Cooking Putty over a fire
Submitted: Tuesday, Feb 10, 2009 at 20:28
ThreadID: 65876 Views:2597 Replies:4 FollowUps:8
Today I needed(no pun intended) to fill a small hole with some material which would stop leaks.
I scratched around in one of my tool boxes and found some blue and white Putty. After tearing a section off I found that it was quite hard, mainly from age. Last time I used it was to plug a fuel tank in Gregory National Park in 1995....lol
So after experimentation in the microwave ( the boss was out of town ) and 7 minutes in total, I got the putty back to a malleable substance, kneaded it and applied it to the hole.
So I was thinking that if one found the putty gone hard while in the bush you could cook it over the fire like marshmellows or use a shovel blade to heat it up!
Reply By: Member - Axle - Tuesday, Feb 10, 2009 at 20:54
Just go and stock up with a modern version of what YA got !! FOR "GODS SAKE".
Cheers Axle.
AnswerID: 348512
Follow Up By: Willem - Tuesday, Feb 10, 2009 at 21:03
Yerrrr...I did that too....LOL
FollowupID: 616695
Reply By: Member - Lionel A (WA) - Tuesday, Feb 10, 2009 at 21:06
Putty and chips.........sounds ok to me.
Cheers....Lionel.
AnswerID: 348514
Follow Up By: Rolly - Wednesday, Feb 11, 2009 at 20:49
That's a chip putty!
FollowupID: 616851
Reply By: Member - Paul W (VIC) - Tuesday, Feb 10, 2009 at 21:33
I wont leave home without steel putty,it has saved me when in the middle of the bush.i never thought it would hold in hot oil but ti does! very cheap insurance i say! cheers Paul
AnswerID: 348520
Follow Up By: Member - Warfer (VIC) - Tuesday, Feb 10, 2009 at 21:37
Ive often looked at that Paul,and put it back thinking you idiot you'll need it one day..Do you recommend particular brand ????
Cheers mate
FollowupID: 616711
Follow Up By: ross - Tuesday, Feb 10, 2009 at 22:28
JB Weld is ok
FollowupID: 616719
Follow Up By: Member - John & Sally W (NSW) - Tuesday, Feb 10, 2009 at 23:50
Selleys knead it is pretty good. You can get 2 types. 1 for under water and 1 for steel (metal). If you google it the selleys site can give details of temperature resistance and applications. We have a tube of each in the tool box. Also have some epoxy putty but think it might be past it by now. (might try Willem's trick of microwaving it)
Sally
FollowupID: 616736
Follow Up By: handy - Wednesday, Feb 11, 2009 at 07:23
you can get knead it for plastic as well.
good for batteries etc. cheers
FollowupID: 616750
Follow Up By: Member - Paul W (VIC) - Wednesday, Feb 11, 2009 at 21:19
Yeh the Selleys one, Kneed it steel, absolutely brilliant stuff, for $14 odd bucks its well worth it.
FollowupID: 616858
Reply By: Member - Oldplodder (QLD) - Wednesday, Feb 11, 2009 at 18:28
Try minties (the sweets).
They got me home from the cape with 7 small cracks in the fuel tank.
Chew until soft, then push in. (or leave packet on the dash for an hour or so.)
They go hard pretty well, and they lasted me 18 months after I got back until I replaced the tank.
They seem to stick to petrol tanks and oily surfaces better than the two pack putty which I tried first.
No 1 son suggested it at age 12, after getting into trouble for dropping them on the floor mats and not being able to get them off. :o)
So we always have to have a packet of minties in the car for a trip. :o0
AnswerID: 348624
Follow Up By: Rolly - Wednesday, Feb 11, 2009 at 20:52
The trouble with minties is that they just don't keep.
They seem to evaporate or something.
Eventually all you're left with is a few wrappers in an empty bag !
FollowupID: 616852
