Trigg and Tregg?
Submitted: Thursday, Mar 05, 2009 at 19:38
Member - Cram (Newcastle NSW)
Ok, the curiouocity has finally got the better of me.
What's the difference between a Trigg hitch and Tregg hitch?
The question came to me when I was looking at the Tregg lock available in the
shop.
It look's like it would work with my Trigg hitch but I am not sure??
Reply By: On Patrol & TONI - Thursday, Mar 05, 2009 at 19:58
Tregg is a manufacturer of all sorts of trailer parts, including a lock as shown in your post that WILL fit a Trig coupling pin.
Trig is a coupling design that uses a semi flexible poly block that in turn can be fitted to an ALKO coupling or a Carter Westco coupling or even a Tregg coupling.
Treg couplingsAL-KO
Hope this helps, Colin.
352378
Follow Up By: Member - Cram (Newcastle NSW) - Thursday, Mar 05, 2009 at 20:14
Ok, sort of...lol they are very similiar is that a fair call??
So if I buy the lock that is in the
shop do you know if that is ok to install for when you are towing?
620596
Follow Up By: On Patrol & TONI - Thursday, Mar 05, 2009 at 20:36
Cram
I use it for just that reason, I can then leave the rig parked and have a slightly better chance it will still be there when I get back.
Colin.
620608
Follow Up By: Member - Cram (Newcastle NSW) - Thursday, Mar 05, 2009 at 21:03
Thanks mate, that is what I am after.
620614
Reply By: Member - Phil G (SA) - Thursday, Mar 05, 2009 at 20:44
They are both very old,
well respected family companies from
Adelaide.
Treg Trailers are around the corner from me at Underdale and designed and made the "Treg" poly hitch. They are the most respected trailer-maker in SA. Started in 1946 by
Gordon Tregonning who worked in the business up until retiring a couple of years ago - at 88 years of age.
http://www.tregtrailers.com.au/
Trigg Brothers are a foundry, making cast iron products such as ball couplings for trailers. They set up in 1925, and are just down the road from me at
Ashford.
http://www.triggbrs.com.au/history.html
We have a 1960 model Treg trailer in the family. Some years back I needed some new wheels, which were Dodge wheels and asked at the counter whether they had any. I was led around the back to see
Gordon Tregonning, who was in his 70's at the time. He took me to the far corner of a lean-to and found a stack of wheels that had sat there for 40years. Asked me whether I wanted 15" or 16". Only wanted $5 each, so I doubled his price and took them away.
352388
Follow Up By: Member - Cram (Newcastle NSW) - Thursday, Mar 05, 2009 at 21:05
Thanks that is awesome....you have to love that sort of tradition...let's hope that China never grabs hold of it!!
620617
Reply By: MEMBER - Darian (SA) - Thursday, Mar 05, 2009 at 22:50
Ditto re Phil's comprehensive response. I've used both poly block couplings - the Trigg is cast, while the Treg is forged - my simple mind thought that castings could not keep up with forgings re strength pound for pound, but it must not be so - the Trigg was very robust - far as I know, the currently polular, highly rated, fully articulating Hyland unit is cast too.
352439
