Can 12v danfoss compressors start some times when on way out? who has had one bu
Submitted: Saturday, Mar 07, 2009 at 20:52
Member - G N (VIC)
Hi all
I recently had my evakool stop working. I had a chat with evakool and they were VERY helpful. they said it was most likely the black box and so we fitted a new one. But no go unfortunaly. The problem is, that the fridge will start some times / many time fine but then will not start at all at other times and just goes to fault.
I will have to get back to evekool on tues but dont want to get a new compressor if its not required.
I thought i had found the issue just after fitting the black box, when i pulled apart the connection where the power enters the fridge and found some freyed wires, but made no diff whe i fixed that iether.
Does any one have any ideas to try before i call evekool again (and propably have to send fridge from vic for expensive compressor)
Kind regards GN
Reply By: Geoff (Newcastle, NSW) - Saturday, Mar 07, 2009 at 22:20
Which error code are you getting?
How big is the wiring between it and the battery?
What sort of plugs are you using on the lead?
Is the battery supplying it in good condition?
Do you have the 240V power supply for it or access to one? If so does the fault also occur on the 240V power supply?
Geoff
| Geoff,
Landcruiser HDJ78,
352836
Follow Up By: Member - G N (VIC) - Saturday, Mar 07, 2009 at 22:43
Hi Geoff
error code with 3 flashes
wiring size is pretty big as its running o a loom supplied / installed to run a liemac what has big power requiremnet much more than this unit.
Using 12volt 2 pin polarised plugs
battery only 6 months old and has condition leds on rotronic independant charge system
also faulted on the 240v adaptor
I stiill have a gut feel its not the compressor?
regards
GN
621002
Follow Up By: Geoff (Newcastle, NSW) - Saturday, Mar 07, 2009 at 22:50
Hi GN,
Gut feel is good most times,
This one, "also faulted on the 240v adaptor" tells me your problem is most likely inside the case of the fridge.
Oh, one more thought, do you use the same cable between the fridge and the 240 adapter as you do between the fridge and the "12V wall outlet" for want of a better term?
It may be a faulty cable or plug if you have a common component on both battery and 240V adapter power.
It doesn't look promising, this is from the Waeco book which "should" be valid for all Danfoss compressors,
Three Flashes
Motor Start Error
If your error light is flashing three times every 5 seconds, the rotor may be blocked or the differential pressure in the refrigeration system is too high or a faulty compressor or faulty control module.
Geoff
| Geoff,
Landcruiser HDJ78,
621007
Follow Up By: Member - G N (VIC) - Saturday, Mar 07, 2009 at 22:56
Yep i agree the fault has to be in fridge.
I have replaced the wire from the power supply to the fridge and have bypassed the plug / socket in the side of wall to eliminate that.
so yes have relpaced black box, but what about the switch etc ???? surley they could be als faulty???
wanted to have more of an investigation this evening but bugger would not fault.
Now dont trust it and not sure what to do.
regards'GN
621012
Follow Up By: Geoff (Newcastle, NSW) - Saturday, Mar 07, 2009 at 23:02
"bugger would not fault."
That is frustrating!
I'll send you an MM to swap email addresses as I've just found a BD35 Danfoss technical document.
It's only 2 pages but it shows the wiring of the compressor and the black box.
Geoff
| Geoff,
Landcruiser HDJ78,
621014
Follow Up By: Member - G N (VIC) - Monday, Mar 09, 2009 at 16:45
Hi Geoff
thanks for the email, i checked it all and seems all correct and good, and it is running / starting now ie will NOT fault, so not sure what to do now??
many thanks GN
621273
Follow Up By: Geoff (Newcastle, NSW) - Tuesday, Mar 10, 2009 at 10:55
Hi Graham,
The only other factor I can think of is heat!
Was the compressor exremely hot when it wouldn't start?
Geoff
| Geoff,
Landcruiser HDJ78,
621379
Follow Up By: Member - G N (VIC) - Tuesday, Mar 10, 2009 at 12:55
Hi Geoff
yes it was hot, the ambient temp was high 30's to 43 when trying to start up, but this shold not stop it.
the compressor has not been running for a few weeks so was not hotter from running earlier.
also when it did go, it then would not start again the foloowing day.
but still as i said the darn thing will now NOT fault so very difficult to find the cause.
I have found out that even the cooling fan can cause it to fault if the fan is faulty but again cannot try as wont fault.
i talked to evakool and they are looking for a local danfoss repairer to take a look at it.
thanks again GN
621392
Reply By: Member - Warfer (VIC) - Monday, Mar 09, 2009 at 00:28
**I recently had my evakool stop working.**
NO GN not the Evakool its just unheard of,Its probably going out in sympathy for all the Engel issues of late...lol
353009
Follow Up By: Member - G N (VIC) - Monday, Mar 09, 2009 at 12:36
Did yours give up? Warfer?
If so what was the fault?
GN
621240
Follow Up By: Member - Warfer (VIC) - Monday, Mar 09, 2009 at 15:42
Hiya GN
Nup mines fine and havnt come across anyone who has had an issue with them...Do you hav the Troubleshooting Flow Chart ???? and where are you in Vic i can look up the nearest Agent to You..But if you have the chart its on the back...
621263
Follow Up By: Member - Warfer (VIC) - Monday, Mar 09, 2009 at 15:48
It says on my chart Three Flashes... 1:Seized Compressor,2: AC Adapter try running in car. Have you replaced the fuse with brand newie ???
Cleaned Compressor and Fan (do not bend fins)
621264
Follow Up By: Member - G N (VIC) - Monday, Mar 09, 2009 at 16:43
Hi Warfer
I have changed fuse to a circuit breaker.
and blew all dust out with air compressor, funny thing was when i did this it went after not starting for a few days and i thoought no way could this have realy fixed it, but then next day went stright to fault again.
Compressor not siezed as since it started faulting it has been running at times? but then will at other time not start / goes straight to fault.
Biggest problem now is that it will NOT fault so how do a find the fault? and so i dont trust it will not let me down when out bush.
not realy sure what do ???
GN
I would like to know how often a BD35 compressor do fail and if is is reasonably possible then that the compressor may be on the way out and so maybe right to put new compressor in it?
But dont want to do that if they hardly ever fail / wear out and then chances are i am putting a new one in for no good reason and the fault is some other cause???
I read that even faulty fans can cause the electronic box to shut down!
621272
Follow Up By: Member - Warfer (VIC) - Monday, Mar 09, 2009 at 17:42
***Biggest problem now is that it will NOT fault so how do a find the fault? and so i dont trust it will not let me down when out bush.**
While at
home leave it plugged to the 240v for as long as you can,i do with
mine just to keep it going instead of leaving it out back for months on end before next trip..
If you hav evakool adapter always make sure its switched to 240v not charge...
621283
Follow Up By: Member - G N (VIC) - Monday, Mar 09, 2009 at 17:56
Hi Warfer
Good idea but i know there is a fault some where and even if it ran for weeks at
home i still would be not confident.
I will call evakool tom as they have been VERY VERY helpfull in the past.
GN
621289
Follow Up By: RV Powerstream P/L - Monday, Mar 09, 2009 at 18:32
GN
If you are in Vic ring Peter Mackay of Oze Fridge. He is up near Shepparton and he carries all the Danfos gear and is a refrigeration Engineer.
It may be cheaper than shipping back to Qld if its out of warranty.
He builds eutectic systems now but has a lot of years of experience under his belt.
Ian
621302
Follow Up By: Member - G N (VIC) - Monday, Mar 09, 2009 at 19:51
Thanks Ian, will
check him out as is much closer although freight costs can be unusual at times.
Would be good just to get another opinion from some one who knows their stuff.
I dont have much confidence in local fridge's
regards
GN
621310
Follow Up By: Member - Warfer (VIC) - Monday, Mar 09, 2009 at 19:56
With all the stuffing around you hav done GN you may hav inadvertently fixed the issue,i'd let it run at
home for a moth or two (putting in a couple of water bottles) to see what happens,Where are you in Vic,i'll giv you a closer Refrigeration Mechanic for Evakool..
621311
Follow Up By: Member - G N (VIC) - Monday, Mar 09, 2009 at 20:55
Mildura
I am still to see anything that has let me down once, stay fixed without fixing (does that make sence?)
Would be good to have someone local who is up to speed.
Perhaps there is someone, i have had some issues with cool rooms previously and have lost my faith in some of the local so called fridgies'
Thanks Warfer
621331
Follow Up By: Member - Warfer (VIC) - Monday, Mar 09, 2009 at 22:12
No worries GN,when you eventually find the fault could you PM me what it was..
Cheers and all the best.
621346
