Cruise Control
Submitted: Friday, Mar 13, 2009 at 13:50
new boy
I have a 2008 3ltr auto patrol which drops down a gear going from 2500rpm to 4000rpm on the slightest incline when set at 115 km .
The dealer says it's the way the engine management system is set up and I,m doing no damage to either the gearbox or engine next Thursday he is doing a full diagnostic on the C/C
But I,m curious has anyone else had similar problems
Reply By: Member - Ron M (NSW) - Friday, Mar 13, 2009 at 14:27
Have you got a turbo in it mate
353800
Follow Up By: new boy - Friday, Mar 13, 2009 at 14:34
Yes
621930
Reply By: timglobal - Friday, Mar 13, 2009 at 16:03
Have you put any mods on?
Larger tyres can cause this.
353814
Reply By: PatrolSTL04 - Friday, Mar 13, 2009 at 16:15
Something wrong with the shift settings from the ECU I would think.
A friend has a 2007 CRD Patrol....and I just spoke to him about this, and his will not kick down on inclines until about 1600rpm with cruise running.
Hopefully the diagnostics will show something...but it may not.
Good Luck.
353815
Follow Up By: chisel - Friday, Mar 13, 2009 at 16:35
Original poster has it set to 115kph though. If it dropped to 1600 rpm it would be a lot lower than that.
621948
Reply By: ajd - Friday, Mar 13, 2009 at 16:42
Mine does the same!!
353823
Reply By: Robert H (SEQ)(aka zuksctr) - Friday, Mar 13, 2009 at 17:53
Would it not be dropping down fron overdrive.
Just a thought as i have a manual.
Cheer's,
Bob.
353830
Reply By: mohdkhan - Tuesday, Mar 17, 2009 at 19:51
hi
i have a 2003 patrol with after market cruse and yes it does cut of cruse if climbing bit too much for the vehicle,you have to start driving your self
Khan
354577
