does anyone know what amp hours is a Yuasa uxh63-12 ??
Submitted: Saturday, Feb 14, 2009 at 11:29
gonebush SA
hi we have just bought a secondhand deep cycle battery, it's a Yuasa uxh63-12, i have done a google search but was unable to findout how many amp hours it is, the bloke we bought it from thinks it's an old Telstra used battery, so if any one could shed some light on it i would be quite greatfull, thanks from chris.
Reply By: Notso - Saturday, Feb 14, 2009 at 11:43
Site Link
This is a link to their Brochure.
The 20 Hour rate is 63 AH
349011
Reply By: oldtrack123 - Saturday, Feb 14, 2009 at 11:43
Hi Gonebush
I would think since it is a deep cycle it's /was 63 ahr.
Their output does decrease with age so no idea what it's present capacity may be.
349012
Reply By: Member - Smiley Bill - Saturday, Feb 14, 2009 at 12:22
Hi GB,
In my experience the model number gives you the info.about the battery, in your case e.g.
uxh - that is the size of the battery, L x W x H.
63 - A/hr rating
12 - the voltage
This method of reading the model numbers would apply in the vast majority of cases.
SB
349018
Reply By: Ozboc - Saturday, Feb 14, 2009 at 18:10
why would you buy a second hand battery not knowing what it is , and how old it may be ?
may be 1 AMP hr --- not knowing its history
Boc
349057
Follow Up By: gonebush SA - Saturday, Feb 14, 2009 at 19:57
when you see the size of it you know it's not a 1 amp, it's quite a good size, but being on a pension we need to watch the $ so when we came across this at $15 it was worth the gamble, even if it hasn't got many years left in it what does it owe us?, we have since put it on the charger and all seems good.
chris.
617296
Reply By: Shaker - Saturday, Feb 14, 2009 at 20:16
Google knows!
YUASA SEALED LEAD ACID SLA UXH63-12, 12v 63Ah, L(mm) W(mm) H(mm) 363 128 217, 1 Piece in a pack, Price for 1 pack Specification: Item/type: UXH63-12, Nominal Voltage: 12, Nominal capacity (20HR): 63, Internal Resistance: 5.0 Weight(KG): 25 approx. Dimensions(mm) Length: 363 Width: 128 Height: 217, Explosion proof filter: Yes Designed with unique valve regulating devices and acid free constructions, ensuring safety and suitability to the contemporary business environment Designed with unique valve regulating devices and acid free constructions, ensuring safety and suitability to the contemporary business environment. Design life: 10 Years Features: upto 15% more capacity, Maintenance-free, Higher Energy efficiency, Negligible gas emissions, Valve regulated, Systems compatible, Fitted with explosion proof filter, No equalizing charge required, No free acid (Non-spillable battery) Applications: UPS, Telecomminications, alarm systems, Fire and security systems, Emergency lighting, Engine starting, Solar powered systems, Utilities, Rail.
349074
Follow Up By: oldtrack123 - Sunday, Feb 15, 2009 at 22:52
So now all you need to find out is the correcting charging requirments. Is it agm SEEMS LIKE IT.
Why not call Century/Yausa aust for charging details .
617545
