gu ijector replacment
Submitted: Saturday, Feb 07, 2009 at 16:19
toffy
how easy is it to replace injectors at
home do u need eany special tools
Reply By: Cruiser Crazy - Sunday, Feb 08, 2009 at 02:43
You need special
tools to
check the spray pattern of each new injector before you install them.
If the spray pattern is not correct, your diesel might smoke more then it does now.
Cruiser Crazy
348094
Reply By: al - Sunday, Feb 08, 2009 at 10:39
hi toffy
i did
mine a little while a go in a gq td4.2 no special
tools needed if you are just swapping them over. got my replacement injectors from local diesel place that does exchanges reconditioned not new. think they where $65 each. make sure you put in new seals in before you scew them back in.not hard just takes a bit of time. if it is the 3 litre you have i haven't got a clue so disregard the above.
regards
al
348128
Reply By: toffy - Sunday, Feb 08, 2009 at 15:25
thanks to u gys that replyed wee will give it a go and se how we go
348166
