Tuesday, Mar 17, 2009 at 21:36
Hello Bomber,
You have already received some good advice ie: use a generator and/or a solar panel or buy a three way fridge.
I have a camper trailer with an AGM 100amp battery installed in it which I can keep charged in either of two ways:
a) a Honda 1000w generator and a 15 amp CTech multi-phase charger. I bought the high-performance charger because it allows for much faster charging of the battery than via the unit inside the Honda generator. The maker of the trailer I own suggested I buy a 30 amp charger, which he claimed would charge the battery in one to two hours. However, I jibbed at the cost !
or
b) a 120W folding solar panel kit. I was encouraged to buy more wattage than I currently need as I will probably end up expanding my camping kit.
I also have an 80 amp. marine-grade deep-cycle battery in a box mounted temporarily in
the tub of my ute with a dedicated connection to the car battery via an isolator. Mostly, this battery runs a 45 litre Engel fridge. If I know I'm going to be doing some travel away from the
campsite, I leave the generator and/or solar panel kit at
home as it only takes a short drive to top up the battery in the box. If I sit in the one place for an extended period, I run one battery down before using the other for the fridge and lights. I can also let the fourby idle for half an hour every now and then if it's not going to annoy nearby campers. That seems to provide sufficient energy to top up the battery in the box.
I also have a dedicated connection from the boxed battery in the ute's tub to the battery in the trailer. When the battery in the box is topped up, the battery in the trailer begins to charge. If you go down this path you may need to get specialist advice and the assistance of an auto electrician as the wiring to the trailer needs to be thick enough to carry current over a distance.
For your needs, I recommend a battery in a box over a dual-battery installation. One great advantage of the boxed-battery set up is you're able to install it in another vehicle (one with an isolator kit fitted) or place it on a charger in the shed when you don't need to carry the extra weight. It can also be loaned to relatives who, from time to time, may wish to borrow the camper trailer.
If you can afford it, buy an AGM deep-cycle battery. It will take a fast charge without any damage and it's suited to the punishment received by a vehicle or trailer on rough roads. It can be positioned upright or on its side. A decent-sized battery will last you a couple of days if you are careful with your choice of fridge. A search of the
Forum archive should provide you with at least two boxed-battery manufacturers, the robust kind that includes a good-sized battery, amp/volt meters, numerous connection points, and an inbuilt charger. The
Forum Archives and articles on this web site are also full of good information. Another good resource I can recommend is www.campertrailers.org
As has already been pointed out, your needs will vary according to the type and size of the fridge and lights you buy and where you
camp. Your budget may also be a limitation !
Remember, there are many
places where you can use a generator, but you need a backup for when you can't. The solar panel kit is great for when the sun shines. However, its effectiveness is limited by its capacity, the number of intense daylight hours available and where you decide to
camp.
If you can afford it, plan your purchases such that over time you end up with a variety of options for charging one or more batteries.
I also have a secondhand 60-litre three-way fridge which I loan to relatives who are technologically challenged. I also use it to increase fridge capacity when the family gets together for an extended camping experience.
I hope this helps.
Netnut
354608
Follow Up By: Bomber_WA - Wednesday, Mar 18, 2009 at 09:51
Thanks very much for all of that. Some very good info there.
The link you gave me to www.campertrailers.org is very very good. The tech tips page has a lot of good info on it.
622794
