Weaco plug melting outcome
Submitted: Friday, Jan 09, 2009 at 11:17
Rock Crawler
ok , Firstly , thanks to everyones imput on this melting plug issue.
Went to a auto elec yesterday and fitted a new hella plug , upgraded the earth to 8 mm cable , ensured a very good earth , tightened pins in the female plug ( that was replaced the day before) and ran the fridge for 2 min during a amp draw
test. The fridge was drawing 8 to 9 amps . We touched the possitive end of the plug and it was still very hot.
We then desided to replace the fuse with a 20 amp fuse to see if the heat was caused by the 8 amp fuse trying to carry 9 amps . Still got hot.
The auto elec then advised that he didnt think the hella plug was really capable of pulling 9 amps and advised anderson plugs were the go.
We then replaced the plugs to anderson plugs and made up a adaptor from hella plugs to anderson , so I can use it with my ac adaptor.
I asked, why does the plug come with the transformer and not my battery , he seamed to thing it was the type of power that came out of the transformer that made it more compatible .
Anyway , ran the fridge and touched the terminals , no heat at all . Not even warm. I also notices that my fridge went from 30 deg to 0 in less than 10 min. i
I have it plugged in for 2 hrs now and will
check for heat shortly .
once again , thanks for everyones help.
Reply By: Crackles - Friday, Jan 09, 2009 at 12:03
Good to hear you got it sorted RC. In the end 90% of fridge issues seem to come down to poor plugs & thin wiring. The fridge pulling 9 amps appears a bit high but it may have been the heat generated in the plug causing that. Would be interesting to know if the amps have dropped now as
well or if that is normal for the big Waeco.
Cheers Craig......
343391
Reply By: Mark Taylor - Friday, Jan 09, 2009 at 13:13
There you go!
I knew an auto sparky could fix it for you!
The curent draw should be the same on the tranny... not sure about his theory on that one!
Mark Taylor
343403
Follow Up By: Rock Crawler - Friday, Jan 09, 2009 at 17:13
he said something about the transformes pushes more power that what my fridge needs , as the fridge was pulling more power than it could get in the car . ????? or does that sound like gobble de gook ???.
After all this , I still think the contact between the fuse and possitive pole could have caused the issue .
anyway all done now .
611280
Follow Up By: Bonz (Vic) - Friday, Jan 09, 2009 at 17:50
yep its gobbledegook
611292
Follow Up By: Member No 1- Friday, Jan 09, 2009 at 18:18
ditto
if you try to pull too much power from the trany it collapses and wont give anything...else it can only give what it was designed to putout providing demand meets that output...if demand is lower then thats all it will give...if its higher it collapses and you get nothing
611298
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Jan 14, 2009 at 18:00
Chaps,
I think you will found the Mobitronics power supply for the 80 and 110 litre Waeco's is 24Volt DC.
That would mean if your fridge draws 9 Amps at 12Volts it will only draw 4.5 Amps at 24Volts on the Mobitronics supply. Halve the current and you'll only generate a quarter of the heat.
Geoff
| Geoff,
Landcruiser HDJ78,
612244
Reply By: Willem - Friday, Jan 09, 2009 at 14:20
Geez Bud...you are hard on your equipment.....hahahahaha
8-9 amps..... whew! Puts me old 2.7amp Engel to shame
Enjoy the rest of your holiday and say Hi to the family from us.
343419
Follow Up By: Member - Doug T (NT) - Friday, Jan 09, 2009 at 15:43
Willem
Well it is a W ea co , and my Waeco has given good service over the last 6 years ive had it.
611264
Follow Up By: Rock Crawler - Friday, Jan 09, 2009 at 17:15
its because
mine bigger than your willy lol
looking at a new fridge , my weaco is just to big , might get a 50 l for smaller trips
what brand should I get ? engle or weaco ?
lol
611281
Follow Up By: Cram - Friday, Jan 09, 2009 at 20:45
What size Waeco are you using?
I have a 60litre Waeco and have had no real issues with it. I actually cut the ends off the 12 volt cord some time ago and replaced it with an anderson plug simply so I kept the connection secure.
The Waeco has been fine but when we are travelling the fridge does not leave the back of the Disco and on the last trip I found that it is just too deep and things in the bottom get lost never to be seen again until clean out time.
Recently got myself the same size engel. It is much easier to see and find things in the fridge.
I have now found myself trying to explain the wife why I need to keep both of them....."I just do" does not seem to be a satisfactory answer.....lol
611315
Reply By: Member - Mike DID - Monday, Jan 12, 2009 at 19:43
"The auto elec then advised that he didnt think the hella plug was really capable of pulling 9 amps and advised anderson plugs were the go. "
- hmmm, that suggestion sounds familiar :-)
343947
