Transferring maps from GPS to computer
Submitted: Thursday, Jan 08, 2009 at 21:39
ThreadID: 64937 Views:2377 Replies:5 FollowUps:3
Can you copy the City Navigator map set from a Garmin Nuvi 250W to the computer and then use it in Garmin Mapsource?
Louie
Reply By: The Explorer - Thursday, Jan 08, 2009 at 22:17
Hello
No - the maps are linked to the gps and cant be used by any other device/program.
AnswerID: 343315
Reply By: rawill - Friday, Jan 09, 2009 at 05:57
But you can get free Australian maps 'Open Street Maps Australia', for Mapsource. I have a system like that that works in NZ and also works on my Garmin 200w.
AnswerID: 343336
Reply By: Member - res.q.guy (Vic.) - Friday, Jan 09, 2009 at 07:23
Hi Louie
I have sent you a member message.
Neil
AnswerID: 343344
Follow Up By: Bonz (Vic) - Friday, Jan 09, 2009 at 17:36
What did the message say? I would like to know how to do this too??
FollowupID: 611288
Reply By: DIO - Friday, Jan 09, 2009 at 10:06
Mapsource is only a program that allows access of City Navigator on a PC/Laptop.
When you open Mapsource if you only have the one map (City Navigator) installed then that's the one that opens on the screen.
What are you trying to achieve ?
If it's real-time mapping off your laptop then download nRoute from Garmin. It's free and allows you to navigate off the laptop screen.
AnswerID: 343366
Follow Up By: The Explorer - Friday, Jan 09, 2009 at 11:09
Hi - the Nuvi comes with City Nav maps preinstalled. The question was can these be downloaded from the NUVI to PC and viewed with Mapsource. Answer is no as far as I know (though there is probably an illegal "hack" out there). Obviously if you had the CD version of City Nav loaded on your PC it could be viewed with mapsource/nroute but this is not the case in this instance.
FollowupID: 611204
Reply By: Louie the fly (SA) - Friday, Jan 09, 2009 at 11:03
Thanks for the replies. Not really wanting to do much with it except have a play around with it. It would be good to have a copy on the computer for reference purposes.
Louie
AnswerID: 343380
Follow Up By: Member - 1/2A - Friday, Jan 09, 2009 at 18:04
I use Mapsource all the time, you can move the mouse pointer around until you get the exact Long Lat them select the google map view to make sure you've got the right spot, make a way point and then send it to your GPS. Its fantastic if you've only got the Lat Long positions.
Arthur
FollowupID: 611295
