in car?
Submitted: Wednesday, Mar 18, 2009 at 23:47
ThreadID: 66964 Views:4523 Replies:9 FollowUps:5
Hi everyone, a mate asked me today if i knew of any gizmo's that would enable him to charge a small 18 amp/hour battery through the cigarette lighter in his car. He said he was told about them by someone. You see he is going on a trip for about 18 days but doesnt want to fork out for a dual battery system, as he wont be keeping car. He will be running a Waeco CF35 and wants know if he can run it off his little 18 amp/hour battery at night when camped, only ever one night at a time. be staying most nights at motels and such and plans to take the fridge inside and run it off 240v at night, but for the 6 or 7 nights he plans to camp out he would like to be able to run the fridge off his little battery and not the main battery. Is their any ways he would be able to keep the little 18amp/hour battery topped up while on the road without the need for extra wiring. He plans to stay 3 nights in a motel then one night outdoors, but he really doesnt wanna use his main battery to run his fridge when car is off, little paranoid as he cant work out how much power it will use.
The main things he is after is
1, Is there a device out there that is reliable that is ok to charge SLA batteries and ready made or is it just a dream (charging through the cigarette lighter)
2, Does anyone know roughly how much a CF35 Waeco draws (website only says roughly 0.856 amps) maximum.
3, Will the 18 amp/hour be good enough for around 10-12 hours, being used as a fridge only. And it will be used from Darwin to Melbourne and back in June, so not really high ambient temps.
Only device i can find is this which looks a little cheap, and probably not very good for a SLA battery???? Is there any ready made power pack that can be charged through the cars cigarette lighter? 12v Battery Charger Gizmo?????
Thanks everyone, its got me beat as i am pretty useless at this stuff, i have dual batteries so i am fine.
Cheers Kroozer
Reply By: Dave(NSW) - Thursday, Mar 19, 2009 at 00:19
Hey Kroozer,
May be one of those Jumper battery packs will do the job, They can be charged from 240v or 12v cig lighter, Just get the biggest amp rating you can afford .
Cheers Dave....
GU RULES!!
AnswerID: 354808
Follow Up By: PradOz - Thursday, Mar 19, 2009 at 08:02
bingo - thats it. get the right one and if his battery goes flat he can then also jump start himself
FollowupID: 622917
Follow Up By: Member - Graham H (QLD) - Thursday, Mar 19, 2009 at 08:45
Thats a bit like getting up yourself in the morning
Be better if he jump started the car.
ROFL
FollowupID: 622924
Follow Up By: Member - Duncan W (WA) - Thursday, Mar 19, 2009 at 20:12
Before I had the duel battery system in my car I used a jump pack. Used it at night for 4 nights before it looked like needing a charge. We have the 50L Weico
Dunc
FollowupID: 623057
Follow Up By: Member - Duncan W (WA) - Thursday, Mar 19, 2009 at 20:13
OOPS can't spell Waeco.
Dunc
FollowupID: 623058
Reply By: Axel [ the real one ] - Thursday, Mar 19, 2009 at 09:00
If he already has the battery how does he charge it now ? He can recharge it in the motel using his batt charger on 240v ,,, another is to buy a 12v to 240v inverter , plug inverter into car - batt charger into inverter ect , not very effiecient but would suffice short term use.
AnswerID: 354841
Reply By: Tenpounder - Thursday, Mar 19, 2009 at 09:01
Hi there. Setting aside the charging question, let's look at the load overnight: If the Waeco draws say 0.8amps, and the fridge is run from say 6:00 pm until 7:30am, that 13.5 hours at 0.8 = 10.8 amp hours. Most people on this site seems to support the idea that you cant safely draw more than about 60% of the nominal capacity of a lead acid battery without damaging the battery. That's 60% of 18, or 14.4 amp hours. This would not leave much of a margin.
If it was me, I think I would run the Waeco flat out during the day, while the car engine is running, (either to make ice and keep the food in an esky, cooled with the ice, or else run the Waeco close to freezing, so that it has a 'head start' to carry it through the night). Then, I'd leave the fridge off until around bedtime, and then run the Waeco on a moderate (fairly warm) setting until first thing off the small battery. This would reduce the load to, say, 8 hours at 0.8 amp load, or 6 amp hours.
As for recharging, I suspect that most of the technical power pack options will be far too expensive. If he already has a simple 4 amp charger in the shed, then an small (150W continuous)inverter, attached to the charger, might be a goer.
Hope this helps.
Chris (SA)
AnswerID: 354842
Follow Up By: CJ - Thursday, Mar 19, 2009 at 10:17
I agree with one of the lines that Chris is suggesting; I often switch off the fridge after my last drink at night, It is quite ok for it to be off for 6-7 hours if it not being opened, in the cool of the night
FollowupID: 622947
Reply By: ABR - SIDEWINDER - Thursday, Mar 19, 2009 at 10:13
Hi Kroozer
1) Yes there is a device to do this called a car to car charger.
2) Draw would depend on setting and ambient temperature.
3) 18 a/h battery would be just about be dead after 10-12 hours (Again depending on the variables and if the battery was full to start with and the fridge was already cold)
Derek
AnswerID: 354859
Reply By: Member - Phil G (SA) - Thursday, Mar 19, 2009 at 10:32
I've used the 7Ah gel batteries for camping and to keep them charged, have simply used a relay that is energised by IGN power. So its charging off the alternator when you run the vehicle, and is isolated as soon as you turn off.
AnswerID: 354862
Reply By: Out and About - Thursday, Mar 19, 2009 at 11:24
We run a Waeco CF40 in the back of our car. We have 2 batteries that we can use. We have a Waeco 36 amp/hour battery thar charges as we drive along and also runs the fridge. Depnding on the external temps, we can get up to 3 days use out of this battery in summer.
As a backup we also have an 18 amp/hour jump start battery that we can also use to power the fridge. This easily runs the fridge overnight.
I have no idea about chargers though.
AnswerID: 354874
Reply By: ben_gv3 - Thursday, Mar 19, 2009 at 11:42
Those 18A/h jumper packs (I have one) can be recharged through the cig lighter. It's a very crued way of doing it since you can only charge for a certain number of hours before you kill the SLA battery due to overcharging. If you keep on eye on the time then it's OK. Mine came with the cig lighter charging cable.
Those SLA batteries are also considered deep cycle so can be discharged to down near 20% SOC. However just because you can doesn't mean you should.
AnswerID: 354879
Reply By: Member - Kroozer (WA) - Thursday, Mar 19, 2009 at 16:52
Thanks everyone for your advice. I think i will recommend friend to get either an inverter or one of Dereks car to car chargers. I think thats what he really wants and as its made by Derek i dare say its gotta be good. All he really wants is a cheap way to charge the battery during the day while travelling, kind of a lazy approach really. Not sure how he thinks sometimes.
Thanks again
AnswerID: 354944
Reply By: Muddy doe (SA) - Thursday, Mar 19, 2009 at 17:08
I'm with Chris in an earlier reply in that you run the fridge on a colder setting while driving (sounds like there will be at least 5-6 hours of driving a day on this trip) and then run it on a less aggressive setting overnight.
I have a CF40 and did this while touring around in a Honda Civic before getting delivery of my Prado (with dual battery setup).
When I bought the fridge I also bought a Weaco branded powerpack (made by the blue-apple people who are now Home of 12 volt at Mt Barker SA) that is a 24AH SLA battery with two outlets and a test light on it. They are still available for about 300 to 400 bucks which is well overpriced for the capacity but you pay for the convenient packaging. these things come with a lead for plugging into the cigar lighter to recharge them while driving.
Even without the pack I would run the fridge in the boot of the Civic (I did pay TJM $100 to wire a socket in the boot for the purpose) on a setting of 4 or 5 lights and then I backed it off to 3 lights overnight. Even with the tiny battery in the Civic it was never an issue.
A 17AH Supercheap jump pack chucked it the boot would also be good insurance for a morning jump start if the car battery got a bit sluggish. You can get these for well under 100 bucks and they are a great backup as well as being a mobile power source around camp (Lights, air bed pumps etc).
The Weaco fridges also have a low battery cutout built in if it is a fairly recent model. Set this to the high (conservative) setting and it will automatically shut the fridge down before the car battery is drained.
Remember also that the 0.8Amp consumption figure quoted is an average, possibly over a 24 hour cycle. My experience with the CF40 is that it draws 4 to 5 amps when the compressor is running but it only runs about 20-30% of the time giving you the 0.8 to 1.0 Amp average usage figure. This would be at an average temp of around 25 degrees.
When it is hotter (try 50 degrees in the back of the wagon in full sun on a 35 degree day) then the fridge is going to be running the compressor virtually flat chat and it will be chugging down 4-5 amps every hour but overnight when it is 10 to 15 degrees or even colder on desert trips then it will hardly run at all so the fridge may only use 3-4 amp hours over the whole night.
As pointed out, some people even turn them off overnight and only run them when driving.
Hope the info assists.
Muddy
AnswerID: 354949
