Heat insulation for cabin
Submitted: Friday, Mar 13, 2009 at 11:13
Gossy
I have a RX GQ Patrol which gets fairly warm inside the cabin on long drives. You can feel the heat coming thru the floor :(
I can purchase locally some heat protection tape suited for wrapping around exhaust pipes which I have been told should make a big difference. Also they sell reflective fibre-glass sheets to install under the carpet.
Anyone had any experience with any/both of these products and do they make a difference?
Replacing the carpet underlay won't really help. Only ones on the market are water proofing underlay, and sound insulation underlay.
Ta,
Reply By: Member - joc45 (WA) - Friday, Mar 13, 2009 at 12:08
I used to have a diesel Maverick. Don't recall any probs with heat thru floor.
Fixing a sheet of thin ally or similar above the exhaust, but separated from the floor; ie, with a spacing, should reduce the radiant heat transfer.
Gerry
353775
Follow Up By: Gossy - Friday, Mar 13, 2009 at 12:12
It's only on the big trips where we have been driving all day and it just creeps up on us over the hours. Putting my hand on the raised floor next to the gear stick is quite warm and under our feet.
Car is white with good window tint so not much more I can do there!
621915
Reply By: Member - John M (NSW) - Friday, Mar 13, 2009 at 12:44
Gossy
I had a similar problem on the passenger side of my GU Ute with a high heat transfer through the floor. I had an exhaust lagging blanket made and fitted to the section of exhaust in this area and fixed the problem.
The blanket is as used on exhausts in the marine industry and heavy machinery (like Patrols). Make sure if you do this order it eye lugs sewn in so that you can secure it with stainless steel tie wire.
John | Life isn't about how to survive the storm, but how to dance in the rain! Lifetime Member My Profile Send Message |
353785
Reply By: Gossy - Friday, Mar 13, 2009 at 14:07
good news that covering the heat source does actually work. I guess the tape or blanket is still doing the same trick.
353796
Reply By: workhorse - Friday, Mar 13, 2009 at 18:56
Hi there.
I've used a couple of sheets of roofing sisalation, the material that has a shiny reflective side and a blue side. Place the shiny side against the heat source against the floor pan, so blue side up , then replace your normal flooring.
353849
Reply By: Ozhumvee - Friday, Mar 13, 2009 at 19:04
Be careful wrapping the exhaust because depending on where you live and use the vehicle it may rust the exhaust out.
As has been suggested the best way is to stop the radiant heat hitting the floor with heat shields or purpose built insulation like Dynamat stuck to the underside of the floor.
I then put the cheap closed cell foam sleeping mats between the floor and the vinyl floormats, stops the heat doesn't hold moisture and also drops the sound level down. I stick it to the transmission hump and just lay it on the floor in the footwells, works
You can also use interior Dynamat but it is expensive.
353850
Reply By: Gossy - Monday, Mar 16, 2009 at 09:20
all great
feedback, thanks. Must admit I didn't think of the rust so maybe a floor shield is the better way to go.
354265
Reply By: Madfisher - Monday, Mar 16, 2009 at 18:03
A lot of interior heat comes from the gearbox especially when towing on long trips. The heat can still be felt 2 hours after completion of the journey. If exhaust would cool off much quicker.
A good oil may help.
Cheers Pete
354363
Follow Up By: Gossy - Tuesday, Mar 17, 2009 at 09:09
We don't tow but we do carry the usual heavy weight on long trips (extended fuel tank, fridge, food, water, etc etc.); and yes the floor around the gear box is quite warm.
I was having a look at the patrol last night to see how difficult it would be to remove the seats, plastic around the gear sticks etc. Never done it before but I guess it wouldn't be too hard on a simple GQ Patrol interior.
cheers,
622638
Reply By: Robin Miller - Tuesday, Mar 17, 2009 at 09:28
Hi Gossy
The exhaust tape is the place to start with that problem , its important to hit it at the soucre.
I found it tricky and time consuming to install though and ended up using aluminium wire to hold it in place.
I still went further by placing alumium flashing over the passenger side firewall and spacing it off 1cm , held in place mostly by bits of wire around various pipes etc.
Mine got so hot (because of aftermarket exhaust) that it melted the radio antenna coax that was inside the car but directly touched the firewall - (Nissan replaced the car radio twice - thinking it was faulty - before I diagnosed that I caused the problem with different exhaust)
354486
Reply By: Gossy - Tuesday, Mar 31, 2009 at 17:27
for my update see thread 67371
cheers,
357291
