ARB Compressor stops - starts
Submitted: Thursday, Feb 19, 2009 at 13:35
Treading Lightly
Hi Guys,
Been using a ARB Compressor fo 5 years never a prob. Over the weekend it pumped up 1 out of 4 tires and stopped. Checked power all OK to the relay. 10 minutes later all OK. Do they have a thermal cut out?
JD
Reply By: Wayne (NSW) - Thursday, Feb 19, 2009 at 14:15
JD,
Yes
Wayne
349877
Follow Up By: Treading Lightly - Thursday, Feb 19, 2009 at 16:14
Wayne,
I take it that the thermal fuse is internal in the motor, and is hidden in the depth of the stator.
JD
618177
Reply By: toyotabits.com - Thursday, Feb 19, 2009 at 14:20
G'day all, does anyone have a wiring diagram for a ARB compressor? thanks, aussiedingo
349879
Follow Up By: Member - Warfer (VIC) - Thursday, Feb 19, 2009 at 14:30
What model you after ???
If its a CKMA12 send me your email addy and i will scan its wiring diagram for you...
618163
Follow Up By: Bushtrek - Thursday, Feb 19, 2009 at 14:40
Here is a link to the ARB Service manual.
On the last page there is an internal link to the Wiring diagram and also the electrical fault diagnosis.
I do not believe they have a thermal cut - out as standard fitment.
ARB Service Manual
Make sure your Adobe Reader is set to open pages in web browser, otherwise the internal pdf links will not function
Hope this helps.
618165
Follow Up By: Treading Lightly - Thursday, Feb 19, 2009 at 15:17
Bushtrek,
Thanks for info, recieved ARB Manual but it only lists the parts manual not a service or electrical faults.
Regards JD
618167
Follow Up By: Bushtrek - Thursday, Feb 19, 2009 at 15:30
JD
If you can see item 5.8 click on this. The link works for me.
It's on page 3 [of 4]
618169
Follow Up By: Treading Lightly - Thursday, Feb 19, 2009 at 16:12
Bushtrek,
Makes me feel like a #ick #ead thanks fo info. It gives me a starting point.
JD
618174
Reply By: MEMBER - Darian (SA) - Thursday, Feb 19, 2009 at 14:35
My mark 1 model is about 8 years old and is still working fine. I was assured at the time by the ARB salesperson that it does not have a thermal cutout.... "doesn't need one" ......?
Could fry and egg on it at times but it keeps on keeping on.
349880
Reply By: Member - Warfer (VIC) - Thursday, Feb 19, 2009 at 15:52
Try this you can save then zoom in !
Image Could Not Be Found
349893
Reply By: Treading Lightly - Thursday, Feb 19, 2009 at 16:13
Thanks guys for all info.
JD
349895
Reply By: Motherhen - Thursday, Feb 19, 2009 at 16:54
Hi JD
We have one of those red compressors - red devil or something. It managed all 8 tyres in the
Kimberley, but further into the trip it started overheating and cutting out, getting progressively worse - eventually to the extent of being unusable. Sounds similar to yours.
Problem not resolved as yet.
349902
Reply By: Wayne's 60 - Thursday, Feb 19, 2009 at 18:22
Hi JD,
I'm not sure if this will help, hope so.
I've been having a similar problem with my second hand ARB unit which seems to have a problem with one of the valve stems on my tyres, pumps the other three up without problem. When using the unit today I had the stop start, pushed the chuck hard onto the stem and held it in place, no problems in finishing the job. May have to invest in a new chuck.
Wayne.
349911
Reply By: On Patrol & TONI - Thursday, Feb 19, 2009 at 19:42
JD I had the same problem with my indicators on my car, on off on off, I tracked it down to the relay also.
I removed the relay and "Viola" they now stay on all the time. LOL
The devil made me say it.
Cheers Colin.
349925
Reply By: Sea-Dog - Friday, Feb 20, 2009 at 17:50
My ARB compressor that came with my lockers got a bit lazy and after pumping for a while would slow down to a stop... I pulled the compressor unit down and refreshed all the connections and cleaned out the motor of dust etc and gave the bearings a bit of a oil and free up..... now it runs better than when it was new out of the box.
350106
