towing in 5th gear
Submitted: Thursday, Feb 19, 2009 at 08:20
Member - dennis&evelyn Z (TAS)
I am towing a 14ft 1400 kg van, that i have only had for few weeks with a 1hd fte troopy. i am getting mixed advice with regard to towing, I tow in 4th gear but a number of opinions is that i can tow in 5th.I have tried towing in 5th and it seems to be no problem, what is the experience out there?
thanks, dz
Reply By: Notso - Thursday, Feb 19, 2009 at 08:27
I was advised by the RAC that it was inadvisable to tow in Overdrive 5th in these types of Boxes. Nissan Toyota etc.
Nissan told me it was OK to tow in 5th and the box stripped the spline on Top Gear at about 45,000. Friend with a toyota and a lot heavier van than yours had his box rebuilt three times because he refused to tow in 4th because Toyota said it was fine to tow in 5th.
So who knows, I know a lot of people with Toyotas and Nissans who have towed in 5th with no problems. I now tow in 4th and the difference in fuel economy is closer than a bee's whisker.
349822
Follow Up By: Member - Taipo (VIC) - Friday, Feb 20, 2009 at 19:29
What yr Patrol?
618440
Follow Up By: Notso - Friday, Feb 20, 2009 at 19:59
2000 3.00litre,
This model had a bigger problem than most with the gearbox.
Nissan bought out a fix for it in about november 2002 I think. But I have heard of others with the problem built since then. Not first hand though!
618445
Reply By: hotfishez - Thursday, Feb 19, 2009 at 08:41
alot depends on the speed and weight of what you are towing. A 750kg rated trailer 5th gear will be ok, a caravan or boat, generally you are only travelling around 80 - 100 kph, not really fast enough for 5th gear, too low speed = too much work to drive 5th gear and 5th gear is the weakest gear in almost any manual gearbox.
349823
Follow Up By: Shaker - Thursday, Feb 19, 2009 at 22:54
80 - 100kph ... too slow for 5th????
618279
Reply By: Willem - Thursday, Feb 19, 2009 at 09:39
This post has been read by the moderation team and has been moderated due to a breach of The Personal Attacks Rule .
Forum Moderation Team
349836
Reply By: Kruzaman (NSW) - Thursday, Feb 19, 2009 at 11:05
Do you know if you have a cast iron case gearbox or the alloy case gearbox. If not sure where is your low range (do you pull the short stick straight down (alloy) or down than across> (cast). If you have a cast iron box fifth gear sits on the back of the counter shaft and is not supported by a bearing, towing in fifth gear is very hard on this gear. With the alloy boxes fifth gear is supported on both ends and can deal with more load but is still hard work for fifth gear. I have an alloy box in my Toy and tow a Kimberly camper trailer and only use fifth gear on down
hill runs and flat running, in the hills I only tow in the first 4 gears
hope this may help
Lee
349856
Reply By: bockstar1 - Thursday, Feb 19, 2009 at 11:26
Running a Mazda Tribute, 4 speed Auto with a Challenge C/T.
We got close to killing the gearbox in our car recently. It was on day 2 of a Red Centre trip. Found tranmission fluid sprayed from the front of car to the back and onto the front section of the C/T.
Fixed in
Broken Hill at the BP. They installed a second cooling unit and replaced the (very black and burnt) transmission fluid.
For the rest of the trip and in subsequent trips with the C/T, we always drive with the O/D off and no cruise control!!
With towing the C/T, at the slightest whiff of an incline, the car is going back to 3rd pretty consistently. Less of an issue in the outback but heading out of
Sydney over the Range and through the towns out west, the gearbox is doing a lot of work.
Cheers.
349862
Reply By: Member - Henry L (SA) - Thursday, Feb 19, 2009 at 12:02
Hi Dennis,
If you still have your owners manual have a look in it.
Toyota don't recommend towing in fifth gear (manual trans.) or overdrive (auto trans.)
In saying that I will use 5th if I am towing a light load only, and 4th for everything else.
hope this helps.
Henry.
349867
Follow Up By: Member - sdr00y (Beecroft) - Thursday, Feb 19, 2009 at 13:59
Second this post. My troopy manual says not to tow in 5th. It is an older model though. Read through yours and see what it says. Page 42, in the transmission section. Good driving practice. "When towing a trailer, in order to maintain engine braking efficiency, do not use the fifth gear."
Now that does not really say don't do it because you will ruin your gearbox, but it still says don't do it!
Again, your manual may be different so
check it.
sdr00y
618157
Reply By: Member - DAZA (QLD) - Thursday, Feb 19, 2009 at 12:25
Hi All
When we tow the Van, I disengage the Overdrive,and push the
Power Button on, which is written in the Manual, no problems at
all, might use a bit more diesel which is insignificant in the whole
scheme of things.
Daza
349869
Follow Up By: Richard Kovac - Friday, Feb 20, 2009 at 00:12
Daza
In your case, I wouldn't Had thought it to be as mush a problem, assuming you have an auto?
I would have thought the converter would have taken up any overload and transfered it into heat, as in oil temp?
Richard
I not questioning what you have stated just a thorght...
618297
Follow Up By: Richard Kovac - Friday, Feb 20, 2009 at 00:37
much a problem
618300
Reply By: Motherhen - Thursday, Feb 19, 2009 at 13:41
Hi Dennis
I am pleased to see that most are advocating not towing over a tonne in overdrive of fifth. Usually this question gets replies from a few who say they always do and haven't come to grief (YET). It may cost you a bit more in fuel, but not only are gear boxes expensive to repair/replace in Cruisers, but the cost could be extreme if you break down in a remote area.
349874
Reply By: Gronk - Thursday, Feb 19, 2009 at 14:11
I know this problem only seems to affect Toyo's and Nissans..( I drive a CRDI Terracan.....gearbox probs unheard of ?? )
But what if you like to drive at 110K's ??
Mine would be doing approx 3500rpm and thats a bit high for my liking ??
349876
Reply By: Flywest - Thursday, Feb 19, 2009 at 14:52
3 new gearboxes in the ol bitsamissing triton 4x4 2.5TD eventually convinced me!
I don't think any of them were under $3K
If you look inside the gearbox and see where the O/drive lay shaft is out tio the side and the tiny needle roller bearings that support it - then you woiuld understand and never tow in 5th.
One of the supposed 'fixes' for that particular box back in the day was to have the alloy box housing mounted up in a lathe and the bearing races for the OD lay shaft at each end turned out to take a larger bearing race with ball bearings rather than pins...
450,000km's and the last repaired box is still going strong - a new owner has it now - hopefully it won't et him down!
349884
Reply By: beelzebug - Thursday, Feb 19, 2009 at 14:56
Fella's, might be a silly question, but with a six speed manual (Nissan Navara D40 diesel) is it OK to tow in 5th?
Gary
349885
Follow Up By: Madfisher - Thursday, Feb 19, 2009 at 21:24
Depends on the layout of the box in question, but if it is overdriven then not a good idea.
For what its worth I tow in 5th, but as soon as I have to use more then about half throttle I change down. This was a issue with the Paj as it is much lower geared then the Jacks and was reving its head off at 100 in fourth, where as in the Jack I sometimes forget to change back up.
Cheers Pete
618246
Reply By: kend88 - Thursday, Feb 19, 2009 at 20:29
Agree with all those against towing in OD. Apparently it's not only the transmission/gearbox which will suffer, but also the motor.
A free revving motor will last a lot longer than one which is straining in lower revs. Particularly for petrol motors.
Fuel consumption is much the same and it's a much more pleasant trip if you are not constantly having to worry about changing up and down at every
hill or head wind. Just turn the radio up a bit if you don't like the higher revving sound of the motor. Better for the motor/transmission and the wallet.
Ken D
Bris
349934
Reply By: Shaker - Thursday, Feb 19, 2009 at 22:58
My previous vehicle was a Nissan Terrano 2 - 2.7 TDI, just on 400,000kms, many of which were towing an 1100kg camper trailer using 5th gear as much as possible.
349975
Reply By: Richard Kovac - Friday, Feb 20, 2009 at 00:03
dz
we tow a 11.5" 1500 kg off road (sort off) caravan, and I tow in 4th gear. The Toyota operators hand book say to tow in 4th because of the greater braking effect, it says nothing about the load that the 5 th gear may take. We have a Troopy and the gearing is such that you don't have to change into 5 th untill 100 km/hr so seeing how the speed limet in Wa is 100 km/hr when towing over 750 kg we have no problems.
and hope this is of some help
Richard
349984
Reply By: Member - dennis&evelyn Z (TAS) - Friday, Feb 20, 2009 at 13:42
Only just got a chance to get time to get back on. Thanks to all that replied to my original thread, Re towing in 5th. I think I will stick to my present practice of towing in 4th. The last time I towed a van was back in the 70s with a three speed nissan patrol.
thanks again, dz.
350062
