Cargo Storage Systems
Submitted: Tuesday, Mar 03, 2009 at 21:04
ThreadID: 66476 Views:3141 Replies:6 FollowUps:8
Hi, I have been researching for some considerable time to source a strorage system for my NP Pajero that will allow access to the underfloor storage space provide after the removal of the rear seats. Whilst I have looked at everything I can't seem to find a system that allows relative easy access to this area and I was wondering if any member has had any success in obtaining a suitable system.
Richard
Reply By: Crackles - Tuesday, Mar 03, 2009 at 21:50
Gaday Richard. Not aware of any commercially built storage units that give access underneath but as I had the same requirement in my JK I built my own. It simply is supported on a box section frame that when the draws are all slid out, allows access by folding the rear seats & reaching through from the back. I have enlarged the area under my floor to fit a 2nd battery, compressor, fuses & spare parts storage so although I don't need to get in there very often, it is important to be able to reach in to get what I want without removing the whole unit. Not that it is a big deal anyway as the whole lot comes out in 5 minutes.
Cheers Craig.............
AnswerID: 352076
Follow Up By: Crackles - Tuesday, Mar 03, 2009 at 21:55
Alternatively one could use ball slides that are removeable on all the draws. (eg: like the ones on the draw above my fridge) That way you just remove the bottom slides & reach in from the back.
FollowupID: 620267
Follow Up By: Steve - Wednesday, Mar 04, 2009 at 22:08
nifty set-up that, Craig
FollowupID: 620455
Follow Up By: Crackles - Wednesday, Mar 04, 2009 at 22:53
Thanks Steve. Have made a few now adding extra features each time. The cutlery draw is removable so that it not only fits the Autofridge (pictured) but also takes the new plastic 40L Engel or 39L Waeco.
Where the 2 x 10L water containers fit behind the seat I plan to mount a 45L water tank with pump.
I've used weld mesh sides to maximise fridge ventilation & minimise the weight & with the alloy draws can lift the unit out by myself. Most commecial units are almost twice as heavy & can't simply be unbolted.
My last effort in the 105 series (Below) was similar but I saved some space, money & additional weight by running the draws on Laminex strips instead of the ball runners.
FollowupID: 620459
Reply By: Richard W (NSW) - Wednesday, Mar 04, 2009 at 05:31
Richard,
I also built my own when I had my NM. Built a platform from 15mm pine that sat over the underfloor storage. The side supports were cut back at an angle so the front half of the lid could open enough to give access to the well. Put two aluminium runners just under the platform with a ply shelf that slid out. Didn't have any drawers built on it but would not have been difficult to do.
AnswerID: 352109
Follow Up By: Member - Richard P (NSW) - Wednesday, Mar 04, 2009 at 18:38
Gday Richard,
Thanks for the info, its back to the drawing board I think.
Thanks again mate
Richard
FollowupID: 620394
Reply By: Member - Richard P (NSW) - Wednesday, Mar 04, 2009 at 18:36
Hi Crackles,
Thanks for the info and pics, it looks like the way to go.
Thanks again
Richard
AnswerID: 352194
Follow Up By: dazza62 - Wednesday, Mar 04, 2009 at 21:57
Hi Richard,
Have been going through the same issues as you are for my NS Pajero.
Looked at Black Widow, Outback and several others however have come up with a system from Fourby Fitouts.
Am meeting with Mark there tomorrow night to discuss a system with a few modifications that I require.
Price is just a touch higher than Black Widow at this stage.
Cheers Dazza
FollowupID: 620449
Reply By: Steve - Wednesday, Mar 04, 2009 at 22:07
I'm sure some "professional" help will be along soon......... ;-))
AnswerID: 352232
Follow Up By: Crackles - Wednesday, Mar 04, 2009 at 23:01
Maybe not. Many "Professional" systems are mounted on a plywood base that wouldn't allow access to the storage area underneath like Richard requires. (Hence his problem)
Cheers Craig...............
FollowupID: 620461
Follow Up By: Best Off Road - Thursday, Mar 05, 2009 at 07:41
Maybe so.
We do two types of systems that allow access access to this valuable space. By clicking on the word drawers will lead you into our home page which has shots of the system in the gallery.
Jim.
FollowupID: 620475
Reply By: Member - Richard P (NSW) - Thursday, Mar 05, 2009 at 21:07
G'Day Dazza62,
Thanks for your help, please let me know how you get on.
Richard
AnswerID: 352396
Follow Up By: dazza62 - Thursday, Mar 05, 2009 at 21:43
Just back from a long drive to Hallam.
Mark was away so met with Daniel. There systems are good quality and flexible. "Mix n match" so to speak.
The Pajero version starts with a flat base, however includes a trap door under the fridge cavity to gain access to the seat well for those things you need to carry but don't really want to use often.
As I am also looking at a full back seat fitout they are willing and able to do it. Just need to measure it up and manufacture. They have a system ready to go for a Prado but not a Pajero yet. Looks like my Pajero might be the mould if I go all the way with this.
Was pleasantly surprised with the price. Will be talking further with Mark next week when he gets back and no doubt placing an order. About a week to 10 days to supply.
They have quite a few good pics on their website. You can check it out http://fourbyfitouts.com.au.
Good luck with your decision.
Cheers Dazza
FollowupID: 620628
Reply By: Member - Colin H (NSW) - Friday, Mar 06, 2009 at 20:04
Richard ,Have installed that type of system in my GU patrol from A FIRM IN sYDNEY CALLED "THE DEPARTMENT OF INTERIOR" tHEY ARE IN SYDNEY .
And have every system to suit your needs .Check them out.
Skin and Bones
AnswerID: 352620
