Nissan Terrano Drive Belts
Submitted: Saturday, Mar 14, 2009 at 13:52
ThreadID: 66824 Views:2224 Replies:3 FollowUps:0
I was wondering if anyone can help me to identify the correct drive belts for use on a Nissan Terrano 1991 turbo diesel (td27) model?
I am looking at replacing the Alternator, Power Steering and A/C belt's. as they're all looking a bit sad.
I am unsure if the belts are the same as the nissan navara with the td27 motor? Does anyone know if they are the same?
Any help appreciated
Michael
Reply By: Ozhumvee - Saturday, Mar 14, 2009 at 16:29
Usually belts will have the part number printed along the flat (outside) of the belt.
If you can't see them get an assistant to just touch the key to turn the motor over without starting it so that the numbers are exposed.
You may also be able to turn it by hand with a suitable size socket on the crankshaft bolt but this can be hard on a diesel due to compression pressure.
You can either take what numbers you find to nissan for genuine parts or go aftermarket at most auto supply stores.
AnswerID: 353971
Reply By: toyocrusa - Saturday, Mar 14, 2009 at 17:28
Hi. You can also take the belts off and take them to a bearing or belt store and they can measure them for you(Repco or Bearing service or similar) Obviously you will neeed another car to travel in. Bob.
AnswerID: 353987
Reply By: TurboTerrano - Saturday, Mar 14, 2009 at 18:05
Thanks for your reply's.
Yeah took me a few cranks but i got the numbers. looks like i'll be off to repco tomoz.
Cheers!
AnswerID: 353994
