Log off
Submitted: Sunday, Jan 11, 2009 at 21:45
ThreadID: 65028 Views:3163 Replies:7 FollowUps:7
Can anyone tell me why I keep getting logged off this site.
Is there an automatic log off and if so how long before one gets logged off. I have the site opened and I am still doing other work on anther site, then go back to this one and find I have logged out????
Love the bush
Reply By: That Troopy Bloke (SA) - Sunday, Jan 11, 2009 at 21:54
It's happened to me a few times too.
Just clear out your cookies and log back in.
Glenn
AnswerID: 343792
Follow Up By: Best Off Road - Sunday, Jan 11, 2009 at 22:16
Glenn,
What is a cookie, how do you access it and what do you do?
I'm a self confessed computer numbnut.
Jim.
FollowupID: 611613
Follow Up By: That Troopy Bloke (SA) - Sunday, Jan 11, 2009 at 22:35
G'day Jim,
Hairy has posted the method for IE below.
I use Firefox, and in Firefox click Tools>Options>Show Cookies.
Then you can select the exploroz cookie from the list and delete it.
Then you just have to log back into the site.
Glenn
FollowupID: 611620
Reply By: Member - Warfer (VIC) - Sunday, Jan 11, 2009 at 22:02
What i find is an issue is if your logged in and have a long reply,and go to submit it,you have to re-log on and then all your reply is gone...
Some may take half an hour or so to write and does it make you see red..Hav to start over again or do people use word then copy and paste !
AnswerID: 343794
Follow Up By: That Troopy Bloke (SA) - Sunday, Jan 11, 2009 at 22:54
If you use Firefox, there is an add-on Textarea Cache that saves whatever you type into a text area or email to your clip board. In the event of a crash you can just copy/paste it back in again....too easy.
It's saved my bacon a few times.
Glenn
FollowupID: 611631
Follow Up By: Wayne's 60 - Sunday, Jan 11, 2009 at 23:34
Warfer,
Try typing your reply in word, highlight, copy, logon, paste into reply. I agree that it is a pain when you lose your reply.
Wayne.
FollowupID: 611643
Follow Up By: Member - Warfer (VIC) - Monday, Jan 12, 2009 at 08:38
Cheers Guys
Yes hav used firefox since it started,TextArea Cache now installed..
FollowupID: 611667
Reply By: Hairy (NT) - Sunday, Jan 11, 2009 at 22:13
Gday,
Try going into
Tools
Internet Options
Privacy
and check your settings slide isnt set to block all cookies.
AnswerID: 343796
Reply By: Member - Graham H (QLD) - Monday, Jan 12, 2009 at 09:32
Could be something totally different as I use both IE and Firefox and have never been logged out even after extended sessions
AnswerID: 343827
Follow Up By: Member - Malcolm (Townsville) - Monday, Jan 12, 2009 at 09:49
I mainly use IE and also never have a problem with being logged off.
I once lost a large post in this forum so to combat that:
Whilst finished typing in the textbox use the following keys:
1. Ctrl A - That's hold CTRL down and press A. All the text will turn blue, callled highlighting the text.
2. Ctrl C - That copies the highlighted text into a clipboard (memory cache).
3. Now submit your message.
If it doesn't work, you can reopen the empty message text box and type 'Ctrl V' - that inserts text saved in the memory cache.
Malcolm
living the 'good life'
FollowupID: 611680
Reply By: timglobal - Monday, Jan 12, 2009 at 13:50
Damien,
What computer and browser are you using?
Tim
AnswerID: 343867
Follow Up By: Member - Damien L (Cairns) - Monday, Jan 12, 2009 at 19:19
IE 7 and a Dell computer at work.
At home ie5 and own built computer, come to think of it I don't rember if it does it at home. It may this system here at work, it does it on 3 different computers. I will check the settings on all 3 later.
Thanks for all of your inputs fellas, good responce.
Love the bush
FollowupID: 611802
Reply By: hotfishez - Monday, Jan 12, 2009 at 14:17
lots of technical stuff there,
I look at the forum from 2 different computers. I am permanently logged in on one computer (work unit of course)but whenever I view from the other computer (home) I have to log in each time.
Check back to see if you have used another computer, if so you may be logged in on that unit.
AnswerID: 343876
Reply By: Member - John (Vic) - Monday, Jan 12, 2009 at 21:31
Nothing hard or complex simply when you log on look at the right side of the log in panel under the heading "Login Options" and tick the box that says "Auto Log in" for this computer.
You may have to do it every few months as I think it will require a new log on??
AnswerID: 343987
