Reserve Tank upgrade for GU 2007 Patrol 3.0l Turbo
Submitted: Tuesday, Mar 03, 2009 at 13:12
Member - Russell C (WA)
I am asking if anyone has had a reserve tank upgrade from 35 litre to 90 l and what other changes needed doing to carry extra weight?
Reply By: Member - Roachie (SA) - Tuesday, Mar 03, 2009 at 13:36
The largest commercially available sub tank I know of for a Patrol is the one from 4WD Systems.....81 litres. I have one of these.
If you fit one, you may need to factor in the extra weight when working out your
suspension. You may need to fit a "boomerang" shaped upper trailing arm to allow the rear axle to fully droop without fouling the rear end of the tank..... I have fitted one of these; available on ebay.
I'm assuming this tank will fit the 2007 Patrol..... I don't think the chassis has changed much; but
mine is a series II (2000) model.
351998
