Tow Ball Standards.
Submitted: Saturday, Jan 24, 2009 at 14:50
ThreadID: 65373 Views:17356 Replies:10 FollowUps:22
Much has been written in recent days on both this forum and others concerning tow bars, WDH, couplings and the legal requirements. Some of the information offered has been well presented while a great deal has, in my opinion, been drawn away from the real issues.
If I may present an actual case (mine) and then seek the input from this learned community of like minded people.
I have a 17’6” Off Road/High clearance van. Tandem 15” wheels on simplicity suspension and with an Al-Ko ball coupling. This is as the van was displayed at the Brisbane Caravan Show.
My tow is a 2005/6 Toyota LC 4.2 TD with Hayman Reese towbar complete with 750lb WDH.Also has Poly Airbags in rear coils. The WDH was set up by the selling dealer.
The van sits level when the tow ball coupling is 650mm from the ground. Loaded and ready to roll that drops to 600/625mm depending upon loading. Airbags at 18psi.. In this configuration it is stable and tows very well across all normal highways, developmental roads and even the blacksoil etc property access roads of western Queensland. Note not talking Cape York or ‘bushbashing’ type conditions. Does not react poorly to ‘wind sheer’ from high speed triple trailers.
Now it transpires that the Australian Standard AS 4177 sets out that among other things a tow ball coupling should be set between 320mm and 460mm max from the ground when measured to centre of ball. Outside of that height range makes the van non-compliant and therefore illegal. The Standard is specific and does not set a max for anything other than a ball coupling. Hyland is a ball type coupling. General consensus is that AT35, Tregg and Orac are excluded and can be set at any height although there is a school of thought that the term “ball” has been used in a generic sense and the limits would therefore be applicable to all couplings.
So I look at the alternatives without making drastic alterations .such as cranking the ‘A’frame.
• Drop the ball mount to comply. Puts van in a nose down attitude and totally destroys the stability of the combination.
• Continue to run as is and take the risk of having an accident. Best advice is that from an insurance point of view in the event of an accident the policy would be worthless as the van was non-compliant to Australian Standards. Indications were given that assessors for three of the major insurers here in Queensland have been taking this aspect and ball weight seriously for the past few months.. In the event of a death resulting from involvement in an accident the best bet is that the Coroner would have a field day and un-limit the liability.
• Change the coupling to say an AT35. Difficult to hook up (had one on a CT previously. Good hitch but could be a finger jammer). Also comes with a range of opinions as to the suitability of running any of these pin type couplings with the WDH. In general the manufacturers appear to favour not using WDH but it depends on the person you speak to. Three for, two against. Also the issue of vehicle manufacturers requiring the use of a WDH to allow the max ball weight which applies regardless of coupling type
To date the manufacturer of my van and the dealer don’t want to know but make comments about what everyone else is doing. Both have indicated they ‘will get back to me’. Other dealers have commented on how the standards are stupid so they are ignored One even went so far as to state that any manufacturer who was not a member of RVMAA did not have to comply to the Australian Standards.
The RVMAA has confirmed that they are aware of the problem and would appreciate any submissions which operators could make to the Standards Committee in order to have the standards reviewed/changed. Bear in mind the RVMAA is a manufacturers Association and not all manufacturers are members.
Best estimate by others in the industry is that between 40% and 60% of off road (high clearance) vans are running ball couplings which do not comply with the height limits and are therefore illegal.
As I said in another post in another place. The more I learn the less I know.
Kevin J
