Looking for Mapping shortcuts
Submitted: Monday, Feb 23, 2009 at 08:34
ThreadID: 66211 Views:2452 Replies:7 FollowUps:19
There is plenty of info in mapping 'Help' lists but no matter where I look it is difficult to disseminate all the info. So I need to pick a luminary's brains :-) (Greg, Thew Explorer..where are you?)
Here is what I have done so far:
I have Placemarked a proposed route on Google Earth
I have written all the Waypoints down in a Word File
Now I want to transpose all of these Waypoints to Oziexplorer.
Does a shortcut exist to do this?....... From Google to Ozi
Or do I have to mark each Waypoint in Ozi....
There are about 70 of them.
Reply By: Sand Man (SA) - Monday, Feb 23, 2009 at 09:02
Hi Willem.
I haven't done it myself but there is an option in OziExplorer to import waypoints from a text file and I know you can create a .txt file from a word document in MS Word.
The one problem you may have is the .txt format probably requires the data in specific colims separated by commas.
If you look in OziExplorer/Data directory there should be a Demo1.txt file you could use for reference.
It may be just a matter of converting your word file to a txt file, then aligning the txt data with the sample.
Bill.
Bill
AnswerID: 350539
Follow Up By: Willem - Monday, Feb 23, 2009 at 09:50
Thanks Bill. Will go have a look
FollowupID: 618837
Reply By: Member - Alan H (QLD) - Monday, Feb 23, 2009 at 09:02
Willem - Is this what you seek?
Importing Waypoints from a Text File
see also Exporting Waypoints to a Text File
To Import waypoints simply select the Import Waypoints from Text File on the Load menu.
The datum used for importing (the datum used for the positions in the file) can be specified, if the datum is in the file in one of OziExplorers standard datums then it will default to this.
Before manually creating your own text files for importing you should create some waypoints in OziExplorer and Export these to a file in the desired format and use this file as a template.
File Format
The format is the same as the Waypoint text files from Waypoint+ but with some extensions.
However these files are not meant for import by Waypoint+ there are extra options on the Garmin menu for importing and exporting Waypoint+ files. The reason Waypoint+ cannot use these files is the datum names are different, when Waypoint+ finds a datum name it does not recognize it gives an error.
RECORD TYPES
Waypoint+ types
The 1st field is signifies that it is a Waypoint record, the characters Waypoint or WP can be used.
Each keyword is followed by a designator that describes what kind of storage is used with latitude and longitude. DM and DMS are stored in as single packed floating point number.
D=decimal degrees; ddd.dddddddd (34.064531922)
DM=degrees minutes; ddd.mmmmmmm = ddd mm.mmmmmmm (34.06548 = 34 6.548')
DMS=degrees minutes seconds; ddd.mmsssssss = ddd mm ss.sssss (34.06453 = 34 6' 4.53")
UTM=zone,easting,northing
Extended Types
To make it easier for text data entry extra extended types have been added.
DMX=degrees minutes; the degrees and minutes are entered into their own fields separated by commas.
DMSX=degrees minutes seconds; the degrees, minutes are entered into their own field separated by commas.
BNG=zone,easting,northing (British National Grid)
IG=zone,easting,northing (Irish Grid)
NZG=easting,northing (New Zealand Grid)
SG=easting,northing (Swedish Grid)
SUI=easting, northing (Swiss grid)
WP, waypoint name, latitude, longitude, date , time , waypoint description.
Example:
Standard Waypoint+ types
The date must be in month/day/year format or left out and the current date will be used.
Examples:
WP,D,WPNAME,34.064531922,-117.2959507350,11/23/1995,19:29:00,Description
WP,DM,WPNAME,34.06548,-117.80632,11/23/1995,19:29:00,Description
WP,DMS,WPNAME,34.06453,-117.29595,11/23/1995,19:29:00,Description
WP,UTM,WPNAME,56J,445946,7063980,11/23/1995,19:29:00,Description
Extended Types (preferred for manual data entry)
WP, waypoint name, latitude(multiple fields), longitude(multiple fields), date , time , waypoint description.
Examples:
WP,DMX,WPNAME,34,6.548,-117,80.632,11/23/1995,19:29:00,Description,Symbol
WP,DMSX,WPNAME,34,6,4.53,-117,29,5.95,11/23/1995,19:29:00,Description,Symbol
No fields are case sensitive, lowercase or mixed case can be used in any field.
The symbol is coded as A=0 B=1 C=2 etc
The Garmin GPS waypoint display format is also added to the end of the line after the symbol, however it is not guaranteed that this will be continued in future. N = Name S = Symbol C = Comment
Datum
The datum can be specified in the file.
The Datum Record Type
DATUM,WGS 84
The datum is optional, if it is not there you will be requested for the datum.
The datum must be a recognized OziExplorer datum name, these can be viewed on the datum list.
When importing the file the software will allow you to modify the datum.
AnswerID: 350540
Follow Up By: Willem - Monday, Feb 23, 2009 at 09:52
Thanks Alan. I will try to get my head around that...lol
FollowupID: 618838
Follow Up By: Member No 1- Monday, Feb 23, 2009 at 10:45
its a bighead so it wont be a problem for ya hahaha
FollowupID: 618842
Follow Up By: Willem - Monday, Feb 23, 2009 at 11:12
Why aren't you at work Member .5 ??
FollowupID: 618846
Reply By: Member - John and Val W (ACT) - Monday, Feb 23, 2009 at 09:12
Willem,
Having got your placemarks on Google Earth (GE), in the left hand side panel, ensure they are selected (box'es ticked) and right click on them. "Save place as" will bring up a dialogue box - select the .kml file option (not .kmz) and save to a your drive. Ozi (the recent versions) will load this file (File|Load from file|import Google Earth (.kml) File.)
You can also make a track in GE by dragging your mouse along the intended route. This will generate a file which can be saved as .kml and fed into Ozi.
Hope that helps
J and V
- Albert Einstein
AnswerID: 350542
Follow Up By: Willem - Monday, Feb 23, 2009 at 10:14
Thanks John
So far it looks like the easier option.
I have done what you said. Saved a Placemark to Data in Oziexplorer on my C drive. BUt when I Load Waypoints from File in Ozi Data it is not there??
Also how do I drag a track route?
FollowupID: 618839
Follow Up By: Member - John and Val W (ACT) - Monday, Feb 23, 2009 at 11:09
Willem,
The facility to load .kml files into Ozi was added to Ozi a while back. It is possible you are running an earlier version which does not have this included. I have version 3.95.4q which does have it. To find it in Ozi, click File, then Load from File, which will give you a list including (at the bottom in my case) "Import Google Earth (kml) file". Simply click on that and tell Ozi what file and where it is.
If you don't have this option, check your version number (in Help|about) and if it's older than 3.95.4q it would be well worth downloading and installing the latest version. (No cost for registered users.)
I haven't used this recently, so a bit rusty, but I'll check it out and set up a few tracks, then get back to you.
J and V
- Albert Einstein
FollowupID: 618845
Follow Up By: Member - John and Val W (ACT) - Monday, Feb 23, 2009 at 11:12
Willem, just noticed you're trying to load "Waypoints from File". No - you must use the "Load Google Earth (.kml) File" option. Having got them into Ozi, you can then save them as waypoints in the usual Ozi way.
J and V
- Albert Einstein
FollowupID: 618847
Follow Up By: Willem - Monday, Feb 23, 2009 at 12:31
Hi John
Thanks for your help. I must have an earlier version as I don't see Google in Ozi.
Will have to do things the hard way...sigh.....LOL
FollowupID: 618854
Follow Up By: Member - John and Val W (ACT) - Monday, Feb 23, 2009 at 13:06
Willem,
Sounds like you have an older version. It may well be that it's quicker to download and instal the latest (it's now up to 3.95.4s so I'm out of date too!) rather than "do things the hard way". As Chris mentions below, you'd also gain the ability to look at Ozi tracks in GE which can be pretty useful.
J and V
- Albert Einstein
FollowupID: 618859
Follow Up By: Willem - Monday, Feb 23, 2009 at 13:33
Hi John
Downloading 3.95.4s at the moment. Will report back
FollowupID: 618862
Follow Up By: Willem - Monday, Feb 23, 2009 at 13:57
Thanks John
It worked!
Thanks also to everyone who contributed to this thread.
This is why ExplorOz is such a fantastic site as there are people(you) out there with knowledge of ' How stuff works!' !!
Now I can get on with my project.
FollowupID: 618866
Follow Up By: Willem - Monday, Feb 23, 2009 at 16:42
I have struck a snag
I have shifted all of the Google Earth Placemarks to my C drive and am able to load them into Ozi. BUT as I load each one the previous one disappears. I would like to load them all. HELP!!
FollowupID: 618895
Follow Up By: Willem - Monday, Feb 23, 2009 at 17:19
Ummm I think I have figured something out
Import from Google Earth kml file and Save to Waypoints File
Now how do I load all of them so that I can set a track?
FollowupID: 618907
Follow Up By: Member - Fred B (NT) - Monday, Feb 23, 2009 at 18:00
Willem, I have the same problem, I can only save or copy one at a time. There must be a way to copy and save multiple points from GE to a .kml file....? The other problem I have... John & Val said to "drag the mouse across the map to form a track" .... all that does is move the GE image, not produce a track.... John & Val help?
Fred B
VKS 737: Mobile/Selcall 1334
FollowupID: 618918
Follow Up By: Richard W (NSW) - Monday, Feb 23, 2009 at 18:20
Willem,
Have you resolved the problem yet? We worked out how to do it at Willies place about 12 months ago but I can't rember the sequence off the top of my head. Happy to have a fiddle and get back if you still need a solution.
FollowupID: 618922
Follow Up By: Member - John and Val W (ACT) - Monday, Feb 23, 2009 at 18:46
Willem, Fred
Hey guys, I'm no expert, just been there and fallen into most (I hope there aren't too many more!) of the traps.
Willem first.
The trick is to get all your placepoints into a single folder, then save the folder as a .kml file.
From the GE help facility :
"You can create folders and move other folders, placemarks, or shapes to them. To create a folder:
1. Right-click on a folder in the Places panel.
2. Select Add > Folder from the pop-up menu. The folder you right-clicked on is automatically set as the container for the new folder.
Once the New Folder dialog box appears, you can set the following fields:
* Name
* Description - Enter a description for the folder. For example, you might enter text that gives a general description of all the placemarks in the folder. The first few words of the description appear below the folder in the Places panel. When you double-click the folder, the description appears in a balloon in the 3D viewer." .................blah blah blah...
In practice, go to your first placepoint, RIGHT click, ADD|FOLDER to create a folder with the name of that placemark. Then drag and drop the other placemarks into that folder. (This becomes the default place too, where any new placemarks are stored.) When you've got them all in there, Right click the FOLDER and save it as a .kml file. Ozi will pick up this file and display ALL the waypoints!!
Fred - I apologise for my vague description. As said, I'm no expert and you tend to forget the little traps you fell into a few months ago.
To make a track (a path as GE calls it), rather than a waypoint/placepoint, click on the icon in the top row - 3 little diamonds with tracks between. A box will appear where you can give the track a name (and do a lot of other stuff if you want to). The trap - Do NOT click OK until you are finished with your track, as that will terminate your track record and you'll revert to dragging the map around using your mouse. The cursor will change to a square with index marks on each side. Click and hold the mouse button down at the start of your track and hold it down while you trace the track. (You can also just use a series of clicks along the track if you prefer, but GE puts in lots more placepoints than you would have the patience to do, so gives a better track.)
During all this, the mouse is busy following the track, so if you need to move the image, use the keyboard up,down,right,left buttons.
Only when you've finished your track do you now hit the OK button in that first screen that came up after you asked to make a track. The track will then be saved and will appear in the left hand sidebar. From there, select it, RIGHT click and save to your machine as a .kml file that Ozi can use.
Hope that makes sense. I know just how frustrating GE can be. It's an incredibly powerful tool, with huge power to confuse and frustrate!! (There's more stuff hidden behind the right mouse button than I've found anywhere else too.)
Good luck to you both
J and V
- Albert Einstein
FollowupID: 618926
Follow Up By: Member - Fred B (NT) - Monday, Feb 23, 2009 at 19:10
Thanks so much for the help.... there are only so many hours in a day... and so many different software programs to learn with thousands of hidden functions (well... hidden to me anyway... l) Technology is great when you know how... frustrating when you don't. That's another reason why this site and it's members are so good.
Fred B
FollowupID: 618932
Reply By: Member - Fred B (NT) - Monday, Feb 23, 2009 at 09:50
Thanks Willem, you have just got the above "helpful ones" to answer some of my questions for me. Thankyou "helpful ones".
Fred B
AnswerID: 350546
Reply By: Member - Chris & Debbie (QLD) - Monday, Feb 23, 2009 at 12:45
Also as a matter of interest you can easily view, tracks, waypoints etc. that you have in Oziexplorer in google earth. To do this, open your tracks, waypoints in Oziexplorer, then click on File - Save to File - Export to Google Earth. In the dialog box that opens click on the third button from top left (view data in google earth), google earth will open automatically zoom in and display your tracks and waypoints.
Chris
Coddiwomple (v.) To travel purposefully towards a vague destination.
AnswerID: 350560
Follow Up By: Willem - Wednesday, Mar 11, 2009 at 15:18
Hi Chris
A belated Thanks for that info. I have had cause to use it today and it works!!! :-)
FollowupID: 621578
Reply By: Member - Phil G (SA) - Monday, Feb 23, 2009 at 19:35
Willem,
If you want to amalgamate a few sets of waypoints, then under the "LOAD" icon you will find "Append waypoints from file". Keep doing this so all your waypoints are showing on the map and then save them to a single file.
If you want them to be visible on a particular map, then load the map; then under the file tab, click "check calibration of map", then click on "Options" and you can attach as many waypoint or track files to the map. I find this really useful for cross-country travel if you are following someone else's tracks. So whenever you load the map, the tracks and waypoints appear.
AnswerID: 350649
Follow Up By: Willem - Monday, Feb 23, 2009 at 22:01
Thanks Phi
Cheersl
FollowupID: 618991
Reply By: Member - Fred B (NT) - Tuesday, Feb 24, 2009 at 00:26
Thanks to Willem for starting this thread, and thanks to all of you for you assistance. I actually have it all working now.... simple when you know how.... now, the trick is not to forget in the future when I need to do it again. Good night all.
Fred B
AnswerID: 350696
